Andrews cam specs/SE tapered p-rods : V-Twin Forum: Harley Davidson Forums
Old 01-16-2010, 08:32 PM   #1 (permalink)
stix68 wants to know Dino or Syn?
Question Andrews cam specs/SE tapered p-rods
Just did a cam change in my TC 96, removed my Woods 9f's and installed a set of Andrews 60H chain drives, while doing the pushrods I cracked one of the lock nuts.
My question is, will the base circles on the Andrews 60H cams allow me to use the stock HD pushrods.
All the best from downunder
Stix.
EDIT: thanx, after a bit more thought I know the answer, rest of build dictates adjustables without doubt.
stix68 is offline   Reply With Quote Quick reply to this message
Old 01-17-2010, 09:13 AM   #2 (permalink)
johneb48 wants to know Dino or Syn?
Set of SE adjustable pushrod nuts made by Poorboy
E-mail Roadking2000@charter.net if interested in a set of grade 8 nuts for the SE Tappered Pushrods,I know most people has no problem with them but if you ever remove them look close for cracks.
I can fix'em same size as what came with rods .250 thick with flat cut on top or take them up to .300,
Reply Reply with quote Notify of replies
on: November 16, 2009, 08:25:37 PM 2 General & Model Specific Technical Forums / Twin Cam / SE Tapperd Pushrod Nuts Relevance: 34.1%Started by POORBOY, Message by POORBOY
johneb48 is offline   Reply With Quote Quick reply to this message
Old 01-17-2010, 01:04 PM   #3 (permalink)
Poorboy's "nuts"
http://harleytechtalk.org/htt/index....html#msg193554
