Dynatec TC88-2P recommended setting : V-Twin Forum: Harley Davidson Forums
Old 04-05-2011, 09:54 AM   #1 (permalink)
HugoBetz's Avatar
HugoBetz wants to know Dino or Syn?
Can anyone give me a good setting for my TC88-2P used on my 98" twin cam. It has everything listed in my signature. I currently have it set at 36A, which is close to stock. Thanks.
2000 FXSTB-98"-Dan Vance heads-Andrews 37G and S&S gears-R&R cam plate-HD HV oil pump-Baisley pushrods-Mikuni 42MM HRS-Dynatek Ignition module-Python exhaust-TP Pro Vent rocker box-Hillside tune
2007 Electra Glide Ultra Classic
Two tours in Afghanistan
Army Corp Of Engineers
HugoBetz is offline   Reply With Quote Quick reply to this message
Old 04-05-2011, 11:21 AM   #2 (permalink)
mtnmotorrider's Avatar
mtnmotorrider wants to know where he is and how he got here
I just put one of those on a Buddie's 97" all bore I just built. Same cam and street ported '07 heads. We started with the same curve for break-in and it runs fine. As soon as it has a few hundred miles on it and we can start opening her up, I will start moving up in the advance curves until it starts to ping, them back down to the privious one. We will also experiment with the curves when we take it to the dyno. Suggest you try the same.
My friends like me; everyone else thinks I'm an asshole. What's that say about my friends?
'07 Road Glide, 103 ci, Big Boyz "Bigger Valve" Street Port 85 cc heads, .030 quench for 10.2:1 cr, SE flat tops, Wood TW 6-6's, K&N air filter, Cobra/Fat Cat bastardized two-into-one exhaust, TMAT ECM with Auto-Tune.
mtnmotorrider is offline   Reply With Quote Quick reply to this message
Old 04-05-2011, 07:41 PM   #3 (permalink)
HugoBetz's Avatar
Thanks... will most likely have to do this. I was just hoping more people would chime in to see if there are similar settings.
Old 04-21-2011, 12:02 AM   #4 (permalink)
2000FiveOh wants to know where he is and how he got here
I run a36 in the cooler months and a34 in the summer. I didn't feel much difference at 38 or 40 so I stayed at 36 to be safe.
2000FiveOh is offline   Reply With Quote Quick reply to this message
Old 04-21-2011, 06:45 AM   #5 (permalink)
HugoBetz's Avatar
36A is where I have mine. The instructions say to start there since it is the closest to stock. I plan to have Hillside dynotune it as soon as it's broken in. Probably the next week or two if it stops raining.
Old 04-21-2011, 09:28 PM   #6 (permalink)
Looks a pretty mild build. Should tune easy.
