Low Idle, IAC Plugged? : V-Twin Forum: Harley Davidson Forums
Old 07-21-2008, 08:48 AM   #1 (permalink)
lostdutchman wants to know Dino or Syn?
For what it's worth, my '03 RK Classic has been having trouble maintaining idle speed for a few months now. She's got 43,000 on the odometer. It'll idle real slow after it's warmed up, then jump back to 1050 rpm's or so, then next time you roll to a stop, chug chug again. I tried re-programming the ECM with a higher idle speed to try and fix this. The other day, I thought maybe the IAC was not working right, but per other posts on this forum, took the air filter off and cycled the ignition switch. I could see the IAC doo dad moving back and forth. Thought I'd try to spray some carb cleaner up in there in the idle air passage. Tons of black crap came flooding out of the passage. Now, I don't know if carb cleaner is good for everything in there, but just like that, the idle is perfect. Went for a long ride yesterday, and at every light and stop sign, she settled in right at 1096 and stayed there. I re-programmed the idle speed at 1000, and this morning coming to work, she stayed right there. Just thought I'd pass it on to anyone who might be having this problem. Youz EFI experts out there, was this the right thing to do?
lostdutchman is offline   Reply With Quote Quick reply to this message
Old 07-22-2008, 04:36 PM   #2 (permalink)
Senior Chief
mattjc247 wants to know Dino or Syn?
rough idle
Tell me more, I have a 2004 RK with 32,000 and it idles rough. Temperature does not seem to be a variant. I replaced the fuel filter and it pulls better but still idles wierd, not like it used to. I have had two dealers tell me it works sweet.
Did you spray the carb cleaner in with engine off, at idle, high idle??? I wouldn't mind giving it a try.
Senior Chief
mattjc247 is offline   Reply With Quote Quick reply to this message
Old 07-23-2008, 09:07 AM   #3 (permalink)
Senior Chief
I pulled the air filter. If you look up into the top side of the throttle body opening, just outside the throttle plate, there's a hole, about 3/8" diameter. If you look up into the hole, there's a "doo dad" in there. Thats the Idle Air Control valve, which controls idle speed, like an idle speed screw on a carbed engine. If you turn the ignition switch on with the kill switch on, then off again, the "doo dad" will cycle open and closed. With everything turned off, I sprayed the cleaner into the hole with the small tube attached to the nozzle of the can, to get pressure into the hole. Lots of crap was flushed out, probably also into the intake manifold. I put a towel under the throttle body to keep the cleaner off the engine.Then re-installed the filter to lessen the chance of backfire setting my garage on fire. Then I cranked her up. She didn't want to start that well, must be carb cleaner and carbon don't burn well. Repeated this process twice more, then called it good. Good luck, hope this fixes your problem. I ride to work every day, and to lunch. This really seems to have fixed my issue.
Old 07-23-2008, 01:21 PM   #4 (permalink)
AirGlider's Avatar
AirGlider wants to know Dino or Syn?
Dutch
The IAC has been know to gum up. Cleaning with carb / fuel injection cleaner is just the ticket. Ride on.
AG
'04 Blue Ultra
DTT TCFI IID
95" Bored Cylinders & Cast Flat Top Pistons
Supertrapp Supermeg 2/1- 18 discs
Woods TW 6G
Big Boyz Heads (10:1cr) 77cc chambers
H-D Reduced Effort Clutch
Garmin 2720
Baisley Spring
Loud Lights SAVE Lives!
AirGlider is offline   Reply With Quote Quick reply to this message
Old 07-26-2008, 12:04 PM   #5 (permalink)
Senior Chief
U reeeekk Ahhh!!!!!!!!!!!!!
Duthcman, thanks for the tip. Followed the simple instructions to the tee. Can't believe that for years I have been spraying auto fuel systems and dumping cleaner in the tank and have avoided doing the same to my MC. Did I think the engine was something mystical, oh yea by the way, it is internal combustion.
Anyhow, watched the"doo dad" cycle a few times and then sprayed it opened and closed. Enough juice came out black that I knew we were on to a new concept. A clean fuel system. Sprayed the inside of the body and throttle plate (be mindfull of what happens to direct spray out of a tube when it hits, it comes back in your kisser, keep at arms length). Started a little hard as expected and then I sprayed a quick shot through the idle circuit while at idle.
Test ride indicated a 98.9 % smoother idle.
How simple??
Thanks, Senior Chief
Old 07-26-2008, 01:28 PM   #6 (permalink)
03GLIDE_'s Avatar
03GLIDE_ wants to know Dino or Syn?
I did the exact same thing a few years back. And the samr black crap came out.
03GLIDE_ is offline   Reply With Quote Quick reply to this message
Old 09-09-2008, 10:18 AM   #7 (permalink)
Lefty's Avatar
Lefty is still riding a stock bike Lefty is still riding a stock bike Lefty is still riding a stock bike
Yet another VTF money saving thread for me. Simply searched rough idle and this thread popped up. Went to Auto Zone for a $2 can of throttle body cleaner. Followed directions as indicated in the posts. Voila, no more low idle/rough running.
Lefty
Lefty is offline   Reply With Quote Quick reply to this message
Old 09-09-2008, 01:03 PM   #8 (permalink)
Mikie wants to know Dino or Syn?
Great solution
I've been chasing the intermittent low idle when hot problem for a couple years and finally gave up. When I read your post I thought "What the hell, I'll give it a shot." Sprayed brake clean in the idle air intake hole and like you, a bunch of crap came out. Did 4 spray, wipe, ignition on-off cycles until the liquid that puked out was clear. (Spray the brake cleaner in the hole, cycle the ignition. When you turn the ignition off, the plunger actuates and expels some of the brake cleaner.) Started hard afterward, but idled a lot smoother and best of all, idle is always stable at around 1,000. Good catch lostdutchman.
Mikie is offline   Reply With Quote Quick reply to this message
Old 09-10-2008, 06:33 AM   #9 (permalink)
RK05's Avatar
RK05 wants to know Dino or Syn?
Pics are worth a 1000 words!
I was looking around for that little booger and couldn't see it.
05' FLHRI
95", 9.8:1 W/Heads by BigBoyz, 37G's, Arlen Ness A/C, PC USB, Supertrapp Supermeg 10-disc open cap
RK05 is offline   Reply With Quote Quick reply to this message
Old 12-19-2008, 06:37 PM   #10 (permalink)
Volsung wants to know Dino or Syn?
Doo Dad is spelled P-I-N-T-L-E.
Volsung is offline   Reply With Quote Quick reply to this message
Old 05-13-2009, 07:20 PM   #11 (permalink)
Broken Spoke's Avatar
Broken Spoke wants to know Dino or Syn?
Four shots of cleaner did the trick for me. RPM's now sitting on 1050
Thanks,
Dutchman
Now, smok'em till they melt!!
Broken Spoke is offline   Reply With Quote Quick reply to this message
Old 05-13-2009, 10:46 PM   #12 (permalink)
ViennaHog wants to know Dino or Syn?
Doo dads, whatchjamakallits, and doohickeys are perfectly understandable technical terms.
Don't be picky around here................
Are you are real biker?
ViennaHog is online now   Reply With Quote Quick reply to this message
Old 05-14-2009, 02:04 PM   #13 (permalink)
billzbubba's Avatar
billzbubba wants to know Dino or Syn?
Now this is the kinda thread I come here for,not the"I know more than you" guys that reply to questions on here & try to make everybody else look like dumbasses,posers,non-bikeres,rubs etc.
THANK YOU!!!
2006 flhrsi
road king custom
black cherry
se a/c
pcIII
hardkhrome t rex duals
Alloy Arts 17" stripper apes
Progressive 412HD's
Progressive Monotube fork kit
Gator Boxes stretched saddlebags w/fender cover
2014 Street Glide Special
Vivid Black w/custom orange pinstriping (Other Side Customs)
Arlen Ness Inverted Series A/C
Rinehart extreme 4" true duals
Power Commander V
Bad Dad stretched saddlebags w/LED speaker lids
Bad Dad Summit rear fender w/957 surface lights
billzbubba is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 06:49 AM   #14 (permalink)
SAFXDL's Avatar
SAFXDL is reading this now saying WTF is this?
Will this also work with the older MM EFI's??
They call me Al....Big Al
Proud Parent of a Son serving his country
'08 FLHPI, 103, SERT, Fatcat 2/1 Black, Reckless Fairing w/tunes.
SAFXDL is offline   Reply With Quote Quick reply to this message
Old 05-16-2009, 02:56 PM   #15 (permalink)
Premium octane member
TXCHOP's Avatar
Al, no the MM Efi does not have the pintle hole. They just have the IAC motor with a lever attached to the blade...They do have a warm idle reset procedure though.
S&S T124
