Twin Cam 88-98 Build Advice or Opinions : V-Twin Forum: Harley Davidson Forums
Old 04-19-2010, 06:43 PM   #1 (permalink)
harleyrider54 wants to know Dino or Syn?
Currently I have a T.C.88 I will doing a 98 upgrade on
with the following components
Dan Vance Street Port Heads
Screamin Eagle 251 cams
Cylinders bored to 98 by D.V
with C.P pistons
B Lifters
Andrews adjustables
TTS Mastertune
Fueling oil pump and camplate
10:1.1 compression
Maybe some new injectors if needed
Arlen Ness Big Sucker 2
D+D Fatcats
Any advice or comments would be appreciated.
William
harleyrider54 is offline   Reply With Quote Quick reply to this message
Old 04-19-2010, 06:54 PM   #2 (permalink)
Moneygreen
arealinvestor's Avatar
Talking
with C.P pistons
B Lifters
Andrews adjustables
TTS Mastertune
10:1.1 compression
D+D Fatcats
William
Can you afford to go bigger? If so, go bigger!! You wll not regret it.Don't do the baby step thing.88 to a 98,then 103 or 107 to eventually end at a 117!!! Go big from the door, & save in the end.1 Big build instead of 2 or 3 builds!!! JMHOP!!!
T-Man gear crank set
Jagg 10 row oil cooler
K&P engineering oil filter
To much more to list!!!!!!
Old 04-19-2010, 07:25 PM   #3 (permalink)
Twin Cam 88-98 build
I sure would like to go bigger with a set of s+s wheels but with my
limited funds that would make another year wait.I want to ride as soon as i can even with what I am planning I dont see it coming together ready to romp until this winter.Lucky for me there is no such
thing as winter in la la land.Now if I win the lotto LOOK OUT WORLD !
Old 04-19-2010, 07:37 PM   #4 (permalink)
schmeg wants to know Dino or Syn?
Not a bad setup. For SE stuff the 251's work good. Stock oil pump and plate will work just fine for your build if you so desire. 10.1-1 is a very safe level. Do you already own the parts?
01 FLHT 95"
Bad Boy Engineering Heads (Old Town Maine)
Wood 6H cam
CV44 Carb
Doherty Powerpacc intake
Bassani Roadrage (pornstar) 2-1 pipe
Barnett diaphram clutch spring
Built by me
schmeg is offline   Reply With Quote Quick reply to this message
Old 04-19-2010, 08:18 PM   #5 (permalink)
aka_Matt wants to know Dino or Syn?
i think u wrote the compression wrong... should it say: 10.1:1 ?
what kind of bike is it? what kind of riding do u do, 1 up, 2 up?
with those cams, i'd bring the comp up to 10.5:1 if a lighter bike or ridden 1 up, maybe 10.3 if a heavy bike, or ridden 2 up...
Matt
FOR SALE
aka_Matt is offline   Reply With Quote Quick reply to this message
Old 04-19-2010, 08:34 PM   #6 (permalink)
HugoBetz's Avatar
HugoBetz wants to know Dino or Syn?
with C.P pistons
B Lifters
Andrews adjustables
TTS Mastertune
10:1.1 compression
D+D Fatcats
William
Sound like a good build. My build is similar except for the 37G Andrews cam, Python 2x2 with the power chamber, Dynatec TC88, and HD high volumne pump with the R&R cam plate. Dan's a great guy to deal with. I brought my stuff to him a few weeks back when I was home on leave. He doesn't do the hard sell and is free with the technical advice.
If you go bigger you will have to split the cases to bore the spigot hole. this will cost more money and if you don't need all that testosterone for the street you will be happy with your build.
2000 FXSTB-98"-Dan Vance heads-Andrews 37G and S&S gears-R&R cam plate-HD HV oil pump-Baisley pushrods-Mikuni 42MM HRS-Dynatek Ignition module-Python exhaust-TP Pro Vent rocker box-Hillside tune
2007 Electra Glide Ultra Classic
Two tours in Afghanistan
Army Corp Of Engineers
HugoBetz is offline   Reply With Quote Quick reply to this message
Old 04-19-2010, 11:35 PM   #7 (permalink)
route66paul's Avatar
With the 4" crank, I think there are better cams out there
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 04-19-2010, 11:51 PM   #8 (permalink)
I already own the parts and as cams go there are so many I just
picked one I thought was reasonable and went with it.My riding style
is almost always solo and to work and back.Truthfully the t.c. 88
is surprisingly powerful.I want to get the headwork and cylinder/piston work
done as soon as I can then have everything installed and tuned. Its like Tom
Petty says "that the waiting is the hardest part" and its true.
Old 04-20-2010, 07:49 PM   #9 (permalink)
While it is true, there may be better cams out there, that set has a good track record if done right. As I said before, 10.1-1 is very safe for all heat and riding conditions, but as Matt pointed out maybe a little soft. If it were mine on my bagger, I would have the head adjusted for a 10.5-1 comp. Make sure the squish is right also. (.030). You've got some good parts there. If it gets built and tuned right, it should work fine. Are you or a good Indy doing the work?
01 FLHT 95"
Wood 6H cam
CV44 Carb
Built by me
Old 04-21-2010, 12:38 PM   #10 (permalink)
"Jane you ignorant slut!"
ceraaa42's Avatar
ceraaa42 wants to know Dino or Syn?
That should be a great set up with a bit more compression and the heads done to match those cams. Mine pulled hard down low and all the way through at 10.25 to 1 with Bailsey heads.
I would add compression releases though. Mine didn't have them and hot starts were tough.
You may also have some valve noise with those cams.
Candy red sunglow
103"
SE255 cams
SE Air cleaner
Fatcat Quiet baffle
Bagger brace
43 member
ceraaa42 is offline   Reply With Quote Quick reply to this message
Old 02-03-2015, 07:27 PM   #11 (permalink)
mightyginger wants to know Dino or Syn?
have an 02 tc88 aquired a 4 3/8 stroker assembly for it and i want to bore the stock cylinders as far as i can without messing up seals or punching the case . once i nail down the bore i can order cp pistons . any input?
mightyginger is offline   Reply With Quote Quick reply to this message
Old 02-03-2015, 07:50 PM   #12 (permalink)
custm crzy wants to know Dino or Syn?
Think u can go to a 107 without case work on a 4 3/8 stroke crank.. Same bore as going from 88 to 98.. The 107 just has the longer stroke that makes the difference...
Talking to Dan V myself on a build just haven't pulled the trigger yet
06 FLHXI
03 ACE
05 VLX
80 KZ750
07 KX250F
custm crzy is offline   Reply With Quote Quick reply to this message
Old 02-03-2015, 08:36 PM   #13 (permalink)
is the 98 bore 3.89 ? that is the size i heard from a guy and just wanted to confirm .
Old 02-03-2015, 08:45 PM   #14 (permalink)
If I'm not mistaken it 3.938 for a 98/107 bore.. But check on that.. That's if my memory serves me correctly
06 FLHXI
03 ACE
05 VLX
80 KZ750
07 KX250F
Old 02-04-2015, 08:51 AM   #15 (permalink)
dsvracer wants to know Dino or Syn?
the 98/107 from CP measure 3.935. i offer the piston with the bore job. this insures proper clearances and longevity. I have both the 98 and 107 in stock. dsv
www.danvanceracing.com
Dan Vance Racing
641 Brook Rd
Hampton Ct. 06237
FAST, NOT FICTION
Authorized S&S dealer
2001 AHDRA National Championship Pro-Gas
dsvracer is offline   Reply With Quote Quick reply to this message
