What's included in cam+ service kit #17045-99? : V-Twin Forum: Harley Davidson Forums
Old 12-20-2008, 02:40 AM   #1 (permalink)
BillyPilgrim's Avatar
BillyPilgrim wants to know Dino or Syn?
I'm putting my bike back together and getting my parts ordered. My local stealer is out of a number of things I need so I'm planning to buy everything through JP. I pulled my rocker boxes so I could re-use my stock pushrods. I'm going to need to replace all o-rings and seals related to the cam chest (oil pump, cam plate, cover), pushrods, breather elements, rocker covers, etc. but I cannot find anything that details what is included in the cam service kit part #17045-99. I've pulled a couple of pictures that shows a number of gaskets and o-rings that appear to correspond to what I need, but does anyone know of a place I can find a list of the included parts with numbers?
2002 FLHPI
BillyPilgrim is offline   Reply With Quote Quick reply to this message
Old 12-20-2008, 11:10 AM   #2 (permalink)
Neil wants to know Dino or Syn?
I used the Cometic kit and it had all of the gaskets and o-rings needed. It included the cam cover gasket, lifter cover gaskets, rocker cover, breather foam and gaskets, and all of the orings including push rod tube o-rings. I believe the HD kit is basically the same. Good luck.
Neil
Neil is offline   Reply With Quote Quick reply to this message
Old 12-20-2008, 12:20 PM   #3 (permalink)
route66paul's Avatar
You can do much better for less money with aftermarket parts. call any of the sponsors that do builds and they can set you straight.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
