HD gasket kit question : V-Twin Forum: Harley Davidson Forums
Old 10-12-2009, 02:44 PM   #1 (permalink)
fairlydangerous wants to know Dino or Syn?
Ordering this gasket kit: Harley Davidson Cam Change Brg & Seal Kit 17045-99C. This looks like it covers all the gaskets I will need for cam change and big bore change except the head gasket and bottom o-ring(using cometic anyways). Anyone verify this?
fairlydangerous is offline   Reply With Quote Quick reply to this message
Old 10-12-2009, 05:45 PM   #2 (permalink)
Ando wants to know Dino or Syn?
Mate pretty sure its what I used and it covers everything you say
Ando is offline   Reply With Quote Quick reply to this message
Old 10-13-2009, 09:06 AM   #3 (permalink)
gtnot wants to know Dino or Syn?
You would also need rocker box gaskets IIRC. The Cam Service gasket set includes cam cover and lifter cover gaskets, along with some (INA, not Torrington) cam bearings and o-rings. I was inventorying the box last night to make sure it had the lifter gaskets.
2011 FLTRX
120R Crate
AV&V Valves/Beehives (nw_guy4_fun)
TR590 @ 10.5:1 / Baisley Rockers
MGS Stepped True Duals
S&S Tuned Port Intake
SE 58mm TB/5.3 Injectors
Evo 49T / Bandit Sportsman Clutch
SE Manual Tensioner / Smith Bros. Pushrods
Pingel Electric Shifter / Gaterman GP1023 Lifters
WPW FCS Cooling Fan
PowerVision/Tuned (to perfection) by Independent1
2007 GL1800 Motor Trike (hers)
gtnot is offline   Reply With Quote Quick reply to this message
Old 10-13-2009, 11:54 AM   #4 (permalink)
Arrogant Bastard
jasilva's Avatar
jasilva wants to know Dino or Syn?
If you have an 06 or earlier bike or an 05 or earlier Dyna get the Torrington B-148 bearings, don't use the INA bearings. Lots of failures in the past with the INA, they may be better now but why take a chance? Timken makes Torrington bearings now so you may find them under that name. As of last Nov. when I last checked they're still made in the USA.
__________________________________________
If con is the opposite of pro does that make congress the opposite of progress?
Isaiah 6:1-9
jasilva is offline   Reply With Quote Quick reply to this message
Old 10-13-2009, 12:26 PM   #5 (permalink)
2009 bike.
Old 10-13-2009, 12:28 PM   #6 (permalink)
All good advice.
Scott
Old 10-13-2009, 01:55 PM   #7 (permalink)
Here for the education!
hdryder wants to know Dino or Syn?
It comes with the top rocker box cover and breather gaskets but does not include the base rocker box gasket, the cylinder base orings or the head gaskets which you stated your using cometic. Kit is almost 100 bucks these days, you could piece the gaskets you need together with better bearings for less then the kit.
hdryder is offline   Reply With Quote Quick reply to this message
Old 10-13-2009, 02:40 PM   #8 (permalink)
Yea, probably piece it together. I didn't know which bearings they put in the kit. Thanks guys.
Old 10-13-2009, 03:39 PM   #9 (permalink)
Arrogant Bastard
jasilva's Avatar
Timken/Torrington B168 for late model bikes. Well worth the money for the piece of mind.
Isaiah 6:1-9
