oil pump : V-Twin Forum: Harley Davidson Forums
Old 04-09-2010, 05:44 PM   #1 (permalink)
cheaponecoat wants to know Dino or Syn?
oil pump
Well the oil pump went south on my 2002 electra classic. The dealer says 328.00 dollars for a new one but it will take two weeks to get it. There has to be a faster way. Have looked on ebay but not sure what I am looking at. Some of the prices there are under 200 dollars but are they junk? Any help would be appreciated.
cheaponecoat is offline   Reply With Quote Quick reply to this message
Old 04-09-2010, 06:04 PM   #2 (permalink)
fatclassic's Avatar
fatclassic wants to know Dino or Syn?
I would be more curious as to why it went bad, broken gear? broken wave washer? or a slipped crank?
fatclassic is offline   Reply With Quote Quick reply to this message
Old 04-09-2010, 06:05 PM   #3 (permalink)
60195 wants to know Dino or Syn?
Call an indi with an S&S dealer account. Have them order it second day.
60195 is offline   Reply With Quote Quick reply to this message
Old 04-09-2010, 06:24 PM   #4 (permalink)
blkfalc4 wants to know Dino or Syn?
I suggest, if crank is good, that it' maybe time to upgrade to the conversion setup. Get rid of the spring tensioners and go to the newer oil pump.
Peace of mind afterwards.
'011' FLHTK gone but not forgotten
Cherry Sunglo/Merlot Sunglo
Fullsac 'X' pipe and recore muffs
TTS
'013' BMW K1600GTL
blkfalc4 is offline   Reply With Quote Quick reply to this message
Old 04-09-2010, 08:08 PM   #5 (permalink)
Broken wave washer I think. It was all over the inside of the chest cavity. What a mess. The crank seems to be ok. Will know more when I get it cleaned up and do a runout. The rear tenshioner was almost gone. I wish I could afford to change it out but not in the cards right now. Thanks
Old 04-09-2010, 08:12 PM   #6 (permalink)
(Tensioner) they moved the keys again sorry
Old 04-09-2010, 08:14 PM   #7 (permalink)
Nahanhoku wants to know Dino or Syn?
For that kind of money I would hope you are not getting a stock replacement pump. You can get a Feuling pump for that much or as Blkfalc4 said, upgrade to the new style pump, plate and tensioners.
Nahanhoku is offline   Reply With Quote Quick reply to this message
Old 04-09-2010, 09:23 PM   #8 (permalink)
Jshuster's Avatar
Jshuster wants to know Dino or Syn?
Yea do not buy a Stock pump for that much, a Fueling would be a much better choice and a much better piece. I have a stock pump you can have.
Jshuster is offline   Reply With Quote Quick reply to this message
Old 04-09-2010, 09:31 PM   #9 (permalink)
Nitram_b4's Avatar
for that price you could have him update to the new oil pump and camplate around 365.00 but then you would need to replace the push rods too around another 165.00..but if it was my bike I would
Nitram_b4 is offline   Reply With Quote Quick reply to this message
Old 04-09-2010, 09:52 PM   #10 (permalink)
Don't really have to do the pushrods, just have to pull the rockers is all.
TTS
'013' BMW K1600GTL
Old 04-10-2010, 12:22 AM   #11 (permalink)
The great camel toe escap
1fast2liter's Avatar
1fast2liter wants to know Dino or Syn?
screaming eagle upgrade with sc cam plate and hydraulic setup with newer pump is 429.95 part number 25284-08
14" bagger apes
99 flhtc 103"
44mm sc carb kit
sc intake kit
vance and hinse ho pro pipe 2-1
103+ heads p&p by hoban
with matching pistons
s&s 585 gear drives
sc pro stroker flywheel
tc88 adj ignition
estimated at 135hp/135tq
1fast2liter is offline   Reply With Quote Quick reply to this message
Old 04-10-2010, 07:39 AM   #12 (permalink)
Thanks for the suggestions. I got price for the pump yesterday and hit the panic button, but this morning I see you are right. For that much money do the upgrade. Thanks again
Old 04-10-2010, 09:55 AM   #13 (permalink)
fatclassic's Avatar
Rear tensioner may have been the culprit, the peices may have been picked up in the pump and boom. I would ( I did over the winter) upgrade to the newer setup, better relieablity.
Old 04-10-2010, 05:16 PM   #14 (permalink)
HDTC882000 wants to know Dino or Syn?
Umm, i do not want to throw monkey wrench in the equation BUT..If your going to do the cam plate conversion to the hydraulic tensioner don't you also need to buy new cams?
The newer hydro cam tensioner uses a roller chain instead of the gear chain, that also includes the inner chain as well.
Plus, if your run-out is anywhere between .005 -.010 I would just go with the same set up that you had just for the cost saving.
The reason why I say about the run-out, the outer feeder gerotor (the thinner set against the cam plate) is thicker at the thinnest point on the earlier models. It measures @ .125" . Now the newer ones that are higher volume for the tensioners, at least the stock HD ones, (not sure on the SE or AM brands), only measure out @ .095" at the thinnest point.
Now it doesn't take a rocket scientist to figure out the .030" of more metal material for the oil pump will take a little more abuse from crank run out than the one that doesn't.
Now keep in mind, I'm an electrician, but its not my first day in the sand box either, and as some of you know, I'm going through the same crap myself
2005 FLTRI
NOW IT'S A 120R
V&H Pro Pipe HO
Barnett Scorpion Clutch
HPI 58mm TB
5.3 gps FI
SERT, Tuned by Big Boyz
Seacoast HD Dyno #'s
133 hp
127 ft lbs tq
HDTC882000 is offline   Reply With Quote Quick reply to this message
Old 04-10-2010, 08:48 PM   #15 (permalink)
The SE kit allows the pre 07 cams to be used. Cam plate uses stock bearings and the stock inner chain. You basically end up with new style pump and hyd tensioners.
Andrews or Herko's kits need to use conversion cams as the only pre 07 stock is the size of the inner cam bearings. So the cam inner journal is ground smaller than an 07+ cam.
Mike
TTS
'013' BMW K1600GTL
