Parts in Cam Service Kit (P/N 17045-99C) : V-Twin Forum: Harley Davidson Forums
Old 12-17-2009, 11:30 AM   #1 (permalink)
The Anti-RUB
petrock's Avatar
Hey,
What parts come with the Cam Service Kit (P/N 17045-99C)?
I ask because I'm getting the parts together to install the SE Cam Plate & High Flow Oil Pump upgrade (P/N 25284-08) and the install instructions state that I need the Cam Service Kit. However, the instructions only mention three parts coming from that kit for the install (Rear Cam Roller Bearing Kit P/N 8983, Cam Plate to Crankcase O-ring P/N 11301, and the Cam Cover Gasket P/N 25244-99A). I figure the Cam Service Kit probably comes with a bunch of other stuff, which would explain its $76 price tag (from Zanotti's). Do I need those other parts, or can I just order the three parts listed above? I'd hate to get half way into the install and realize that I'm missing some parts, but would also hate to waste $40 on stuff I don't need.
Thanks for any info...
Vivid Black '06 FXSTBI
SE Stage-II 95"
My Two Front Teeph
Old 12-17-2009, 12:17 PM   #2 (permalink)
46u
46u's Avatar
46u wants to know where he is and how he got here
I am getting ready to all so install the same kit in my 02 Ultra. I am going to replace both bearings for the cam plate and the secondary chain as well as the gaskets. You will all so need to get spacer kit 25285-08. If you have not done it so far I recommend replacing the POOR INA bearings in the case with Torrington bearings. I all ready replace mine a while back since I have around 80,000 miles on it this will not be the first time I have been in mine.
Sorry as far as what all comes in the cam service kit I cannot help.
46u is offline   Reply With Quote Quick reply to this message
Old 12-18-2009, 09:00 AM   #3 (permalink)
secretsquirrel wants to know Dino or Syn?
the cam service kit contains all of the gaskets to service the cam chest. Cam cover, upper rocker box, breather gaskets. Also has all of the o-rings needed to do the job. cam plate to case, push rod tubes, oil pump etc. Also has all camshaft bearings. The kit is quite complete and worth the money
secretsquirrel is offline   Reply With Quote Quick reply to this message
