S&s 107 Question : V-Twin Forum: Harley Davidson Forums
Old 07-30-2008, 11:47 PM   #1 (permalink)
8UP
jakace's Avatar
jakace wants to know Dino or Syn?
S&s 107 Question
Anyone know the specs of a stock S&S 107. I'd like to know the approx. HP/TQ. I'm also not sure if the motor in question is a Super Stock or a sidewinder. Help me out, if ya don't mind.
2001 flstf yellow chrome
95cuber
SE perf.heads mcr
95 hc forged pistons 10.5/1
SS 510g cams
SE billet cam plate/oil pump
SE adj. push rods
SE race ignition/coil
SPEEDS plugwires/Autolite platinum plugs
SE clutch spring
SE bigbore intake/hsr 45 Mikuni with Ness BS
Vance&Hines BSS
Did I mention CHROME!!??
jakace is offline   Reply With Quote Quick reply to this message
Old 07-31-2008, 05:37 AM   #2 (permalink)
S&s 107"
S&S 107" powerplants usually will show 102-105 hp and 110-113 ft/lbs., from what we have seen.
Smooth configuration, and much more on tap if heads/cam/carb mods are addressed.
Old 07-31-2008, 03:45 PM   #3 (permalink)
8UP
jakace's Avatar
Hey, thanx for your feed back. I appreciate it.
95cuber
SE perf.heads mcr
SS 510g cams
SE adj. push rods
SE clutch spring
Vance&Hines BSS
Old 04-28-2009, 11:38 PM   #4 (permalink)
1M$man wants to know Dino or Syn?
What is a high figure for this engine? On pump gas with extensive head work (or a swap to worked over heads), modest left cam, say .625 and a good flowing carb like the PSI Genesis?
I reckon about 125HP/130 TQ?
1M$man is offline   Reply With Quote Quick reply to this message
Old 04-29-2009, 06:37 AM   #5 (permalink)
compressor#v wants to know Dino or Syn?
S&S 107's are Evolution based engines.
They make a kit that will take your TC to 106", but they are not very popular a/c the short skirts on the pistons.
compressor#v is offline   Reply With Quote Quick reply to this message
Old 04-29-2009, 09:02 AM   #6 (permalink)
route66paul's Avatar
S&S build their engines for performance and realibilaty. They already have head work, a decent cam and a good flowing carb. They have done a lot of testing on their product, why would you second guess them?
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 04-29-2009, 09:09 AM   #7 (permalink)
We installed there v 107 touring engine into a early bagger. Runs good but not huge power by any means. The new V 107T is only 9.5 with a 585 cam. Made just shy of 100/100. huge increase over the stock 80 incher he had though LOL
Another crate we did for a 97 RK was a 113. bub 7 dual exhaust made 102 hp and 116 tq.
A 96 EPA crate engine landed at 76/93. These are in stock form. with out any engine modes other than tuning the carb. Ign was left un touched due to warranty.
Old 04-29-2009, 09:46 AM   #8 (permalink)
strokerjlk's Avatar
they are not popular?? not sure what build you base that statement on
they have only been realeased for a month or so. all the S&S dealers I have talked to are not even able to get them yet!
as far as the skirts they are no shorter than the stock 96 ci that I took out. they are weisco pistons .030 less than the 107 pistons every one is using in there 107 builds. As far as I know I am one of the first to install the kit.
I can tell you the clys are very heavy much more than stock clys. the liners are as thick as a stock cly before boring.
they are very well engineered with zero deck height.
07 ULTRA
AMRA
SE 218
DR 218
Old 04-29-2009, 06:14 PM   #9 (permalink)
Well I base it on the fact that your the only guy I know who frequents this site with one. Do a poll. Hear about many 103, 107, 117 etc. And the S&S 106" kit has been out for years. S&S does make good stuff, but over the years a few of their parts have had issues, although they stand behind them, or did. The 106 piston isn't the first either. In the middle 1980's the pistons from their 86" Shovel kit for a while (made by TRW IIRC) had short skirts and they were soft. 3000mi and worn out. I know, went through 2 sets, 3rd set, installed and sold the bike.
Old 04-29-2009, 08:32 PM   #10 (permalink)
strokerjlk's Avatar
they are brand new to the market is why I am the only one running it.
twin cam 106 4 3/8X 3.927 with wiseco pistons were just released. do some more research. They actually say 107 standard on the box
this is NOT the 106 4 1/2 x 3 7/8 kit
Evo kits have been around a long time.
Every S&S dealer I have talked to are waiting for them because the are new just released. The wiseco piston skirt in these kits are no diff than the wiseco 107 kits they are just .030 smaller dia. than those used in 107 kits. one dealer I talked to said that the wiseco 107 pistons could be used if at some point you want to freshen up . Bore .030 over. as far as I know there is only a .005 over piston available for the 107 or 98 bore.
The liner is the same as a stock 88-96 ci so no worry of heat issues on a bagger with lowers. This was the concern I had with the 107 ci because it is very thin when ya bore stock clys . I know a lot of guys are running them. I just thought they might be a little thin for my riding tank to tank all day and all night.
EDIT should have said .011 smaller bore than other 107's..
S&S =3.927 Hillside 107 =3.938
07 ULTRA
AMRA
SE 218
DR 218
Old 04-29-2009, 09:52 PM   #11 (permalink)
ndmp40 wants to know Dino or Syn?
The 106 you are referring to is not the same as the new 106 jug and piston kit for the 96's. The one you mention is a stroker crank kit for an 88. You are mistaken.
ndmp40 is offline   Reply With Quote Quick reply to this message
Old 04-30-2009, 05:36 AM   #12 (permalink)
S&S, as many outfits, will leak it out to the market that they have a new product.
Then they see what reponses they get, prior to pulling full-blown production runs of that product. That is why they are unavailable.
BTW, a worked-over S&S or our 107" kits we offer, will show 120-125 hp, and 125-130 ft lbs, street driven.
Scott
Old 04-30-2009, 06:13 AM   #13 (permalink)
strokerjlk's Avatar
Scott
What clutches do you recommend for your 107's ?
as expected the stock setup wont hold the tq.
I have always used Barnett in the past.
but there are a lot of choices out there now. Kevlar? carbon?
I dont really want to spend the kind of money it takes to set up the VPC. Just thought I would go with GOOD CLUTCH and heaver spring.
I just ordered the 49 tooth clutch gear and will swap clutches when I install it.
07 ULTRA
AMRA
SE 218
DR 218
Old 04-30-2009, 06:31 AM   #14 (permalink)
OK, so theres 2 106" kits available. I was referring to one (early TWIN CAM) and strokerjlk the other.
Old 04-30-2009, 07:34 AM   #15 (permalink)
The VPC seems to be the most inexpensive way to get a grip on that power.
Scott
