BEST solution - loose comp nut/'08 107"? : V-Twin Forum: Harley Davidson Forums
Old 06-20-2011, 08:07 AM   #1 (permalink)
mzack's Avatar
mzack wants to know Dino or Syn?
Hey guys - since my 107" build I have what sounds like a loosened comp nut. There's been plenty written on how-to on a loose comp nut, so that's not my question. Is there a hands down best way to solve for this?
Is it to remove, clean, re-torque and red locktite? Is it drill and stake the nut to the washer? Or spend $44 on what seems like a permanent fix like this from AMS?:
http://www.automotivemachine.com/ind...d=46&Itemid=53
Thanks for opinions, I want to open this up and get it fixed before next weekend.
mzack is offline   Reply With Quote Quick reply to this message
Old 06-20-2011, 08:12 AM   #2 (permalink)
WikkedWorkshop's Avatar
WikkedWorkshop wants to know Dino or Syn?
that ams unit looks to be the way to go imo thats what im going to put in as soon as I make my way to that section of the bike...
09 flht
Axtell 107 cylinders CP pistons
Wood tw8, Lifters, & springs
Heads "street ported" by Dean Turk
What do I know I dont even use Amsoil!!!
WikkedWorkshop is offline   Reply With Quote Quick reply to this message
Old 06-20-2011, 05:51 PM   #3 (permalink)
mzack's Avatar
I ordered an AMS lock. Will report back on install if anyone's interested. Thinking I won't use any locktite as I can change it easier if I need to in the future.
Old 06-20-2011, 09:00 PM   #4 (permalink)
d1hojo's Avatar
d1hojo wants to know where he is and how he got here
Your 08 should have a bolt, not a nut
2007 FXDWG-Gone but never forgotten.
d1hojo is offline   Reply With Quote Quick reply to this message
Old 06-20-2011, 09:13 PM   #5 (permalink)
Rollmeaway's Avatar
Rollmeaway wants to know Dino or Syn?
Isn't that something. Now ya gotta wipe another engineers a$$ by installing
a fail-safe locknut ...
What next ...
Rollmeaway is offline   Reply With Quote Quick reply to this message
Old 06-21-2011, 07:10 AM   #6 (permalink)
mzack's Avatar
Yes - it's a bolt - you're right. There's a new washer/spacer in the lock plate kit that's threaded. The plate fits over the torqued bolt head and holes are irregulary spaced as to line up w/the new spacer. Couple of cap screws hold it together...may throw some LT Blue on those.
Old 06-21-2011, 09:35 AM   #7 (permalink)
Still the Same!
wurk_truk's Avatar
wurk_truk wants to know Dino or Syn?
Something isn't right. You shouldn't need that thing and you are guessing it's a comp bolt coming loose. Putting the cart way before the horse here.
What comp do you have? Stock? SE? If it's the SE its THAT POS making the noise... throw it in the trash.
Best best practice is to buy a NEW comp bolt every time you loosen it. That's what the SM states. If there is a question... follow that, I guess.
There are numerous things that can give you that kinda noise. clutch hub bearing, for example... or the comp being wore out and it's bottoming really quick.
Oh... one thing that I found on my bike was left over locktight in the bolt hole itself will not allow the bolt to fully seat. Used a dentist pick to dig that all out and bought a NEW bolt, instead of locktiting old bolt.
120r
wurk_truk is offline   Reply With Quote Quick reply to this message
Old 06-23-2011, 05:01 PM   #8 (permalink)
mzack's Avatar
Hi Truk - I have the stock compensator, not the SE. I'm guessing it's the comp - the noise is on the left and I especially hear when decel at lower speeds and going along in a lugging mode (like 4th gear, 25-30mph). It sounds like 'slack' for lack of a better term. It has gotten progressively worse in say a few hundred miles and I assumed (I know, I know) it was the comp that was making noise. The bike has 7500 miles and only 600 mi or so on the 107 build. I figured I'd crank it back down and got on this locking plate for $50 to my door (which arrived today). I ordered it because I don't want to have to F with it again...figuring that it wasn't big bucks for piece of mind (if it's this at all).
I have to make a locking tool out of some 1" stock and hope to change it tomorrow. We'll see - one question - are the threads on this bolt left-hand? So I should go to the MoCo and buy a new bolt hunh?
thanks!
Old 06-25-2011, 08:23 AM   #9 (permalink)
mzack's Avatar
This is the installed AMS compensator bolt lock.
I didn't notice it before looking at the pics, but does the comp sprocket look like it's fracturing/splitting at 10-11 o'clock?
Name:	6_24_11 bolt lock 002.jpg
Old 06-25-2011, 08:48 AM   #10 (permalink)
SVD999's Avatar
SVD999 wants to know Dino or Syn?
No its not left hand thread thats the trans, personally i would red lock tite it and use over
SVD999 is offline   Reply With Quote Quick reply to this message
Old 06-25-2011, 08:51 AM   #11 (permalink)
petew's Avatar
petew wants to know Dino or Syn?
I sure would love to look at that comp alittle closer without the chain to see what is up with that possible fracture... That looks like a good fix except for the sprocket... In spite of what some one else says, the SE compensator is way better, ask the dealer to show u both together, then u will see how much better the design is vs the stock one u have. Replace with SE comp and u will be done, period.
petew is offline   Reply With Quote Quick reply to this message
Old 06-25-2011, 09:34 AM   #12 (permalink)
Still the Same!
wurk_truk's Avatar
That looks like it will hold.
Pete... better do some searches here and on HTT before you make such a statement. We don't care what the 'dealer' can show you... I have personally thrown TWO of them in the trash, and so have a LOT of members. http://harleytechtalk.org/htt/index....c,29069.0.html
They DO seem to be a bit better lately, though. I will get another one because the DO work... just hate the self destruct mode.
120r
Old 06-25-2011, 11:07 AM   #13 (permalink)
mzack's Avatar
Just went for a maiden voyage of 5 miles to test it. For the sound/clunk I was hearing, the retorque seemed to fix it. The hat should keep the bolt in place and if the sprocket doesn't self-destruct I should be all set.
thanks for all info -
