Thoughts on the Crane HTC-300-2 cam : V-Twin Forum: Harley Davidson Forums
Old 10-19-2008, 04:04 PM   #1 (permalink)
HS2020's Avatar
HS2020 wants to know Dino or Syn?
Does anyone have any ideas about how well the Crane HTC-300-2 cam should perform in the 96" engine for a touring bike?
It's Specs. are:
Intake: 13/33, Exhaust: 42/14, Max. lift of 0.505"
My bike's engine is currently a stock 07' FLHTC, with only SE mufflers, SE air filter, and Tmax/Autotune added.
I don't plan on any immediate cylinder head work with H/C pistons, but was looking for just a little more grunt from 2000 to 4500 rpm range. The specs for this cam seems to be a very close split between the Andew's 26H and 37H, which both have decent reviews for a stock motor. Any insight or suggestions about Crane cams would be greatly appreciated. Thanks
2014 FLD Switchback (silver)
Arne J., Bothell, WA
My bike maintains my sanity.
HS2020 is offline   Reply With Quote Quick reply to this message
Old 10-22-2008, 12:32 AM   #2 (permalink)
Grand Poobah wants to know Dino or Syn?
I have lived with this Crane cam for around 27,000 miles and it pulls well and comes on early. I shift between between 2 and 3k most of the time. I am actually looking to make a change and am willing to loose a little on the very low bottom to gain a litttle above 4,000. If I had it to do over I would choose the Crane 310 on a 96" engine. My gut feeling is the strokers can benifit from more duration and possible a little later closing to gain stronger performance at higher RPM's. Dont get me wrong the Crane runs strong . I am real interested in the Dave Mackie 510 cam and the HQ500. Winters coming.
Walt
Grand Poobah is offline   Reply With Quote Quick reply to this message
Old 10-22-2008, 01:09 AM   #3 (permalink)
HS2020's Avatar
Originally Posted by Grand Poobah View Post
I have lived with this Crane cam for around 27,000 miles and it pulls well and come on early. Because of its power I shift between most normal riding stays between 2 and 3k. I am actually looking to make a change and am willing to loose a little on the very low bottom to gain a litttle above 4,000. If I had it to do over I would choose the Crane 310 on a 96" engine. My gut feeling is the strokers can benifit from more duration and possible a little later closing to gain stronger performance at higher RPM's. Dont get me wrong the Crane runs strong .
Walt
Thanks for your input on this matter, it's greatly appreciated. I found out that the information I listed earlier about the Crane 300 cam's durations was incorrect according to Crane's web-site. The cam spec's I listed earlier was what I found on Nightrider's site under their HD cam spec's list. It appears that my shift points are almost exactly as your's, but I just need a little more pull for passing. The stock C/R on my engine is about 9.2:1, so I'm very hesitant about over camming my stock engine with too much duration or lift to risk adversely affecting my touring gas mileage. The Andrew's 26G cam now appears to be my limited best choice cam for a slight improvement to my stock engine without my paranoid concerns.
Thanks again, and ride safe.
Arne
btw: Thanks for the tips on the Dave Mackie & HQ cams, I'll be sure to check them out too before deciding. Good luck on your winter project.
Old 10-22-2008, 04:38 AM   #4 (permalink)
Moneygreen
arealinvestor's Avatar
It's Specs. are:
With an intake close of 33 degrees it should give you just what your looking for .Not much lift,but then again its a bolt in cam.You want real grunt down low ?????Go to Woods performance and choose one of his cams!!!!You will not be disappointed!!! His cams will bring the beast out of your tame 96 motor!!!! Call Mr.Woods tell him what you have ,and he will recommend a cam for you!!!!!
T-Man gear crank set
Jagg 10 row oil cooler
K&P engineering oil filter
To much more to list!!!!!!
Old 10-22-2008, 06:23 AM   #5 (permalink)
softailguy wants to know Dino or Syn?
I chose the 26G for similar reasons and was pleasantly surprised at how much difference it made... Power where you use it most...
fwiw & Regards,
Doug
'07 FLSTC
SE AC
PC III
Magnecor Wires
Andrews 26G Cams
SE Cam Plate
Cycle Shack Slipons
softailguy is offline   Reply With Quote Quick reply to this message
Old 10-22-2008, 09:28 PM   #6 (permalink)
HS2020's Avatar
Thanks for your in-put on this matter. The intake close that I posted was based on bad information that I acquired earlier. That Crane cam has a much longer intake close for what I want in early to mid. torque. I've heard a lot of great press here about the Woods 6-6 cams, but that it truely performs it's best with a high C/R and flowed heads. Thanks again for the suggestions though, it's greatly appreciated.
Old 10-22-2008, 09:32 PM   #7 (permalink)
HS2020's Avatar
fwiw & Regards,
Doug
Thanks for the update on your positive experience with that cam, I appreciate the feedback.
Take care,
Old 10-25-2008, 12:25 AM   #8 (permalink)
fastroadking106 wants to know Dino or Syn?
try the wildthing tc46 try have done alot of work with lobe timinga and have a very wide power band and you will be super impressed with the starting advantages you get also
fastroadking106 is offline   Reply With Quote Quick reply to this message
Old 10-25-2008, 01:18 AM   #9 (permalink)
HS2020's Avatar
Thanks for the tip, I'm trying to keep an open mind with all these options, and I'll add them to my research list.
Old 10-25-2008, 09:48 AM   #10 (permalink)
I have used about 6 sets of these and everybody loves them I have change a 95" harley build over to the from s/e 211 that had to use comp. releases for every start to now not using them at all and the bottom end to midrange power change is outragous even with a cheap set of drag pipes with big city baffles if he would go to a good 2 into 1 pipe it would really come alive
Old 10-25-2008, 12:40 PM   #11 (permalink)
HS2020's Avatar
Thanks again for your input; I'm beginning to think that I might want to get a "little more cam" for future engine mod's.
Old 01-01-2009, 12:32 AM   #12 (permalink)
grandpa Tom's Avatar
grandpa Tom wants to know Dino or Syn?
HS2020: I am also looking at cams for my 07 FLSTC and just seen the Crane HTC 300-2, during my looking for Crane cam specs I have found a site that said the Crane cam for the 96" motor is now called the 1-6000, so I am a little mixed up on which crane cam is really which for my bike.
Another site says the HTC 300 will still work, then another says its for the 88" not the 96"s so its confusing.
Now for my question in your above statement, You said the Crane cam has a longer Intake close, Do you mean Earlier or later? I have never heard of longer Intake Close when referring to Intake valve timing.
Then you said it has a longer IC than what you want in a Low-mid tq. My research and understanding is that you want a early closing Intake for more tq low-mid rpm's.
Just trying to understand you ?'s and or statements......
In my search the stock cam closes at 30*. Andrews 26 is 35*, SE204 is 34*, and the crane HTC300-2 is 33*. So if you want good low-mid TQ the crane 300-2 (1-6000) has a lower intake close than most others for a bolt in cam. Unless you put in a 4* advance gear.
Up till now I was thinking on the SE 204, but I want to dig to find more information on the Crane cams now.
Does anyone have dyno #'s they can post or tell about.. or maybe the HTC310-2 dyno results.
thanks if anyone can help....
Retired
07 FLSTC, 47k miles
SERT, SE/K&N, Rush
Andrews 26h cams
grandpa Tom is offline   Reply With Quote Quick reply to this message
Old 01-01-2009, 08:17 AM   #13 (permalink)
BaggerDad's Avatar
BaggerDad wants to know Dino or Syn?
Here's another Crane HTC 300-2 (1-6000) thread on the Harley Tech Talk Net forum
http://harleytechtalk.org/htt/index....ic,3623.0.html
http://harleytechtalk.org/htt/index....html#msg205919
http://harleytechtalk.org/htt/index....ic,4582.0.html
2002 Road King Classic 107ci / 1746cc
Static Compression 10.23:1 / Corrected CR 9.54:1)
Baisley Superstock Plus Heads (87.2cc- 1.94 I / 1.630 E)
Compression Releases
3.937" Axtell cylinders
3.937 CP Flat Top Pistons
0.030" Head Gasket
Wood TW5G cam (Intake close 37 & Duration 234/234)
Horsepower Inc 51mm TB
HPI V2 A/C
S&S Super Sidewinder 2-1
3.37 final gear ratio
TTS Mastertune
BaggerDad is offline   Reply With Quote Quick reply to this message
Old 01-01-2009, 02:33 PM   #14 (permalink)
HS2020's Avatar
Originally Posted by grandpa Tom View Post
HS2020: I am also looking at cams for my 07 FLSTC and just seen the Crane HTC 300-2, during my looking for Crane cam specs I have found a site the said that now the Crane cam for the 96" motor its called the 1-6000, so I am a little mixed up on which crane cam is really which for my bike.
In my search the stock cam closes at 30*. Andrews 26 is 35*, SE204 is 34*, and the crane HTC300-2 is 33*. So if you want good low-mid TQ the crane 300-2 is a little better than the others for a bolt in cam. Unless you put in a 4* advance gear.
grandpa Tom,
It's been several months since I posted this while researching cams, and discovered that the net-site I pulled the cam spec's for were incorrect. After later visiting the Crane website the specs on those cams have a little more duration than I wanted for my stock engine. The major issue that's been ticking me off is that I've found at least 3 different cam spec's for the 07'-08' 96" engine, and don't know which one is truely correct. They all agree though that the stock cams have literally a negative In/Ex overlap. My research for the stock cam spec's are Screamin Eagle catalog, Andrews website, and AI's article-June 2008. According to AI's article regarding the Big Twin Cam Spec. Chart, the 1999 FI Twinkie Engines (pre-extreme smog reqmt's) were running IN: 02/34, 216* and EX: 36/06, 220*, with cam lifts of 0.473". I feel that something closer to those spec's should make the stock 96" engine run much better, without sacrificing it's gas mileage too bad. The cam that currently has my strongest interest is the Andrews 21H or 26H, since its extremely rare for me to exceed more than 4500 rpm's, even while passing.
Best of luck on finding the best cam for your riding style.
Arne
Old 01-06-2009, 12:40 AM   #15 (permalink)
Well Happy New Year to all.
HS2020: I have the same problem finding different stock 07 cam Specs .
Big Boyz web site shows 484 lift both, Int = -12/30, exh = 38/4. overlap -8,
LC = 111/107, and LS = 109 for the injected 07-08, but not sure if it is for the B motors.
One of the best post on cams I have found is by BAGGERDAD two post up. He posted it on 10/5/05 it explains the ins/outs of cams as good as any.
So my hat is off the BAGGERDAD. thanks for that posting. Easy to read yet deals with problems we face today picking our cam..
Another article I read lately, cant find it now, says the bolt in cams are in a group of their own. All close to each other and picking THE one is still personal preference.
Is seems to me that different areas of the country have a different favorite cam.
I will agree the Woods cam probably is at the top of the list everywhere.
Although I dont know anyone running them. But some say even it has draw backs..
At my age and the guys I ride with mostly Heritages, and Road Kings, we want our Tq somewhere between 2-4.5k rpm's.
So the Wood 5 & 6:, Crane 1-6000 & 1-6001:, Andrews 21 & 26:,& 37:, SE 203 & 204 :, Dave Mackie tc500:, HQ TC510:, Tman TR525C:, and others not on the this list is all close to each other but still different enough to pick one for each ones needs.. The Bold ones = better low TQ
I am looking at these cams because I want a little more TQ low-mid, and a better running motor, I am not interested in building a 100-100 or more motor.
Might lose Grandma off the rear end, HA, That would NOT be GOOD!
So I might be picky but still trying to find the one that fits my needs and not have to do it again.
So far for me I leaning on the Crane 1-6000 and a new set of D&D fatcats Quiet baffle.
Already have stage 1 and Rush 2" baffles. K&N, SERT.
We ride two up 90% time, and total around 375lb's before we stop and eat. Ha.
Very seldom rev above 5k and usually before 4k, If Grandma's on.
Thank you all for this Forum and it is helpful to many...
Retired
07 FLSTC, 47k miles
SERT, SE/K&N, Rush
Andrews 26h cams
