SE204 compression : V-Twin Forum: Harley Davidson Forums
Old 10-17-2009, 12:48 AM   #1 (permalink)
terryjck's Avatar
terryjck wants to know Dino or Syn?
SE204 compression
Im getting ready to send my heads out for a little work,My build is 95bb SE204, 2005 FLH.new style SE billet cam plate,SERT,V&H true duels,The question is what is the best compression for this cam?seams like there is a lot of diffrent opions.Just want to get it write.the first time
terryjck is offline   Reply With Quote Quick reply to this message
Old 10-17-2009, 01:54 AM   #2 (permalink)
strokerjlk's Avatar
I am running mine at 10.2:1 static and 9.65:1 corrected.
this is a tad to much unless you can get the tune dead on and are able to adj. a little on your own for fuel and weather conditions.
I would recommend 9.3- 9.4:1 ish corrected compression.
07 ULTRA
AMRA
SE 218
DR 218
Old 10-17-2009, 07:32 AM   #3 (permalink)
OldMsocko's Avatar
OldMsocko wants to know where he is and how he got here
I had mine set at 9.7:1 and it ran fine. I was able to get a good tune and where I generally ride I was able to always buy 93 octane. If it is not tuned right you will have a ping monster.
OldMsocko is offline   Reply With Quote Quick reply to this message
Old 10-17-2009, 10:47 AM   #4 (permalink)
Mtclassic wants to know Dino or Syn?
I am curious with that CR and I am guessing the build in your signature why are you running the 204? Seems like with those ingridents already in place there are a bunch of cams that would give more all the way around.
Mtclassic is offline   Reply With Quote Quick reply to this message
Old 10-17-2009, 11:34 AM   #5 (permalink)
strokerjlk's Avatar
well....you are correct!
still deciding what I want to switch to.
this set up is working very well actually.It has instant tq. the kind that will pull the front end with just a whack of the throttle rolling @ 2500 rpm.
2nd and 3rd gears lift the front end and slip the rear @ 5500 rpm shifts also. it's a lot of fun in it's current configuration so I am not in a big hurry to swap cams. put the time is approaching. LOL
currently at 91 hp 113 tq.
07 ULTRA
AMRA
SE 218
DR 218
Old 10-17-2009, 12:03 PM   #6 (permalink)
instant torq is good. what is your ccp? compression releases?
Old 10-17-2009, 12:04 PM   #7 (permalink)
hightop's Avatar
hightop wants to know Dino or Syn?
I just looked at your sig. Where is your aux. fuel tank? What kind of mileage are you getting with your current set-up? I would think that would be an important consideration for you.
I once made 850 miles in 11 hours (Daytona to Md.), but no way I felt like getting back in the saddle the next day. Gotta give you credit!
hightop is offline   Reply With Quote Quick reply to this message
Old 10-17-2009, 05:08 PM   #8 (permalink)
strokerjlk's Avatar
CCP 200 ish
c/r yes
fuel mileage is around 36-38mpg interstate 80-85 mph two up and loaded
38-42 back roads two up and loaded. about the same solo as I ride even harder by myself LOL
aux fuel cell goes on in the passenger seat and is bolted to the struts. the fuel line stays on the bike at all times. it has a quick coupler that just plugs in like a air chuck only smaller. I wire tie it under the tour pak when not in use. the overflow (vent line) stays on the bike also, coiled up under the side cover
07 ULTRA
AMRA
SE 218
DR 218
Old 10-20-2009, 06:53 AM   #9 (permalink)
andij wants to know Dino or Syn?
the 204s are bolt in stock cr is fine if you are goin for more comp use the211s
andij is offline   Reply With Quote Quick reply to this message
