SE MVA heads flow sheets : V-Twin Forum: Harley Davidson Forums
Old 01-02-2012, 04:31 PM   #1 (permalink)
strokerjlk's Avatar
I have received several request as to what Eric's and my heads ended up flowing.
this is what I got from WFO Larry. he did the porting ,guides, and flowed them.
07 ULTRA
AMRA
SE 218
DR 218
Old 01-02-2012, 07:24 PM   #2 (permalink)
Bad Disposition's Avatar
Bad Disposition wants to know Dino or Syn?
Stroker,
Just out of curiosity, using the same set up in your pictures, what did the heads flow while they were stock? Just trying to get a little bit of Flow comparison between the MVA and R&R heads.
BD.
08 ULTRA /120 CC Mutt
4.060" big-bore cylinders.
4-5/8" stroke S&S Flywheels
Compression 10:7
T-Man 660SM
R&R Roller Rockers
S&S Lifters (HL2T with limters).
R&R Stage IV CC Heads
HPI 55 mm Throttle Body/1.800 intake
HPI Injectors
Evolution Diamond Terminator Clutch Basket
Bandit Sportsmen Clutch
Bassani Road Rage 2:1 Header
Dyno 143hp/142tq
Bad Disposition is offline   Reply With Quote Quick reply to this message
Old 01-02-2012, 07:30 PM   #3 (permalink)
hd king's Avatar
hd king wants to know Dino or Syn?
What did the exhaust side flow?
07 Denim Black Street Bob
124" S&S cylinders, custom CP pistons, S&S roller rockers, custom Smith Bros pushrods, DT 3 stage OP, S&S Premium lifters, HPI 62mm TB, DBW 6.8inj., Custom SPF exhaust, EVO Ind. 49t, Bandit clutch, TMAX, 3.07 final drive
hd king is offline   Reply With Quote Quick reply to this message
Old 01-02-2012, 08:03 PM   #4 (permalink)
SLPER's Avatar
SLPER wants to know Dino or Syn?
Lower Lifts
Hey,
Any numbers available in the .300"-.500" range?
Cheers!
Feel free to stand in front!
SLPER is offline   Reply With Quote Quick reply to this message
Old 01-02-2012, 08:08 PM   #5 (permalink)
strokerjlk's Avatar
stock on the same bench
IN 305 EX 220
after IN 330 EX 240
Larry does the EX @ 10 usually. but I think this is what he told me the EX did @ 28
I haven't really used these heads to there fullest. exhaust/cams/compression. Eric's pulled a 140 tq. but we really bandaged them with the t man cams. Eric's 662-1 pulls the best followed by the 662-2. but both need more compression and cams that will work with these heads to use there potential.
but they do pretty well out of the box in the crate motor at 10.3 .
07 ULTRA
AMRA
SE 218
DR 218
Old 01-02-2012, 08:18 PM   #6 (permalink)
Thank you sir.
Compression 10:7
T-Man 660SM
R&R Roller Rockers
HPI Injectors
Dyno 143hp/142tq
Old 01-02-2012, 09:18 PM   #7 (permalink)
strokerjlk's Avatar
Originally Posted by Bad Disposition View Post
Thank you sir.
no problem.
and thank you also. I have wondered what a stock type big name 88 cc head would do for one of these motors.it takes money and talent to pull it off. judging by that hp in your sig., a hit on exhaust would would blow over 140 tq. easy. I dont even know what you used. dosent matter really,they all work a little diff but with that hp showing now.... something will blast the tq.out if you wanted to chase it LOL.. might cost you 2 hp. might not. its only money.
SLPR
Larry would have to answer that.
FWIW... one of the engineers on the design team, said they (MVA) are good for N/A 160 hp after that.... Hurricane.
07 ULTRA
AMRA
SE 218
DR 218
Old 01-02-2012, 09:25 PM   #8 (permalink)
95280 is Prospecting
Originally Posted by SLPER View Post
Hey,
Cheers!
I am wondering the same. I like to see .100-.650 , and cfs. you also need the inches they are pulling to compare to others. I know one guy that only pulls 15 or so. he claims pulling more shows numbers only to make sales.
95280 is offline   Reply With Quote Quick reply to this message
Old 01-02-2012, 09:34 PM   #9 (permalink)
Once the new wheel, with sold bearings is installed, I'll have it up on another dyno, and see how much more I can get out of it.
Time will tell.
Compression 10:7
T-Man 660SM
R&R Roller Rockers
HPI Injectors
Dyno 143hp/142tq
Old 01-02-2012, 10:13 PM   #10 (permalink)
strokerjlk's Avatar
flow numbers are like dyno numbers. they are tools. use the same tool and compare before and after,. all along learning.
but hey I like seeing data as well.
Larry mentioned he likes to flow the exhaust @ 10 so he can hear it.
07 ULTRA
AMRA
SE 218
DR 218
Old 01-03-2012, 06:23 AM   #11 (permalink)
I tend to agree, but with experience one can compare different numbers from different tools. provided they have the proper data.
Old 01-04-2012, 11:56 AM   #12 (permalink)
road king 100 wants to know Dino or Syn?
117" and R&R cast heads
strokerjlk, I am very pleased with the R&R cast heads on my 117" and the numbers turned out great also with the 615/585 cams that are super quiet.
03 RKC=GMR 117" build WITH S&S CYL. KIT
124HP/139TQ
road king 100 is offline   Reply With Quote Quick reply to this message
Old 01-04-2012, 12:27 PM   #13 (permalink)
Premium octane member
TXCHOP's Avatar
http://www.wallaceracing.com/calcafhp.php
S&S T124
Old 01-04-2012, 07:05 PM   #14 (permalink)
jam65's Avatar
jam65 wants to know Dino or Syn?
Thanks for that Dan.I'm there with a 107" STD.As for the heads...
jam65 is offline   Reply With Quote Quick reply to this message
Old 01-04-2012, 09:16 PM   #15 (permalink)
Who needs a set of MVA heads?
BD
Compression 10:7
T-Man 660SM
R&R Roller Rockers
HPI Injectors
Dyno 143hp/142tq
