Piston direction : V-Twin Forum: Harley Davidson Forums
Old 05-06-2009, 01:32 PM   #1 (permalink)
mtngoober wants to know Dino or Syn?
Question Piston direction
I am doing a 95" upgrade to my TC88 99 FLHT. Since this is all new to me and I have never done anything like this before I sent my cylinders out and had them bored and fitted with SE 10.25 to 1 pistions.
They set the rings and installed the pistons in the cylinders so that all I had to do was push the piston down far enough to get the wrist pin in the connecting rod and install the circlip. What I noticed is after I already mounted the cylinders the arrows on the top of the pistons are pointing in the wrong direction according to the Harley service manual. I can't see any differance in the piston top so I was wondering what is the reason for the arrows. I am using the stock heads that have been ported. Should I take it all apart and rotate the pistons 180 degrees? Thanks.
mtngoober is offline   Reply With Quote Quick reply to this message
Old 05-06-2009, 02:21 PM   #2 (permalink)
splitting_lanes wants to know Dino or Syn?
I would say that at minimum, you should turn the pistons around so the ring gap is in the correct location.
However, a more experienced builder may say it's ok to leave as is....
2007 Dyna
117" Hillside
splitting_lanes is offline   Reply With Quote Quick reply to this message
Old 05-06-2009, 02:38 PM   #3 (permalink)
Axtell wants to know Dino or Syn?
the pistons have a offset wrist hole to help quiet piston slap...turn them around....
Axtell is offline   Reply With Quote Quick reply to this message
Old 05-06-2009, 04:40 PM   #4 (permalink)
midnight sporty's Avatar
midnight sporty wants to know Dino or Syn?
the fly cuts go up... no jus playin.. like they said turn them around.
midnight sporty is offline   Reply With Quote Quick reply to this message
Old 05-06-2009, 05:58 PM   #5 (permalink)
Axe Man
BVBOB's Avatar
First of all, what did the manual show and which way are they pointing now? Never assume the manual is 100% correct.
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
Old 05-06-2009, 06:03 PM   #6 (permalink)
The manual says the arrows should point toward the front of the motor and they are pointing toward the back.
Old 05-06-2009, 06:27 PM   #7 (permalink)
Faast Ed wants to know where he is and how he got here
They need to point toward the front.
Faast Ed is offline   Reply With Quote Quick reply to this message
Old 05-06-2009, 06:34 PM   #8 (permalink)
Axe Man
BVBOB's Avatar
Yup, the manual is correct, now go give the guy that put them in backwards a swift kick in the groin.
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
Old 05-06-2009, 06:41 PM   #9 (permalink)
Lance03's Avatar
Lance03 wants to know Dino or Syn?
I'm no mechanic, but I think they go up and down.
Lance03 is offline   Reply With Quote Quick reply to this message
Old 05-06-2009, 07:43 PM   #10 (permalink)
LE PEW's Avatar
LE PEW wants to know Dino or Syn?
Hahahaha, you musta stayed at a holiday in!
I was gunna say that it would be easier to just spin the cylinder around but I didnt want to sound like you did.
Like everyone said, point the arrows forward ...................
LE PEW is offline   Reply With Quote Quick reply to this message
Old 05-06-2009, 07:52 PM   #11 (permalink)
Thanks guys for all your input. I would love to give him a swift kick in the ass if he wasn't so far away. Next time I am going to find someone local. Looks like I will be removing cylinders and rotating pistons. Thanks again!
Old 05-07-2009, 05:36 AM   #12 (permalink)
geoff1200 wants to know Dino or Syn?
I just installed KB forged pistons with offset pins...if my memory serves me (???) the instructions showed the arrows on the pistons pointing rearward? Visit the piston manufactures web site or call their tech before you take a leap of faith...
geoff1200 is offline   Reply With Quote Quick reply to this message
Old 05-07-2009, 06:08 AM   #13 (permalink)
milphillips wants to know Dino or Syn?
midnight sporty mentioned fly cut. Some pistons do have a larger cut where the intake valve is. Intake is larger than exhaust. Make sure larger relief is under the intake. The cylinder fins are relieved on one side for the push rod tubes. Make sure they're not turned 180. Don't mean to question you're ability, but sometimes it's the little things that get by.
milphillips is offline   Reply With Quote Quick reply to this message
Old 05-07-2009, 06:56 AM   #14 (permalink)
moosh's Avatar
moosh wants to know Dino or Syn?
what he said
the trouble with Italian food?....3 days later your hungry again
moosh is offline   Reply With Quote Quick reply to this message
Old 05-07-2009, 12:51 PM   #15 (permalink)
I confirmed with Harley the SE pistons point forward just like the stock pistons. Thanks
