88 to 95 : Is it worth it? : V-Twin Forum: Harley Davidson Forums
Old 08-27-2008, 03:38 PM   #1 (permalink)
Mbluz wants to know Dino or Syn?
I have an 04 Roadking with s+s 510 gear drive cams still stock bore 88. It has a power comander and wild pig mufflers. I's dyno numbers are: 87.06 tq and 78.1 HP. If I go to the 95" with no head work what are going to be my gains? Is it worth it?
Mbluz is offline   Reply With Quote Quick reply to this message
Old 08-27-2008, 03:41 PM   #2 (permalink)
Axe Man
BVBOB's Avatar
Honestly, if you are just going to pull it down to do only the 95 , save your money, if you are going through the trouble of pulling the top end down it would be a waste without at least a nice street port and cc of the heads to make the whole package come together.
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
Old 08-27-2008, 03:58 PM   #3 (permalink)
You might gain 4/4 5/5 without head work. As BV stated the head work is where it is at.
Old 08-27-2008, 04:29 PM   #4 (permalink)
ride4daze's Avatar
ride4daze wants to know Dino or Syn?
I have a '06 RK with 95" bore, Andrews 26 chain drive cams, street port heads set to 9:6:1 comp and .030 head gasket, SE/AC and true duel ex. The tune is basically a canned sert map that I chose myself. Had it on a dyno at a horsepower wars event, because it only cost $20.00 to see what it had. Anyway, HP was 87.6 and Tq was 93. Bike runs like day vs night compared to when it was a 88". I did all work except heads myself and am very happy.
2006 Road King, SE/AC, Rinehart Duels, Andrews TW26a cams, 95" big bore, Bigboyzs street port heads, .030 head gaskets, 3:37 primary gearing, sert with tune by me.
ride4daze is offline   Reply With Quote Quick reply to this message
Old 08-27-2008, 05:04 PM   #5 (permalink)
trying this again, unshrouding the valves by going 95 inch is where the gains are, not neccesarilly the 7 cu. in.
Old 08-27-2008, 05:09 PM   #6 (permalink)
route66paul's Avatar
In order to raise the c/r, you will need pistons, if still 88", you will need domes( shaving the heads enough to get the comp needed would hurt the intake seal), or go with 95" pistons, flathead and .030 gasket should get you to 9.4:1, a minor mill on the heads will take the comp to 10.0:1, domed pistons will get more. You might as well go to 95(or 98).
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 08-27-2008, 05:13 PM   #7 (permalink)
Kivaari wants to know Dino or Syn?
unshrouding
You're meaning....changing the shape of the combustion chamber to "cover" the larger bore....so to speak...increasing combustion chamber area around the valves..????
Kivaari is offline   Reply With Quote Quick reply to this message
Old 08-28-2008, 06:19 AM   #8 (permalink)
Jeepin_Lawyer's Avatar
Jeepin_Lawyer wants to know Dino or Syn?
Take it from me, don't do it piece by piece you will spend so much more $$$ and it won't run right until it is all done! Do a package (even a budget package) from one of the venders and you will be so much happier. Steve at GMR tried to tell me this a long time ago. Finally I ended up with a full package and it runs great now but I wasted lots of $$ on labor, gaskets and individual parts getting to the final result.
"Let us speak courteously, deal fairly, and keep ourselves armed and ready." Theodore Roosevelt
Jeepin_Lawyer is offline   Reply With Quote Quick reply to this message
Old 08-31-2008, 06:04 PM   #9 (permalink)
KingofCubes's Avatar
KingofCubes wants to know Dino or Syn?
Squish
Not a good idea to increase combustion chamber or take away squish area. Although the faster burn comes from flat tops we prefer to use domes to make up the difference for the street. Some porters use low 9's on compression with short duration cams where as we like to use higher compression with longer duration cams, ccp comes out about the same. The thumb of rule is the higher the ccp, the tighter the squish needs to be. Pinging comes from heat and pressure, if you take away heat you can up the pressure without detonation.
King Of Cubes
515-266-6381
www.kingofcubes.com
KingofCubes is offline   Reply With Quote Quick reply to this message
Old 08-31-2008, 06:53 PM   #10 (permalink)
RUB wanna be
mungo wants to know Dino or Syn?
May I ask why you're interested in 95" without head work?
If it's budget, then what I'd do is find a set of '06 heads (used, so they are already heat cycled), send them out to be CNC ported and pop them on your 88". You'll see some pretty nice performance gains from that. When when your 88" jugs wear out, slap in some 95" jugs.
If you do it piece by piece, yeah, you're going to pay more. But then, financing a bike 'causes you to pay more as well. Sometimes piece by piece is the only way some can do it. (It's one of the reasons my bike is still stock and will most likely remain so for a while.)
Look into it. Ask around. This is what I'd do.
--m
2004 Night Train
2009 Street Glide
mungo is offline   Reply With Quote Quick reply to this message
Old 08-31-2008, 07:44 PM   #11 (permalink)
Average Dude
YankeeBob's Avatar
YankeeBob is reading this now saying WTF is this?
Originally Posted by Mbluz View Post
Is it worth it?
No. Not without headwork.
Deut. 23:12-13
YankeeBob is offline   Reply With Quote Quick reply to this message
Old 08-31-2008, 07:47 PM   #12 (permalink)
No, not at all. There is a natural boost in compression, you have more volume being displaced into the same area, this is the natural boost. if you do the math and shave the heads to make the chamber smaller, that brings up the compression. Different cams work better with a little more compression. if you wish to go to higher compression with thw 88", the heads would have to be shaved too much to be practical, so you would need to use domed pistons(popups) to make more compression. Flattops with an .030 should be around 9.4:1 or 9.5:1 with stock heads on a 95 or 98in.
43%er
HQ575 cams
.030 head gasket
"43" points cover
TRW rear mount
Old 09-01-2008, 04:33 AM   #13 (permalink)
FTF
hrdtail78's Avatar
hrdtail78 wants to know Dino or Syn?
Well worth the effort. I currently have two bikes I have ridden as 88's that are now 95's. A fast reving 95 will outrun a slow reving 103 all day long. 1/8 on the bore is a good start.
09 FLHX 120r WFO Larry's heads, 662-2, X series TH 2-1 136/136
127 evo. Hardtail 05 special construction. Hyperformance jugs, R&R billet heads, RB Racing 124 challenge pipe. 148tq. 139hp.
99 FXDWG, 103 in. Dave Mackie heads, Kury 57, DM598G, under construction.
hrdtail78 is offline   Reply With Quote Quick reply to this message
