Pinging from 103 at highway speeds : V-Twin Forum: Harley Davidson Forums
Old 07-17-2011, 08:17 PM   #1 (permalink)
candubrain's Avatar
candubrain wants to know Dino or Syn?
Just noticed this yesterday and I don't know if its heat related (90F+ air temps) or if I never noticed before with the radio playing drowning out the noise
My 2010 Ultra Ltd, which has the 103 engine, but completely stock with 10,000 miles pings while in 6th gear going down the highway at 70~80 MPH.
Investigating I notice that it pings anytime I am between 2200 and 2900 RPM in 4th, 5th or 6th gear and holding the throttle for a steady speed.
It's not constant, but maybe every 10 seconds or so, I can hear a couple of pings, it's not the low frequency knock you get when you lug a motor.
I mostly run Shell 91, I have fresh Amsoil 20W50 in the crank. I ran a tank of HD octane boost and fuel cleaner through it and have changed the spark plugs and air filter. I thought maybe deposits on the plugs could have been causing pre-ignition. The plugs looked normal.
Is this the nature of the beast, i.e. super lean for EPA that it causes the bike to ping in hot weather?
a wish is a desire without an attempt...
candubrain is offline   Reply With Quote Quick reply to this message
Old 07-17-2011, 09:15 PM   #2 (permalink)
HATER OF THE GRAVEL!!!!!!
Jeffytune's Avatar
Jeffytune is reading this now saying WTF is this?
Pinging can destroy that engine in no time at all, as little as one bad tankload of fuel.
Is your bike 100% stock?
If so, get it to the dealer to have them diagnose it right away.
If you have done pipes and a air filter, what correction have you done to the computer system?
I'm Just Sayin'...
2010 FLHTCUI
96 CID w/ the quiet 6 speed
K&N RK-3930 air filter
Harley quiet high flow 110 mufflers
Vance and Hines Fuelpak
Professional Rockat Surgen
Disclaimer.
Jeffytune is offline   Reply With Quote Quick reply to this message
Old 07-17-2011, 09:45 PM   #3 (permalink)
candubrain's Avatar
100% stock
Good advice, I'll give them a call monday
Old 07-17-2011, 10:55 PM   #4 (permalink)
Big-G's Avatar
Big-G wants to know Dino or Syn?
Welcome to the club!
I have a thread going for the same problem. Here it is:
http://www.v-twinforum.com/forums/tw...y-pinging.html
Gerald
2009 Ultra 103
Big-G is offline   Reply With Quote Quick reply to this message
Old 07-18-2011, 09:08 PM   #5 (permalink)
candubrain's Avatar
thanks for the link, I did a search before posting, but didn't find what I was looking for.
Funny, today it was in the mid 70's in the a.m. and no pinging. It's looking more like something to do with high temps.
Old 07-18-2011, 09:24 PM   #6 (permalink)
Acquisitions
dynageno's Avatar
dynageno is reading this now saying WTF is this?
High temps, high gears at low speeds.
Back in Black
dynageno is offline   Reply With Quote Quick reply to this message
Old 07-18-2011, 09:26 PM   #7 (permalink)
candubrain's Avatar
But I was pinging doing 70~80 mph in 6th gear.
Old 07-18-2011, 09:53 PM   #8 (permalink)
Big-G's Avatar
Have you searched XIED's? Maybe take a look at what it can do for you.
Gerald
2009 Ultra 103
Old 07-18-2011, 10:19 PM   #9 (permalink)
Acquisitions
dynageno's Avatar
What does your Tach say at 70-80 in 6th? Over 3K?
Back in Black
Old 07-19-2011, 07:12 AM   #10 (permalink)
candubrain's Avatar
at 80 MPH in 6th gear the Tach is right at 3,000 RPM
Old 07-19-2011, 07:14 AM   #11 (permalink)
candubrain's Avatar
I was just reading about them last week on the Nightrider website.
I pulled a lot of good advice from Nightrider when I had my 97 bagger.
The XIED's sound like an inexpensive work around compared to the several hundreds required for a good Dino Tune
Old 07-19-2011, 11:19 AM   #12 (permalink)
Acquisitions
dynageno's Avatar
I guess I would get it checked out. It could be the outside air temp I suppose, but check it out anyway.
Back in Black
Old 08-19-2011, 09:58 AM   #13 (permalink)
thecatsfan wants to know Dino or Syn?
I know this is a month old, but yesterday I experienced this exact problem for the first time. I have a 2011 FLHX 103 that I bought new a couple of months ago. Yesterday outdoor temp was around 100 degrees. Running on the Interstate at 75 to 80 mph and between 2800 and 3000 RPMs. Anytime the throttle was held steady, like cruise control, I would get pinging from the engine. Not good.
I have never heard it before but I have only had the bike a couple of months, and it is not common for me to be on the interstate in the middle of the day in those temps.
Candubrian, what did you end up doing? Just curious if you resolved your issue and how.
2001 FLSTC, 95" Big Bore, SE 10.25/1 high comp pistons, stock heads professionally machined, ported and polished with oversized valves, S&S 585G gear driven cams, SE Race Ignition Module and Coil, SE air intake, Big Gun 2 1/4" duals, stock CV carb, manual compression releases. Hasn't been dyno'd yet.
thecatsfan is offline   Reply With Quote Quick reply to this message
Old 08-21-2011, 10:25 PM   #14 (permalink)
candubrain's Avatar
Talked to the dealer, he said a lot of people have been complaining about it. I asked about about a flash upgrade to the EFI. He said it's mild pinging and it won't hurt the engine.
I grew up in the 70's when you still set your point gap and timed your motor. I don't buy his answer, but I haven't done anything more about it.
It definitely is related to outside temps being hot, and the engine being lean to meet the EPA standards. I think the XIED's are the way to go.
Old 08-21-2011, 10:36 PM   #15 (permalink)
59panhead wants to know Dino or Syn?
its a lean mean 103 cu in smog pump it needs more fuel to run cooler about a 40 degree drop in eng temp just by getting a different 2 into 1 exhaust and adding a increase in air/fuel mix plus look into ultra cool oil coolers they work moving or standing still in traffic all others are junk
59panhead is offline   Reply With Quote Quick reply to this message
