Hydraulic lifter pre-load?? : V-Twin Forum: Harley Davidson Forums
Old 01-02-2010, 09:57 AM   #1 (permalink)
NCTURBOS's Avatar
NCTURBOS wants to know Dino or Syn?
Ok... I keep hearing about people adjusting their lifter pre-load to between 3-turns & 3.5-turns. Is this something that has collectively been determined to equal an approximate measurement? Like each turn equals .010" or something? Are all pushrods machined with the same thread pitch? Lastly, wouldn't different lifters require a different pre-load?
IE., With my Buick engines running a retro-Chevy SB roller lifter, I set the pre-load @ .025-.030 with the standard lifter and @ .005 with the race lifters...
Thanks,
K.
Dr. Jekyll and Mr. Hyde: The build(s)... Coming soon!
S.B.B. BikeBooberfest Horsepower Shootout winner, 2011...
NCTURBOS is offline   Reply With Quote Quick reply to this message
Old 01-02-2010, 11:51 AM   #2 (permalink)
60195 wants to know Dino or Syn?
All pushrods are NOT machined with the same thread pitch. The amount of preload is the amount of travel needed to center the plunger in the lifter. Most all hydraulic lifters have the same amount of plunger travel.
60195 is offline   Reply With Quote Quick reply to this message
Old 01-02-2010, 02:56 PM   #3 (permalink)
rbabos wants to know Dino or Syn?
Most lifters operate at 1/2-5/8 compressed of their total travel . You can use the pushrods manufacturers suggestion for turns if you have them or make note of how many turns it takes to bottom the lifter and back off half that amount to put you in the middle of the travel. If you really need to know how much one turn makes, you could use a long vernier or set up a dial indicator to find out, if there's no directions, or you bought a used set. Hydraulics aren't super critical of exact settings as long as you are in the compressed range that keeps them there between a cold and hot engine.
Ron
rbabos is offline   Reply With Quote Quick reply to this message
Old 01-02-2010, 03:03 PM   #4 (permalink)
Axe Man
BVBOB's Avatar
another easy way is to extend the pushrod while keeping the jamb nut in place and measure the distance between the jamb jut and the female threaded end of the pushrod with a feeler guage, since the harley lifter has approximately 200 thousands of travel you should shoot for that middle mark or sligtly more. I have heard many cases where builders have said that setting preload further (deeper)reduced valvetrain noise but that has not been my experience at all, the S&S method is to bottom out the lifter and let it bleed off then come up a couple turns from bottom(depending on thread pitch)
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
Old 01-02-2010, 08:23 PM   #5 (permalink)
.140-.150" into the lifter and run it.
Scott
Old 01-03-2010, 11:52 AM   #6 (permalink)
Thread Ender
Pikeslayer's Avatar
Another way if you know the thread pitch is to do the math to figure out how many thousandths are in one revolution.
2007 Street Glide
Old 01-03-2010, 10:58 PM   #7 (permalink)
stthomas wants to know Dino or Syn?
To adjust pushrods that you may no longer have the instruction sheets for or may have come in a bike when purchased
http://www.bigboyzcycles.com/showthread.php?t=131
stthomas is offline   Reply With Quote Quick reply to this message
Old 01-03-2010, 11:01 PM   #8 (permalink)
The lifter has a reservoir of oil under the piston in the lifter body that it drinks from as the engine grows ....
http://www.v-twinforum.com/forums/tw...c-lifters.html
Old 01-04-2010, 08:48 AM   #9 (permalink)
You realize that the link uses the TDCC method of adjustment. That will almost cause fist fights on this forum.
Ron
Old 01-04-2010, 09:56 AM   #10 (permalink)
Ron
.............or cage fighting................
Scott
Old 01-04-2010, 10:54 AM   #11 (permalink)
HDMD88 is reading this now saying WTF is this? HDMD88 is reading this now saying WTF is this?
Ron
Watch it Ron
Here is a good picture of a lifter cross section.....yes they let me play with Crayons in Group
Name:	Hydraulic Lifter colored 2.jpg
HDMD88 is offline   Reply With Quote Quick reply to this message
Old 01-04-2010, 02:34 PM   #12 (permalink)
Premium octane member
TXCHOP's Avatar
Nice pic Doc!
And Merry Christmas/Happy New Year to you and Elizabeth!
K, this may help you on the TPI figuring..
Revolution Performance Chromoly – 32 tpi
Jims Pro-Lite – 24 tpi
Slim Jims – 32 tpi
Andrews – 28 tpi
Andrews – 32 tpi
Crane New Time Savers – 28 tpi
Crane Old Time Savers – 24 tpi
Crane – 32 tpi
H-D – 32 tpi
S and S – 32 tpi
Screaming Eagle – 32 tpi
Rivera Taper Lite – 40 tpi
Rev Tech – 36 tpi
Copied this from a post by MXR515...
For depth, go by threads per inch which in the case of a pushrod with 32 tpi (S&S etc) the depth in one turn would equate to 1/32 = .03125" per 1 turn. You would need just under 4.5 turns to get to .140 on a 32tpi pushrod. Just verify your tpi on the screamin eagle pushrods
Turns=.140\.03125 = 4.48 Turns with a 32tpi pushrod
(For a 24tpi pushrod it would equate to 3.36 turns)
By Flats (with a nut with 6 sides): 32tpi*6 flats per nut = 192 wrench flats per inch
1"/192 = .005208 (rounded off)
.140/.005208 = 26.88 flats to get to a .140 depth.
26.8802 flats /6 flats per nut = 4.48 turns
S&S T124
Old 01-04-2010, 04:51 PM   #13 (permalink)
Happy New Year to you too Dan......keep up the good work.
Doc
Old 01-04-2010, 05:00 PM   #14 (permalink)
Don Dorfman's Avatar
Have some Morels I wanted to try but they have a bigger roller
Old 01-04-2010, 07:25 PM   #15 (permalink)
Axe Man
BVBOB's Avatar
Originally Posted by HDMD88 View Post
Watch it Ron
You get two stars and a sucker for staying inside the lines.
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
