base gasket exchange : V-Twin Forum: Harley Davidson Forums
Old 03-11-2012, 10:34 PM   #1 (permalink)
dukcarvr's Avatar
dukcarvr wants to know Dino or Syn?
About to change heads , so is it imperative that base gaskets are replace as well? If so what is required (tools,piston ring compressor ect) Thanks inadvance Dukcarver
Mine 05 Glide Classic 95" Hers 06 XL trike 73"
Daughter's XL Bobber 51"
Size Matters
dukcarvr is offline   Reply With Quote Quick reply to this message
Old 03-11-2012, 10:47 PM   #2 (permalink)
anubisss's Avatar
anubisss wants to know Dino or Syn?
Just changing heads I think you will be fine.
anubisss is offline   Reply With Quote Quick reply to this message
Old 03-12-2012, 07:40 AM   #3 (permalink)
dukcarvr's Avatar
Anubisss Thanks for your reply, just curious have you tried this or are you speculating (as I am that reusing base "o"ring will be good). Of course I will not be disturbing cylinders, just installing head gaskets. Dukcarvr
Size Matters
Old 03-12-2012, 09:23 AM   #4 (permalink)
Location: The Pines of NJ; recently escaped from the burning sands of Nevada
n.e.confederate wants to know Dino or Syn?
dukcarver,
I have removed and replaced a cylinder head for repair without disturbing or changing the cylinder base o-ring. It's best to be careful not to disturb the cylinder and "break the seal". If the o-ring has been in there for long it will have flattened and you may not be able to get it to seal again. Why not replace them? All you really need is a ring compressor, a TC's cylinders are "unbolted" once the head bolts are off.
Eric
'02 Road King
All Bore (4-1/8") 107"
T-Man 625G cams
Insane Power heads
n.e.confederate is offline   Reply With Quote Quick reply to this message
Old 03-12-2012, 04:32 PM   #5 (permalink)
Gearhead
2wheelrider's Avatar
2wheelrider wants to know Dino or Syn?
I have pulled the heads on my 117 w/o replacing the base gasket. My 117 does not have O-rings but cometic base gaskets. So far I have had no problems(leaks). I did not remove the cylinders and took great care not to disturb them wile the heads were off. If you do feel the need to replace the base gaskets or O-rings you can sometimes pull the ristpins out without pulling the piston from the cylinder depending on the compresson hight of the piston, to install a new base gasket. That way you don't need to worry about re honing or new rings.
2001 FLHTC 95ci Custom mtr hyd cam & 06up heads
welded btm & forged pistons to much to list. for sale.(SOLD)
2001 FXDXT (S&S SA 131ci motor)
2010 street glide..103ci 57 cams...fun and reliable...
2wheelrider is offline   Reply With Quote Quick reply to this message
Old 03-12-2012, 05:05 PM   #6 (permalink)
streetglidekirk's Avatar
streetglidekirk wants to know Dino or Syn?
I have always wondered why people say " if you remove the piston from the cylinder, you have to hone and replace rings "... Why? Why not just put it right back together with the same rings and same cylinders? I have done this on briggs v-twins with no problems...ever....
I'm no expert,but I did stay at a Holiday Inn Express!
2008 Streetglide 103" 10.1:1
Woods TW-555 Cams
Bigboyz street port heads
Doherty Machine Power Pacc Air Breather
Kuryakyn Crusher True Duals
TTS Mastertune
Power Commander V
100 hp 108 tq
L.A. Choppers lowering
Arnott Aldan Air Ride 13" Shocks
Arc Audio KS 125.4 amp
DLS UP6i 6-1/2 speakers
Avatar: The wife and I
streetglidekirk is offline   Reply With Quote Quick reply to this message
Old 03-13-2012, 12:51 AM   #7 (permalink)
dukcarvr's Avatar
Streetglidekirk I agree with you,if the piston is back in its original jug ( which it has too, to be correct) why would a hone & rering be needed! But I do like 2wheelrider's way of getting around that issue(leave the piston in the cylinder). This is getting interesting ! Any body pulled cylinders installed base gasket and not honed or reringed successfully ? dukcarvr
Size Matters
Old 03-13-2012, 02:32 AM   #8 (permalink)
Dyna Ryda is reading this now saying WTF is this?
I have pulled heads and changed only HG before. If you want to change the base o-ring, you can pull the cylinder up until you can remove the wrist pin. Then you can leave the piston in the cylinder. If it were me, just pull the head and change the head gasket and forget about it.
Dyna Ryda is offline   Reply With Quote Quick reply to this message
Old 03-13-2012, 08:16 AM   #9 (permalink)
Gearhead
I also think that it would be possible to pull the pistons from the cylinders....most of the time. Maybe even every time. I not willing to break new ground in this area. Its just as easy to leave them in the cylinders.
Old 03-13-2012, 01:30 PM   #10 (permalink)
jammer45u's Avatar
jammer45u is reading this now saying WTF is this? jammer45u is reading this now saying WTF is this?
Yep, pulled the cylinders on an EVO for base gaskets and reinstalled w/o hone using the same rings about 85,000 miles ago. No problems or excessive oil consumption yet, but those damn base gaskets are seeping again.
jammer45u is offline   Reply With Quote Quick reply to this message
Old 03-13-2012, 04:32 PM   #11 (permalink)
I talked to a buddy of mine that builds top fuel drag bikes. I asked him this question on the cylinder and piston ring deal. He said that it is possible to remove and reinstall the cylinders with the same rings, but to not let the rings rotate for best results. He said if he were to do it, he would do as mentioned above by leaving the piston in the cylinder and remove the wrist pin.
Woods TW-555 Cams
TTS Mastertune
Power Commander V
100 hp 108 tq
Old 03-13-2012, 04:36 PM   #12 (permalink)
the_tunaman's Avatar
the_tunaman wants to know Dino or Syn?
If you're not going to replace the heads immediately, get some 1/2" PVC couplings and use them with two of the head bolts to keep the cylinders in place until ready.
Roger
104th-Anniversary, Hillside 107" (105/114), Shotgun Shock, Andrews 31h, V&H Pro Pipe BP, TTS Master Tune (was TMax AT, was PC III), C&C Seats, PM brakes
the_tunaman is offline   Reply With Quote Quick reply to this message
Old 03-14-2012, 12:57 AM   #13 (permalink)
"Jane you ignorant slut!"
ceraaa42's Avatar
ceraaa42 wants to know Dino or Syn?
So lets say you just replace the head gaskets, then the 0-rings leak. It happened to me on both cylinders when the bike had about 5K miles on it and Harley covered it.
What are the costs for you to go back and redo the job to replace the O-rings if they leak? How many miles are on the engine since it was done? If it's a lot, then thats a lot of heat cycles. If I tried to cut this corner, they'd leak. But it's just the way things happen to me I guess.
Chris
Candy red sunglow
103"
SE255 cams
SE Air cleaner
Fatcat Quiet baffle
Bagger brace
43 member
ceraaa42 is offline   Reply With Quote Quick reply to this message
Old 03-14-2012, 08:26 AM   #14 (permalink)
msocko3's Avatar
I've pulled heads on a couple with 20,000+ miles and never had any o-ring leaks. I have nuts made to screw onto the cylinder studs, I immediately install them and snug them down when I pull the head. As the_tunaman suggested PVC will get the job done also.
2012 GL1800 Hannigan.
Old 03-14-2012, 08:32 AM   #15 (permalink)
Rollmeaway's Avatar
Rollmeaway wants to know Dino or Syn?
I myself would not hesitate to replace the 1.99c O ring, Its just too much hassel to go back in, but thats just me I guess.
We never even said a word,
And we rolled...
Dare...
2000 FXST - Carbed
Rollmeaway is offline   Reply With Quote Quick reply to this message
