Cam end play, how critical is it? : V-Twin Forum: Harley Davidson Forums
Old 02-21-2011, 12:00 AM   #1 (permalink)
Torxhead wants to know Dino or Syn?
I'm doing a cam conversion on my 01 ST. So far it looks like the front cam has less than .008 end play and the rear has more than 012. The front cam has the .100 spacer on it. Suggestions?
Torxhead is offline   Reply With Quote Quick reply to this message
Old 02-21-2011, 07:27 AM   #2 (permalink)
Still the Same!
wurk_truk's Avatar
wurk_truk wants to know Dino or Syn?
120r
wurk_truk is offline   Reply With Quote Quick reply to this message
Old 02-21-2011, 08:58 AM   #3 (permalink)
Premium octane member
TXCHOP's Avatar
How are you measuring cam end play on a twin cam motor?
S&S T124
Old 02-21-2011, 10:12 AM   #4 (permalink)
autoworker's Avatar
autoworker wants to know Dino or Syn?
Assuming you have no outer bearings.....Run It.
autoworker is offline   Reply With Quote Quick reply to this message
Old 02-21-2011, 01:22 PM   #5 (permalink)
Gearhead
2wheelrider's Avatar
2wheelrider wants to know Dino or Syn?
Well this is the first time I have heard of someone checking the cam end play on a motor build. Could someone enlighten me on this. Thanks
2001 FLHTC 95ci Custom mtr hyd cam & 06up heads
welded btm & forged pistons to much to list. for sale.(SOLD)
2001 FXDXT (S&S SA 131ci motor)
2010 street glide..103ci 57 cams...fun and reliable...
2wheelrider is offline   Reply With Quote Quick reply to this message
Old 02-21-2011, 04:39 PM   #6 (permalink)
The Andrews N cam instructions call for .008-.012 minimum cam end play measured between the cam plate and the thrust washer.
I was able to measure the inner, between the shoulder of the cam and the cam plate, came up .010 so I'm good to go. Used a feeler gauge.
Does everybody just skip this part?
Old 02-21-2011, 05:18 PM   #7 (permalink)
cracker III wants to know Dino or Syn?
The cam end play is no more than .010.
The reason you measure it is... the "inner needle bearings" don't like end play... it's one of the causes of needle skidding. This can cause premature bearing failure.
The cam spacers come in different thicknesses. Or you can get an oversize one and throw it on a surface grinder and grind it so it ends up less that .005. Your needle bearings will thank you.
It's smart to pay heed the cam bearing end play!
cracker III is offline   Reply With Quote Quick reply to this message
Old 02-21-2011, 05:29 PM   #8 (permalink)
On the old style cam plate with the roller bearing holding the cams... there was not an issue with end play.
But... you said you were doing a conversion. I'm assuming you are going to the new hydraulic cam tensioner style. Those cams ride on the aluminum cam plate with no bearings. (the auto industry has been doing this for years).
Anyway this new set up calls for the proper cam end play using spacers. The spacers are the only way to set the end play on this type of cam plate.
Old 02-21-2011, 08:20 PM   #9 (permalink)
fatclassic's Avatar
fatclassic wants to know Dino or Syn?
+1 on the thicker spacers, Harley sells them in .005 step-ups. I installed with kit provided spacers, measured, then went to HD for the proper thickness ones. It's been a year since I did it, I think they're suppose to be within .005 of each other also.
'05 Fatboy with '75 FLH bags & batwing, 95" big bore, 26n andrews, '06 roadking wheels, and a little more. A FLHST?
fatclassic is offline   Reply With Quote Quick reply to this message
Old 02-21-2011, 09:10 PM   #10 (permalink)
Still the Same!
wurk_truk's Avatar
This IS a critical step with 07up cam plates. You REALLY have to try to be precise. I use a Starret straight edge when I set these up. Me??? I think .012 is TOO loose, BWDIK.
120r
Old 02-21-2011, 11:21 PM   #11 (permalink)
The service manual and the Andrews instructions call for the .100 spacer on the front\cam and then whatever size on the rear cam that aligns the rear cam sprocket with the crank sprocket. Well, once the sprockets are aligned theres no adjusting the end play, you can't go larger or smaller with the spacers. Seems like after that you would use different size spacers on the front cam so that the cam sprockets on the inner side of the cam plate are aligned.
Does that make sense?
Old 02-22-2011, 06:56 AM   #12 (permalink)
Gearhead
Well that's interesting. Back when I was in my 20's I Had a 1956 panhead that all the gears from the gen back ran on brass races. The cool thing to do then was convert everything to needle bearings. Sounds like old school technology is back in.
Old 02-22-2011, 07:06 AM   #13 (permalink)
Zwiehund's Avatar
Zwiehund wants to know Dino or Syn?
Dont worry about it. Put the .10 on the front, and shim the back one to align the gears as shown in the book and go. The play is not set by the washers, but by the cam journals. It will be fine.
2004 FLHTCI with Khromewerks Mufflers, Fullsac headers, Stage I Download, Dobeck TFI, Big Sucker, Saddlemen Gel Seat, Windvest Windshield, Cruise, HD Stainless Pullbacks, Throttle-Up Touring Stabilizer, Andrews 21N Cams, Herko Hydraulic Tensioner Upgrade Kit, Hogtunes Sound.
A perfection of means, and confusion of aims, seems to be our main problem.
Albert Einstein
Zwiehund is offline   Reply With Quote Quick reply to this message
Old 02-22-2011, 08:25 AM   #14 (permalink)
hightop's Avatar
hightop wants to know Dino or Syn?
The depth of the shouldered area of the cams - the depth of the bore in the cover = your end play, changing the washer thickness won't affect this. The rear washer thickness must be selected to align the cam sprocket with the crank sprocket, so the chain runs true.
hightop is offline   Reply With Quote Quick reply to this message
Old 02-22-2011, 11:03 AM   #15 (permalink)
autoworker's Avatar
There's your answers.
