113/Bob Wood Cam Combo : V-Twin Forum: Harley Davidson Forums
Old 01-01-2011, 03:19 PM   #1 (permalink)
2010bulldog's Avatar
2010bulldog wants to know Dino or Syn?
Everyone:
I have been building EVO's for years with Bob Wood cams and have created some great motors. Now that i am in the twin cam world i was wondering if anyone has built a HD 113 stage 4 but used a Bob Wood cam, and if so, what number of cam and what hp/tq numbers did you get?. I'm looking for numbers in the 120hp 130tq range with 100tq in by 2,000rpm.
Thanks for the help!
2011 Street Glide 103, 2010 Road Glide 114
2010bulldog is offline   Reply With Quote Quick reply to this message
Old 01-01-2011, 06:12 PM   #2 (permalink)
FXDRYDR is still riding a stock bike FXDRYDR is still riding a stock bike
Yes. Look thru the dyno section. Use the "search" function.
FXDRYDR
2003 FXD
124
Black, chrome & loud.
Old 01-02-2011, 08:53 AM   #3 (permalink)
Cpl Mike wants to know Dino or Syn?
Should be able to.
08 FLSTF--Axtell 107--JE Forged Flatops
Besley Oil Pressure Spring
Wolfgang Grasser Headwork--10.8 Com.
Compression Releases.
Woods TW-400-6--Woods Lifters--Woods Springs
Patrick Brothers Pushrods
S&S Roller Tip Rocker Arms
SE 58 M/M TB- 5.3 Inj.
Jagg Oil Cooler
SE Compensator
SE Clutch
Amsoil and Redline
D&D FatCat Big Bore Quiet
TTS Mastertune
Cpl Mike is offline   Reply With Quote Quick reply to this message
Old 01-02-2011, 01:44 PM   #4 (permalink)
destroyer wants to know Dino or Syn?
I dont have numbers but I just spoke to woods a few weeks ago and he said for that build the 408-6 is the best cam
destroyer is offline   Reply With Quote Quick reply to this message
Old 01-02-2011, 02:55 PM   #5 (permalink)
ejk_dyna wants to know Dino or Syn?
<< a HD 113 stage 4 but used a Bob Wood cam, and if so, what number of cam and what hp/tq numbers did you get?. I'm looking for numbers in the 120hp 130tq range with 100tq in by 2,000rpm.>>
a lot depends on compression and other parts.
two choices would be
tw408
tw9b
the 408 will be tq biased like you want and will power further down low.
ejk_dyna is offline   Reply With Quote Quick reply to this message
Old 01-02-2011, 03:41 PM   #6 (permalink)
SLPER's Avatar
SLPER wants to know Dino or Syn?
TW-8 Candidate..Flick the switch torque in the 2K range..
Cheers!
Feel free to stand in front!
SLPER is offline   Reply With Quote Quick reply to this message
Old 01-02-2011, 03:57 PM   #7 (permalink)
Axe Man
BVBOB's Avatar
I have one,(114) just finished it up this morn, Woods 8, will have dyno numbers in a few weeks. Hope for that VERY early torque.
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
Old 01-02-2011, 04:04 PM   #8 (permalink)
dean350b wants to know Dino or Syn?
I went T-Man TR625C with my 113, which is theoretically the "quiet" valvetrain version of Woods 400-6.
Will post results when engine is finished.
There are a lot of good people on this site that have done 113's with TW cams, so do some research and study what type of bike (FX, FL) they applied their build on to help make your decision.
dean350b is offline   Reply With Quote Quick reply to this message
Old 01-02-2011, 05:19 PM   #9 (permalink)
yes the tw8 cam is great but will not give the tq bias with early tq that he wants. the tw8 is an equal hp/tq cam if everything is right.
but yes the tw8 is definitely in the conversation.
Old 01-02-2011, 06:20 PM   #10 (permalink)
Coonass Extraordinaire
beaureed445's Avatar
beaureed445 wants to know Dino or Syn?
I used the T-Man 590G in my 113". There's a 113" on another popular site that's running with the TW8, and I believe his is making like 127/130 (ish).
2007 FXST
113" Science Project- Baisley Heads, T-Man Cams, HPI t/b,
CP Piston return springs, Fatcat with high flow muffler bearings,
Amsoil synthetic blinker fluid, etc, etc, etc.......
beaureed445 is offline   Reply With Quote Quick reply to this message
Old 01-02-2011, 09:29 PM   #11 (permalink)
BadWeather wants to know Dino or Syn?
I went the Woods 408 route see below in my signature have not had the bike dyno'd unfortunately so not sure where she is at but feels real good.
06 CVO Ultra
113" w/ 0.010 OS SE Pistons
SE MVA Heads
Wood 408 Gears
Wood lifters
HPI 55/60mm TB w/ 5.3 injectors
SE 10.5:1
ThunderMax ECM
Wimmer AC
AIM 92T VPC
Akrapovic exhaust
3.37 Final Gearing
SE 4.375 Crank Darkhorse'd
Timken conversion
SE 6 Speed overdrive Tranny
SE Roller Rockers
SE Cam plate
Dual oil coolers
BadWeather is offline   Reply With Quote Quick reply to this message
Old 01-10-2011, 12:47 PM   #12 (permalink)
FLHRC TODAY wants to know Dino or Syn?
I am running the Woods 400 cams in my 117. 120hp/130tq and the torque comes on just above idle. Great bagger set up IMO. Valve train is noisy but sounds like the new Woods lifters can help with that issue. I am certain you will have a great motor with this research you are doing.
FLHRC TODAY is offline   Reply With Quote Quick reply to this message
Old 01-10-2011, 03:13 PM   #13 (permalink)
Don Dorfman's Avatar
Have done just that with a Wood 8 and 1.94 intake and 1.57 ex. 7mm valves + beehives. 10.4/1. Bike now has 28k on the build.
Old 01-10-2011, 08:13 PM   #14 (permalink)
lonewolf55 wants to know Dino or Syn?
...This one?
'07 Street Glide 107"
lonewolf55 is offline   Reply With Quote Quick reply to this message
Old 01-11-2011, 06:24 PM   #15 (permalink)
SLPER's Avatar
107 TW-8g
This was my 107" with a TW-8g..Still needs tuning.
Cheers!
