Andrews 48H, First Impressions : V-Twin Forum: Harley Davidson Forums
Old 09-20-2010, 06:58 PM   #1 (permalink)
kslg's Avatar
kslg wants to know Dino or Syn?
Just had the Andrews 48H installed in my bike, following is my first impression for anyone looking at this or a similar cam, like the SE255.
My Bike for comparison: 2008 Street Glide with Doherty Powerpak intake, stock recored by Fullsac exhaust, Xied's.
Idle & Exhaust: High idle when starting sounds really different, when it idles down to 1k rpm, sounds almost the same, slightly different cadence. When pulling up to a light or just taking off, sometimes sounds very different when just barely on the throttle. Exhaust is quite a bit louder, about 30%. The exhaust airflow coming out of the pipe is much sharper/stronger, more of a "pop" to it. Much more growl to it when you roll on.
Vibration is somewhat more at idle, say 20% more.
(Now what everyone really wants to know) POWER: Seat of the pants calibrated dyno, the bike has as much power at a 1/4 throttle as it used to at 1/2 or more. The power is more immediate and sharp, used to be a much softer response. Merging onto highways, in about the same time and distance it took me to get to 60, I'm now getting to 80 or so. These bikes have a very tall 6th gear, now I can twist it at 65 or so and move on out much stronger. Past 4k rpm, the bulk of muscle feels like it flattens somewhat but you are still moving quite a bit quicker that stock up to the redline. This is one great cam for the rpm's you'll be riding in 99% of the time. Great bagger cam profile!!
Strangly enough, engine braking is completely gone. Shift down, let out the clutch at even 3,000rpm and you won't slow down a bit. Anyone in the know want to explain that one?!
None of this is exact, but wanted to give y'all my honest representation on the differences from stock.
2008 FLHX, super ram 5000 injection, billet unobtainium frame, raked, stretched, ported, polished, bored +1.076" (requiring sintered unobtainium cylinder liners), .890 lift/360 duration cam, 19.8:1 compression, nitrous, billet wheels, billet virgin rubber tires, custom molded seat & titanium wheelie bar. Total cost of build $1.2M
kslg is offline   Reply With Quote Quick reply to this message
Old 09-21-2010, 08:07 AM   #2 (permalink)
Don Dorfman's Avatar
This cam works for you (stage 1 96") and fits the bill, good deal
This does not make it a shoe in for a 103" and especially may act quite differently in a CVO103 or 110. It's about the heads, airflow and especially compression. Those will have to be tested before drawing any conclusions wide spread. In some cases I would not attempt the install for example the 103 limited which has very high compression and not real good close squish stock.
Old 09-21-2010, 09:07 AM   #3 (permalink)
kslg's Avatar
Your exactly right, that's why I'm always sure to include my bike info with any product I'm talking about for a proper/real comparison.
Old 09-21-2010, 09:33 AM   #4 (permalink)
sjgrzz's Avatar
sjgrzz wants to know Dino or Syn?
Looking forward to getting my 48's in the bike. Ditching the Rinehart TD's for a D&D Fatcat + cams. Thanks for the report.
sjgrzz is offline   Reply With Quote Quick reply to this message
Old 09-21-2010, 10:52 AM   #5 (permalink)
aww man if you dont have a tw5 then you aint got nothing!!! dont you know, LOL
Enjoy the cam go ride the bike, enjoy the power.
Old 09-21-2010, 11:04 AM   #6 (permalink)
kslg's Avatar
Been ridin' it every day...
Steve, thanks for getting them to me so quickly when no one else could get them!!
I didn't say where I got them in the original post for fear of being pegged as a shameless plug!!
Old 09-21-2010, 11:04 AM   #7 (permalink)
Well now that you mention it for some situations the TW5 is a good choice not all either, certainly you jest.
So in the case of the 103" limited
48h 9.38/1 corrected for 29 intake close cam
TW5-6 9.12/1 corrected for 37 intake close cam
Which would you choose all things considered especially gas quality?
Old 09-21-2010, 11:06 AM   #8 (permalink)
FOr a 103 I would install the 54
Old 09-21-2010, 11:19 AM   #9 (permalink)
Certainly those work too. Brings home my point to start with that one size doesn't fit all.
Old 09-21-2010, 03:37 PM   #10 (permalink)
Doof! There it is.....
'05Train's Avatar
'05Train wants to know Dino or Syn?
For a non-Screaming Chicken 103? Would the valve springs need to be replaced?
'05 Vivid Black Night Train
Lots o' black
103 by Dave at JD's
116.70/116.01 SAE
'10 Scarlet Red/Vivid Black Electra Glide Ultra Limited
Stage 1, Intiminators, 575s
'05Train is offline   Reply With Quote Quick reply to this message
Old 09-21-2010, 03:39 PM   #11 (permalink)
nope bolt in cam swap.
Old 09-21-2010, 03:40 PM   #12 (permalink)
Nor one cam company, that is what is great we have some many to choose from
Old 09-21-2010, 03:44 PM   #13 (permalink)
'05Train's Avatar
My wallet didn't need to hear that.....
Lots o' black
103 by Dave at JD's
116.70/116.01 SAE
Old 09-21-2010, 03:51 PM   #14 (permalink)
I have to say the 54 cam is a very easy going cam that will work in many many applications, in fact calling it underrated is noit out of line at all.
Old 09-21-2010, 04:13 PM   #15 (permalink)
'05Train's Avatar
Steve, you wouldn't happen to have a dyno chart of a 54 with stock heads in a FLHTK 103, would you?
Lots o' black
103 by Dave at JD's
116.70/116.01 SAE
