107 all bore : V-Twin Forum: Harley Davidson Forums
Old 04-14-2010, 11:31 AM   #1 (permalink)
xler8r wants to know Dino or Syn?
107 all bore
My 06 SG's crank twisted so it's time to do what I always wanted.
My bottom end has been sent to Darkhorse, I have Axtell 107 kit on order. My heads are at 80cc. What cam should I use?
I was looking at the Andrews 67G, how much CCP is safe?
Where does this cam like to be as far as static compression?
Is there something else I should look at?
Also, where does a guy in NE Indiana get a "GOOD" sert tune?
Thanks in advance...
06 Orange pearl SG
All Bore 107
67G Cams
Stg 5 Heads by Hillside
Roland Sands A/C & wheels
D&D Fatcat
xler8r is offline   Reply With Quote Quick reply to this message
Old 04-14-2010, 01:26 PM   #2 (permalink)
whatcha gonna do for heads? did ya order the flat top pistons?
Old 04-14-2010, 01:30 PM   #3 (permalink)
Yes got the flat tops, they will ship with either .030 or .040 Head gaskets (my choice).
My heads are previously ported and milled to 80cc they have 1.90 in and 1.57 ex and springs good for .600 lift.
06 Orange pearl SG
All Bore 107
67G Cams
D&D Fatcat
Old 04-14-2010, 04:59 PM   #4 (permalink)
Michael M wants to know Dino or Syn?
How did you twist the crank?
Michael M is offline   Reply With Quote Quick reply to this message
Old 04-14-2010, 05:00 PM   #5 (permalink)
Axe Man
BVBOB's Avatar
Get your comp right, even if it means adding cc's by removing material in the combustion chamber and keep the cams you are running now, May want to consider milling a small oval dish in the pistons. I did this with an all bore 107 with R&R 525 cams last year. I swear there is some magic in that bore stroke combo, the 4 3/8 stroke 107 bikes just don't run the same, bike just ran way better than it should have, even with crappy pipes. Keep your ccp around that 190 -195 mark for a good street bike and install comp releases if you don't already have them. I think you would be really happy with this combo.
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
Old 04-14-2010, 06:28 PM   #6 (permalink)
01fxdx's Avatar
01fxdx wants to know Dino or Syn?
if i were doing one for my bagger, i'd prolly go with the s&s 625.
these combos work better than the 4 3/8 combo because the bore is bigger, unshrouding valves more improving head flow. be sure to take advantage of that.
107" axtel terrorist
thundertek cylinder heads
cams= not woods....
super "D"
loud d&d
2006 fltr
95" all secondhand parts
2009 1125cr. rolling grins.
01fxdx is offline   Reply With Quote Quick reply to this message
Old 04-14-2010, 08:03 PM   #7 (permalink)
d1hojo's Avatar
d1hojo wants to know where he is and how he got here
He probably didn't have his tongue in the right spot when he twisted the throttle a little to early in the morning on an odd day of the month
2007 FXDWG-Gone but never forgotten.
d1hojo is offline   Reply With Quote Quick reply to this message
Old 04-14-2010, 08:10 PM   #8 (permalink)
compressor#v wants to know Dino or Syn?
Thanks in advance...[/QUOTE]
Otto, or Valley Racing, in Illinois.
compressor#v is offline   Reply With Quote Quick reply to this message
Old 04-14-2010, 09:00 PM   #9 (permalink)
That's exactly how it happened!!
06 Orange pearl SG
All Bore 107
67G Cams
D&D Fatcat
Old 04-14-2010, 09:37 PM   #10 (permalink)
Redrubicon2004's Avatar
Redrubicon2004 wants to know Dino or Syn?
Is this the proper tounge position? ---->
2003 FXDWG
107" Axtell 4" Stroke, R&R615 Cams, 34hp nitrous kit
1997 FXD
Featured in July '11 Easyriders Magazine
2007 Street Glide
124", Cut, Raked, Stretched.....26" front wheel
Redrubicon2004 is offline   Reply With Quote Quick reply to this message
Old 04-14-2010, 10:04 PM   #11 (permalink)
DURWOOD's Avatar
DURWOOD wants to know Dino or Syn?
Yup,he probably had this look going on when it scissored...
2011 Road glide Ultra
John 3:16
DURWOOD is offline   Reply With Quote Quick reply to this message
Old 04-14-2010, 10:49 PM   #12 (permalink)
skyhook wants to know Dino or Syn?
i'm running the se257(almost identical to andrews 67) in a 110" motor with 10.5 compression...115hp/115tq sae 250i...pulls like a madman above 3000rpm, but roll-on torque is not that great and it had a stumble when cruising below 50mph
08 fxdse2 110", r&r stage 4 heads, 257 cams, hp inc 55mm, wood 3.25 a/c, supermeg, pc3usb
skyhook is offline   Reply With Quote Quick reply to this message
Old 04-14-2010, 11:07 PM   #13 (permalink)
better do the research on cams. with the cams that would bleed off some compression ( your heads are too tight), would work great for me, but may not work for you. may wanna talk to someone about biigger valves too, it all depends on usage and riding style.
ive been happy with mine. cant make it ping, with real gas. i guess the larger area for squish helps.
the timing on these motors is lots different, be sure and get a good tuner that will go through the entire tune-up.
Old 04-15-2010, 07:42 AM   #14 (permalink)
Sert tune
I almost had Otto tune my 98, it's just hard to get dyno time with his schedule!!
Otto, or Valley Racing, in Illinois.[/QUOTE]
06 Orange pearl SG
All Bore 107
67G Cams
D&D Fatcat
Old 04-15-2010, 08:59 AM   #15 (permalink)
DURWOOD's Avatar
Strokerjlk is in central Illinois,he knows what's up,there is probably someone closer but he will give you a complete tune,without smoke and mirrors..
Herko,Flying W Performance, is in Borden Indiana but he only tunes with TTS.
John 3:16
