Cough Through Intake : V-Twin Forum: Harley Davidson Forums
Old 05-13-2010, 06:55 PM   #1 (permalink)
JOKERS IMPALA's Avatar
JOKERS IMPALA wants to know Dino or Syn?
I have an 09 Night Train, quite a few times when I go to start the bike it takes a little longer than youd expect for it to start and sometimes if either I let off the switch or even sometimes during cranking it will cough back through the intake and blow a mist of oil (not sure if from the A/C or build up from breathers) down on the right side of the engine. I have a Roland Sands A/C and BSS exhaust. Just wondering what is causing it to cough back through the intake, just figure a bike with 3000miles shouldnt have these issues.
2009 Night Train
Roland Sands A/C
Black Big Shot Staggereds
PCV & Autotune
Andrews 54H Cams
S&S 107" Big Bore
SE Clutch Spring
Battastinis Grips
Stage 4 Heads by Flo-Tec Racing
2014 Street Glide Special Charcoal Pearl
JOKERS IMPALA is offline   Reply With Quote Quick reply to this message
Old 05-13-2010, 07:47 PM   #2 (permalink)
09nitetrain wants to know Dino or Syn?
mine did that.... i found the fixed. its call s&s easy start cams, cause i've had it tuned and still did the samething
09 night train, big sucker 2, hooker dark side troublemakers , stage 1 map download, power commander 5 and a set of s and s easy start gear drive cams ( 583 )... autometer tach, saddlebags, and smoke out turn signal lense, and removed the mirrors. flat black paint job undecided on what to do next, i swear this thing handles better than my 98 sporty 1200
09nitetrain is offline   Reply With Quote Quick reply to this message
Old 05-13-2010, 07:53 PM   #3 (permalink)
Even for a stock motor, I mean Im really not ready to do cams yet.
2009 Night Train
Roland Sands A/C
PCV & Autotune
Andrews 54H Cams
S&S 107" Big Bore
SE Clutch Spring
Battastinis Grips
Old 05-13-2010, 08:17 PM   #4 (permalink)
mine did it more when it was hot and it helps with starting, it puts less stress on the battery and alternator. but the cams and new push rods your looking around 850 then the install is usually another 450, buts its worth the money. bike starts easier and the power is alot nicer. no more down shifting for passing car
Old 05-13-2010, 08:19 PM   #5 (permalink)
No doubt having a set of cams would be great but again not in the budget anytime soon
2009 Night Train
Roland Sands A/C
PCV & Autotune
Andrews 54H Cams
S&S 107" Big Bore
SE Clutch Spring
Battastinis Grips
Old 05-14-2010, 01:22 AM   #6 (permalink)
The Anti-RUB
petrock's Avatar
Same thing happens on my ride. Just hold onto the switch until it starts. If it starts happening more frequently, even when you don't let off the switch early, then you may be due for a new battery...
You: "Petrock, it hurts when I do this... "
Me: "Then don't do that..."
Vivid Black '06 FXSTBI
SE Stage-II 95"
My Two Front Teeph
Old 05-14-2010, 07:31 AM   #7 (permalink)
Battery was just replaced a few months ago
2009 Night Train
Roland Sands A/C
PCV & Autotune
Andrews 54H Cams
S&S 107" Big Bore
SE Clutch Spring
Battastinis Grips
Old 05-14-2010, 03:57 PM   #8 (permalink)
put the cams in... youll thank me later... fyi i did the 583, ill let you know what my numbers are tommorrow night after i get it dyno tuned
Old 05-14-2010, 04:35 PM   #9 (permalink)
Theres no doubt Id love to have a set of cams in but its not gonna happen right now. Im just curious to the real cause of the problem
2009 Night Train
Roland Sands A/C
PCV & Autotune
Andrews 54H Cams
S&S 107" Big Bore
SE Clutch Spring
Battastinis Grips
Old 05-14-2010, 04:56 PM   #10 (permalink)
its a flaw the hd motor company built in the bike so you would take it back to the stealership to spend money so they can diagnose it and then charge you even more money to fix it. have you done any modification to the bike... if so what did you do?
Old 05-14-2010, 06:18 PM   #11 (permalink)
hoghawler's Avatar
hoghawler wants to know Dino or Syn?
Does it ever back-fire through intake after the bike is running(quick throttle change off idle)
Tom
hoghawler is offline   Reply With Quote Quick reply to this message
Old 05-14-2010, 06:23 PM   #12 (permalink)
No once its running its all good just start up
2009 Night Train
Roland Sands A/C
PCV & Autotune
Andrews 54H Cams
S&S 107" Big Bore
SE Clutch Spring
Battastinis Grips
Old 05-14-2010, 07:00 PM   #13 (permalink)
hoghawler's Avatar
Most times an intake back-fire is caused by a lean a/f ratio. I'd have the fuel enrichment on idle air control valve checked.
Old 05-14-2010, 07:17 PM   #14 (permalink)
just dyno tune it
Old 05-14-2010, 07:25 PM   #15 (permalink)
HARLEYRIDER155 wants to know Dino or Syn?
I can't believe the bike needed a battery already. Usually you should get about 5 years or so with a pretty much stock bike, heck even if it isn't close to stock if its tuned some what right. Your bike must still be under warranty ? Make harley fix it .
HARLEYRIDER155 is offline   Reply With Quote Quick reply to this message
