Stage 4 or STage 5 R&R Heads : V-Twin Forum: Harley Davidson Forums
Old 09-19-2009, 07:02 PM   #1 (permalink)
BadWeather wants to know Dino or Syn?
Can anyone tell me what the differences are between these two options besides cost.
06 CVO Ultra
113" w/ 0.010 OS SE Pistons
SE MVA Heads
Wood 408 Gears
Wood lifters
HPI 55/60mm TB w/ 5.3 injectors
SE 10.5:1
ThunderMax ECM
Wimmer AC
AIM 92T VPC
Akrapovic exhaust
3.37 Final Gearing
SE 4.375 Crank Darkhorse'd
Timken conversion
SE 6 Speed overdrive Tranny
SE Roller Rockers
SE Cam plate
Dual oil coolers
BadWeather is offline   Reply With Quote Quick reply to this message
Old 09-19-2009, 07:06 PM   #2 (permalink)
rob71458's Avatar
rob71458 wants to know Dino or Syn?
I believe stage 4 are your own heads reworked and stage 5 are their own cast heads.
rob71458 is offline   Reply With Quote Quick reply to this message
Old 09-19-2009, 07:26 PM   #3 (permalink)
dennish's Avatar
dennish wants to know Dino or Syn?
The stage 5 heads flow a tad better than the stage 4. Worth the extra $$$ (which isn't that much more) your call. I went with the
5's, not worth looking back and wondering. However, knowing what I know now I would have saved a little longer and bought the billet heads, no better performance but they are beautiful!
dennish is offline   Reply With Quote Quick reply to this message
Old 09-19-2009, 08:53 PM   #4 (permalink)
Average Dude
YankeeBob's Avatar
YankeeBob is reading this now saying WTF is this?
Yep. I have the stg V (cast) heads. They weren't a whole lot more money than the stg IV (your own). They are a nice piece of workmanship. The stg V heads have raised floors in the intakes. They can get better velocity and therefore better cylinder fill than your reworked heads.
Deut. 23:12-13
YankeeBob is offline   Reply With Quote Quick reply to this message
Old 09-19-2009, 11:26 PM   #5 (permalink)
Has anyone checked out the Zipper 2.0 CNC heads, they are offering what they call a stage 2 head equivlent to stage 5 or 4 from everyone else but has a combustion chamber shaped like a Pro Stock head. Cost for the Zipper head is about the same as R&R.
06 CVO Ultra
SE MVA Heads
Wood 408 Gears
Wood lifters
SE 10.5:1
ThunderMax ECM
Wimmer AC
AIM 92T VPC
Akrapovic exhaust
3.37 Final Gearing
Timken conversion
SE Roller Rockers
SE Cam plate
Dual oil coolers
Old 09-20-2009, 01:55 AM   #6 (permalink)
towboattrash34 wants to know Dino or Syn?
4 has 1.7 intake the 5 has 1.8 intake with raised ports... same price.... cast flow better
2012 CVO Ultra. And loving it !!!
06 Dyna Lowrider...Sold..Gone,but not forgotten...
towboattrash34 is offline   Reply With Quote Quick reply to this message
Old 09-20-2009, 08:57 AM   #7 (permalink)
rob71458's Avatar
For those that may be concerned about apearance. The stage 5 casting is a little rough. The fin thickness is irregular and uneven. If you can afford it, go with the billets.
Old 09-20-2009, 11:45 AM   #8 (permalink)
Billet is about a grand more ouch! function before form I will go with cast or the Zipper heads
06 CVO Ultra
SE MVA Heads
Wood 408 Gears
Wood lifters
SE 10.5:1
ThunderMax ECM
Wimmer AC
AIM 92T VPC
Akrapovic exhaust
3.37 Final Gearing
Timken conversion
SE Roller Rockers
SE Cam plate
Dual oil coolers
Old 09-20-2009, 12:12 PM   #9 (permalink)
Moneygreen
arealinvestor's Avatar
How big are the intake & exhaust valves on the billet heads???
T-Man gear crank set
Jagg 10 row oil cooler
K&P engineering oil filter
To much more to list!!!!!!
Old 09-20-2009, 08:03 PM   #10 (permalink)
stix68 wants to know Dino or Syn?
R&R web site states cast heads have 1.940 inlets and 1.625 exhaust, stock bolt configuration billet heads the same and oval port billet heads to suit their motors uses 2.150 inlets and 1.725 exhaust.
stix68 is offline   Reply With Quote Quick reply to this message
Old 09-20-2009, 08:47 PM   #11 (permalink)
OrangeGlide wants to know Dino or Syn?
I own a set of R&R cast heads and I like them. Just beware that the breather bolt locations are not the same as stock. Therefore air cleaner mounting turns into a custom fit project.
OrangeGlide is offline   Reply With Quote Quick reply to this message
Old 09-20-2009, 09:44 PM   #12 (permalink)
Average Dude
YankeeBob's Avatar
You need the older style mounting bracket like I have on my 04' FLHRCI. The newer style cast mounting bracket can't be tweaked like the older style chrome plated steel bracket.
Deut. 23:12-13
Old 09-21-2009, 08:51 AM   #13 (permalink)
KingofCubes's Avatar
KingofCubes wants to know Dino or Syn?
The welded and cnc ported stage 4 have a 1.900" intake valve and can be used with stock intake. These heads rev very fast and the torque comes on quick. The stage 5 R&R heads have a 1.940" intake valve and need an intake to match the larger 1.800" port. The torque comes on a little later (600-800 rpm) than the stage 4 but there is more of it, approx. 10 ft. lbs.
King Of Cubes
515-266-6381
www.kingofcubes.com
KingofCubes is offline   Reply With Quote Quick reply to this message
Old 09-21-2009, 08:13 PM   #14 (permalink)
bigpete1's Avatar
bigpete1 wants to know Dino or Syn?
i have the zippers heads you are asking about on my 106 and soon to have another set on a 120 build on that bike nice parts i do not know how they compare to the r&r ,i bought the latest set on there closeout deals ,very nice price ,check it out on there website,thanks pete
support your local hmc ny bridge st
bigpete1 is offline   Reply With Quote Quick reply to this message
Old 10-20-2009, 03:34 AM   #15 (permalink)
unit wants to know Dino or Syn?
Hi there i'm geting a pro race 103 stage 4 kite put on my 08 steet bob now thay said it would make from 105hp to 110hp depending no your pipes the kit comes with se high flow heads with 2.120 intake valves se 260 cams 58mm throttle body perfect-fit pushrods sert 3-7/8" cylinders but it only comes in black
I hope helps
unit is offline   Reply With Quote Quick reply to this message
