110 Build Questions : V-Twin Forum: Harley Davidson Forums
Old 02-23-2011, 09:08 PM   #1 (permalink)
93-331-29PSI's Avatar
93-331-29PSI wants to know Dino or Syn?
110 Build Questions
I've been searching the forum, and maybe I'm just an idiot, but I see plenty of threads for the 103, 117, 124 but didn't see any about the SE110 kit. I've been considering the 110 kit, but wanted some feedback before I dropped the coin. Is the 110 a bad build idea? I just want more power, and looking at the price difference between the 103 and 110, and reading about some of the disappointment of the 103, I'm thinking 110 is the best route. Pros Cons??
'12 Candy Colbalt Twilight Blue FLTRXSE
2008 Heritage - Sold
2009 Road Glide - Sold
93-331-29PSI is offline   Reply With Quote Quick reply to this message
Old 02-23-2011, 10:10 PM   #2 (permalink)
springer 03's Avatar
springer 03 wants to know Dino or Syn?
Just do the 107 and save yourself the bother.
Life is short, live accordingly!
springer 03 is offline   Reply With Quote Quick reply to this message
Old 02-24-2011, 06:09 AM   #3 (permalink)
If you start with the CVO 110 and use the stocker crank, is 117 the next up bore size? Which cams work well with that set up using the 110 heads?
Old 02-24-2011, 08:50 PM   #4 (permalink)
hightop's Avatar
hightop wants to know Dino or Syn?
A con you might not be aware of is that to install the 110 kit you have to pull the engine, completely disassemble it, bore the cases to fit the 110 cylinder spigots, then reassemble it & install it, you can just pull the top end & go up to 107 without any other work.
hightop is offline   Reply With Quote Quick reply to this message
