New rocker breather assembly : V-Twin Forum: Harley Davidson Forums
Old 06-19-2011, 01:51 PM   #1 (permalink)
jam65's Avatar
jam65 wants to know Dino or Syn?
Doing some work on my 07 FXDL and needed breather gaskets.Went to the dealer and got a new assembly,part #17025-03A.
Any one tried these?Umbrella valves and fiber baffle is all contained in the assembly.No more loose packing that you have to mess with.
jam65 is offline   Reply With Quote Quick reply to this message
Old 06-19-2011, 04:01 PM   #2 (permalink)
Ghost Rider - IronButt
rodriguc wants to know Dino or Syn?
If possible, can you share a pic of this new breather assembly? Thanks.
Regards, Carlos
Once a Marine, Always a Marine
1981-2007
Retired, but still supporting Marines
rodriguc is offline   Reply With Quote Quick reply to this message
Old 06-19-2011, 04:24 PM   #3 (permalink)
Mother's Avatar
Mother wants to know Dino or Syn?
is this the one with the shorter bolts?
Hyperformance 124ci. 11.5cr CP pistons Triple XXX S&S'G' Green filter
Wood lifters & rocker supports
R&R bottom end DT oil pump. Andrews 64G cams
Torque Inc. JWPERF.com 110 heads
DaytonaTwinTec ignition
Baker KKK/4+1 pan
RB Racing 2" 2into1Blackhole
Smith Bros. pushrods
HUGE amount of help from Torque Inc.
153hp 149tq
JWPERF.COM
Mother is offline   Reply With Quote Quick reply to this message
Old 06-19-2011, 04:28 PM   #4 (permalink)
jam65's Avatar
Here you go.
ID:	65984   Click image for larger version
Old 06-19-2011, 04:48 PM   #5 (permalink)
That certainly is a new design...thanks again.
Please let us know how they work for you. My 02' had plastic breather assemblies and I replaced them in 03' with the older metal assemblies.
Regards, Carlos
1981-2007
Old 06-19-2011, 05:12 PM   #6 (permalink)
jam65's Avatar
Will do.Kind of surprising that the MoCo would change such a simple workings. But have to say that the wad of fiber crap made me think that this was a low tech way to go about it.I will keep you posted on the results.
Old 06-20-2011, 07:07 AM   #7 (permalink)
Axe Man
BVBOB's Avatar
Been running them in my 114 with no oil carry over problems.
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
Old 06-20-2011, 07:51 AM   #8 (permalink)
Premium octane member
TXCHOP's Avatar
Got a few sets on with no issues.. They do not fit some billet rocker supports without some major cutting though..fwiw..
S&S T124
Old 09-22-2012, 10:15 AM   #9 (permalink)
Gearhead
2wheelrider's Avatar
2wheelrider wants to know Dino or Syn?
These new breathers are a lot easier to install when doing in-frame top end work...shorter bolts.
2001 FXDXT (S&S SA 131ci motor)
2010 street glide..103ci 57 cams...fun and reliable...
http://matthias-trier.de/HD_MOTOR_in_Betrieb.gif
2wheelrider is offline   Reply With Quote Quick reply to this message
Old 09-22-2012, 11:32 AM   #10 (permalink)
Nitram_b4's Avatar
steel stampings hmmm
Nitram_b4 is offline   Reply With Quote Quick reply to this message
Old 12-04-2012, 10:54 AM   #11 (permalink)
todd comer wants to know Dino or Syn?
Is the kit #17025-03A for both heads or for just one?
2006 FLHXI
120"
Timken(Kirby)
SE 4.625 Crank plugged welded(Kirby)
R&R Cast heads
S&S roller rockers
T-man 662-2g cams
TTS
All Balls Starter
Oil Bud cooler
HP 55mm tb
Boarzilla
Baker DD6
todd comer is offline   Reply With Quote Quick reply to this message
Old 12-04-2012, 11:55 AM   #12 (permalink)
rootintootin wants to know Dino or Syn?
They come each, so you need 2 for replacement on both heads. Careful with the gaskets, not sold separate. After removing a couple of times, they tear and the rebuild kit is like $13- 14. I went back to my perfectly good Al. versions when Mine tore and dealer didn't have repair kits in stock.
2000 Lowrider, 87K miles
95" SE Forged pop-ups
S&S 585Gs on Delkron plate
Zippers Stage III CNC heads
45mm Mikuni and Supertrapp(S.E.) 2-1
Lots of other stuff Harley took years to fix
rootintootin is offline   Reply With Quote Quick reply to this message
Old 12-09-2012, 12:10 PM   #13 (permalink)
boosted-delslow's Avatar
boosted-delslow wants to know Dino or Syn?
I used them when I did my 107. No problems so far.
boosted-delslow is offline   Reply With Quote Quick reply to this message
Old 03-31-2013, 07:01 PM   #14 (permalink)
drspencer wants to know Dino or Syn?
Does anyone know the correct torque spec for the the style breather?
drspencer is offline   Reply With Quote Quick reply to this message
Old 03-31-2013, 08:10 PM   #15 (permalink)
Nitram_b4's Avatar
I would guess the motor company has them steel stamped because it is much cheaper then the aluminum assembly. It may also make a better assembly, but I think main reason is it is cheaper to manufacture
2000 FXSTS
97"
KB Pistons
Ported heads
SE 203 Cams
Fueling Camplate and Pump
Fueling lifters
S&S Quickie Push rods
Red Shift Hyd Tensioners
HRS 42 Mikuni Carb
DTT Ignition
