Power Star Spark Plugs : V-Twin Forum: Harley Davidson Forums
Old 07-15-2010, 09:15 PM   #1 (permalink)
Ken55's Avatar
Ken55 wants to know Dino or Syn?
Not sure if this is the right forum for posting this, but -
A fellow I met at a cookout told me that he improved the performance of his 96" H-D with Power Star Spark plugs. Was wondering if anyone out there had experience with them, if they actually improved performance, and did they run a dyno test to verify, and what the difference in numbers (HP or torque) ended up being -
Thanks -
2013 FLHTC 103"
T-Man TR555TQ Cam
Stage I Air Filter
V&H True Duals w/Monster Rounds
Ken55 is offline   Reply With Quote Quick reply to this message
Old 07-15-2010, 10:16 PM   #2 (permalink)
tunnelrat wants to know Dino or Syn?
Probably the same hokum as Split Fire and all the other variations of the same BS.
tunnelrat is offline   Reply With Quote Quick reply to this message
Old 07-15-2010, 10:25 PM   #3 (permalink)
Still the Same!
wurk_truk's Avatar
wurk_truk wants to know Dino or Syn?
I'm thinking 30hp minimum.
120r
wurk_truk is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 01:07 PM   #4 (permalink)
rbabos wants to know Dino or Syn?
Torque probably doubled though. That's what he was feeling. (rolls eyes)
Ron
[SIGPIC][/SIGPIC
120 CI. Rivera Pro Clutch, HPI 55mm . 5.3 HPI Injectors. EVO 49 Tooth Clutch Sprocket. Head Designs By Dewey (Don) Supertrap 2-1
rbabos is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 01:29 PM   #5 (permalink)
Sturge's Avatar
Sturge wants to know Dino or Syn?
Good one!
02FXSTi...107" CI
S&S 4-3/8 stroker crank
Big Boyz Heads/CP Pistons - 10:1 CR
Andrews 37 cam
SE camplate/HO oil pump/tensioner upgrade
Dan Vance Ported TB (48mm)
SE II Slip-on's
Built by me with help from VTF
Sturge is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 02:41 PM   #6 (permalink)
multispark wants to know Dino or Syn?
PowerSTAR Performance Spark Plugs
The PowerSTAR plugs are not like the Splitfire plugs.
They are unlike any other spark plug on the market.
Three US Patents.
Splitfire, Bosch, NGK all have multi-grounds. The spark will only jump to one ground at a time.
The PowerSTAR has multiple sets of gaps that under the high voltage electromagnet field produces simultaneous ignition events.
PowerSTAR gets more than one of the tips to produce a flame front. The flame front is spread out over a larger surface area.
This produces more Torque and Horsepower.
Not 30 Hp, but 5-10% low end torque from the stock HD-Delphi ignition. 4 ft-lbs from a TC-96.
The kind of difference you can feel when you twist the throttle.
We have hundreds of happy Harley customers that can feel the difference it makes in their bikes.
Check out the website.
multispark is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 03:56 PM   #7 (permalink)
Arrogant Bastard
jasilva's Avatar
jasilva wants to know Dino or Syn?
Uh huh.
__________________________________________
If con is the opposite of pro does that make congress the opposite of progress?
Isaiah 6:1-9
jasilva is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 03:59 PM   #8 (permalink)
maddogg4's Avatar
maddogg4 wants to know Dino or Syn?
Did someone say "snake oil"?
When the game is over, the King and Pawn go back in the same box.
maddogg4 is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 04:35 PM   #9 (permalink)
BOUTYM's Avatar
BOUTYM is reading this now saying WTF is this? BOUTYM is reading this now saying WTF is this?
I don't believe any claims of improved performance unless I hear it on Oprah.
Why is it that people are often labeled racist only because their comments are taken out of context?
BOUTYM is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 04:50 PM   #10 (permalink)
rscalzo's Avatar
rscalzo wants to know Dino or Syn?
PowerSTAR Performance Spark Plug RS-12CB8-10
$17.99
SKU: RS-12CB8-10
Per plug....Nothing stated where they are made. Another Chinese plug? I'll stick with stock USA plugs. Beyond their claims of increased power, no data was presented on their website.
rscalzo is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 05:47 PM   #11 (permalink)
nvsteve wants to know Dino or Syn?
Whatever happened with the test someone was going to do on a dyno?
nvsteve is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 05:58 PM   #12 (permalink)
springer-'s Avatar
Life got in the way. I am trying to get to this real soon though. Maybe this week if I can swing it.
Check out Ride of the Month
207-621-8089
Old 07-16-2010, 06:15 PM   #13 (permalink)
JohnMstrks wants to know Dino or Syn?
Hey multispark, If I buy your spark plugs do you guarantee the claim of "... 5-10% low end torque from the stock HD-Delphi ignition. 4 ft-lbs from a TC-96."
If it lives up to the claim I'll gladly pay the cost of a before and after dyno. If it doesn't, will you pay for it? If you have faith in your product, this should be a no-brainer.
JohnMstrks is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 06:30 PM   #14 (permalink)
dentboy wants to know Dino or Syn?
spark plugs
A customer just brought these plugs to my freinds shops attention. He did do back to back tests on the dyno, he did see on a low compression 107" almost 3 hp and three pounds of torque. He didnt beleive it at first, switched plugs out, numbers went down, put the power star plugs in, went back up. I've also heard from people that just putting in a fresh set of plugs will increase power, I will be throwing these plugs in my bike, will do a couple of pulls, then put some mileage on the bike, then recheck on dyno, hopefully numbers will hold true,
dentboy is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 08:04 PM   #15 (permalink)
Just a friendly jab. Thanks Springer.
