best cams for my 103 : V-Twin Forum: Harley Davidson Forums
Old 01-21-2009, 10:28 PM   #1 (permalink)
sinner07 wants to know Dino or Syn?
i have a 07 street glide with a 103in motor 255 cams(came in the bike when bought) i want to get the most out of my motor. i have the heavy breather and 2-1 d&d fat cat with quite baffel. stock heads. what do you guys think?
sinner07 is offline   Reply With Quote Quick reply to this message
Old 01-21-2009, 11:49 PM   #2 (permalink)
Iron Butt, SS2000
jerry34208's Avatar
jerry34208 wants to know Dino or Syn?
Have the heads worked over and put in a set of Bob Wood's TW6
'04 Ultra built & tuned by Doc
'01 FXD built & tuned by Doc
Now if only I could learn to ride worth a sh!t...
jerry34208 is offline   Reply With Quote Quick reply to this message
Old 01-22-2009, 02:29 AM   #3 (permalink)
Registered User
xtractor wants to know Dino or Syn?
You can get really good low/ mid range power with the 255 and ported heads and stock compression for your Glide. The SE255 respond well with head work.
xtractor is offline   Reply With Quote Quick reply to this message
Old 01-22-2009, 06:29 AM   #4 (permalink)
Moneygreen
arealinvestor's Avatar
Get some head work done by a reputable builder/tuner.Get a Woods cam & a good tune using the TTS mastertune.I would also change the baffle to the performance baffle.
T-Man gear crank set
Jagg 10 row oil cooler
K&P engineering oil filter
To much more to list!!!!!!
Old 01-22-2009, 07:15 AM   #5 (permalink)
If your are looking for even more, take a peek at the Wood 400G.
Bigger brother of the 6, 7H, 6H.
Roller rockers arms will be needed.
Old 01-22-2009, 07:44 AM   #6 (permalink)
Site Sponsor
rosascycle wants to know Dino or Syn?
We are very pleased with results of the Woods TW5-6 chain drive cams with your exact set up head work is a must! also consider the S/E 50 mm throttle body at 400 bucks its a good investment. With a good tune your 103 will surprise even bigger motors
rosascycle is offline   Reply With Quote Quick reply to this message
Old 01-22-2009, 12:14 PM   #7 (permalink)
happyman wants to know Dino or Syn?
what compression do you like for the TW 5-6 on the baggers and two up riding, running 91 octane gas?
happyman is offline   Reply With Quote Quick reply to this message
Old 01-22-2009, 12:17 PM   #8 (permalink)
Don Dorfman's Avatar
Now have several out there at 10/1. Everyone loves them. Lots of punch.
http://harleytechtalk.net/htt/index.php?topic=4783.0
Old 01-22-2009, 12:22 PM   #9 (permalink)
maddog55 wants to know Dino or Syn?
I would estimate somewhere around 9.5:1. Ask the cam
manufacturer to be sure.
maddog55 is offline   Reply With Quote Quick reply to this message
Old 01-22-2009, 01:03 PM   #10 (permalink)
ejk_dyna wants to know Dino or Syn?
<<what compression do you like for the TW 5-6 on the baggers and two up riding, running 91 octane gas?>>
with any of the woods .575/.590 cams 5,6hg,7 you want to shoot for 190psi ccc with a good tune. for the 5 that would be 9.9.
ejk_dyna is offline   Reply With Quote Quick reply to this message
Old 01-22-2009, 02:12 PM   #11 (permalink)
"Jane you ignorant slut!"
ceraaa42's Avatar
ceraaa42 wants to know Dino or Syn?
It all depends on what you want to spend and if you can do your own work or not. Some cams should have cylinder head work to bring them to life and some may need different pistons. Then remember you will need the retune.
Chris
Candy red sunglow
103"
SE255 cams
SE Air cleaner
Fatcat Quiet baffle
Bagger brace
43 member
ceraaa42 is offline   Reply With Quote Quick reply to this message
Old 01-22-2009, 04:27 PM   #12 (permalink)
well i was planning to get darcey to work my heads and i also heard that the quite baffle makes more power then the performance baffle? because i hope we all know noise isnt horsepower
Old 01-22-2009, 04:49 PM   #13 (permalink)
KingofCubes's Avatar
KingofCubes wants to know Dino or Syn?
Two other great choices are the Andrews 54 and the R&R525G with the 525 being my pick if your willing to go gears. Great cam to build off of with head work.
King Of Cubes
515-266-6381
www.kingofcubes.com
KingofCubes is offline   Reply With Quote Quick reply to this message
Old 01-22-2009, 05:15 PM   #14 (permalink)
does anyone have dyno numbers or sheets with a 103 with my upgrades with 255 cams and 257 cams?
Old 01-22-2009, 10:43 PM   #15 (permalink)
route66paul's Avatar
Take a look at HQ cams
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
