Screamin Eagle Cam Plate and Oil Pump : V-Twin Forum: Harley Davidson Forums
Old 05-30-2008, 10:00 AM   #1 (permalink)
aldean's Avatar
aldean wants to know Dino or Syn?
I have a 99 Road King at a shop having a GMR 107 kit with the RR615 cam being installed. I had them order and install the Screamin Eagle cam plate and high volume oil pump part # 25283-07. They called me and said the oil pump didn't work. They said they replaced the oil pump again and that one didn't work either. They said they went ahead and installed the oil pump with the one that the owner uses in his bikes which is the same price. So that tells me they didn't go with a feuling oil pump. Are there other oil pumps that still have the high volume? Could they have been doing something wrong with the install? I'm concerned now....Any input will be greatly appreciated.
aldean is offline   Reply With Quote Quick reply to this message
Old 05-30-2008, 10:58 AM   #2 (permalink)
Fastest Chkn N the South!
Colonel Sanders's Avatar
Colonel Sanders wants to know Dino or Syn?
If I'm not mistaken, the SE plate is only for the new style pump. Is that the new style pump?
I'm running the SE plate and new style HD pump in my 124" and it's working just fine.
'01 Deuce
GMR 124"
4.125" x 4.625"
CV51 carb/intake/AC
R&R Stage IV heads
10.8:1 CR
JE -10cc pistons
S&S 640 cams
Axtell cylinders
JIMS/Darkhorse crank
Rivera Pro Clutch
DTT ignition
Hooker Troublemaker pipes
137/134 STD 134/130 SAE
Colonel Sanders is offline   Reply With Quote Quick reply to this message
Old 05-30-2008, 11:13 AM   #3 (permalink)
aldean's Avatar
It's the kit # 25283-07
This is a complete kit. Unless they tried to piece it together to save money and charge me the kit price. I will find out. Thanks.
Old 05-30-2008, 11:15 AM   #4 (permalink)
Premium octane member
TXCHOP's Avatar
I am running it in my build as well. No problems here. I did hear of one instance where it was sumping though.
Wonder what brand they gave you?
S&S T124
Old 05-30-2008, 12:35 PM   #5 (permalink)
aldean's Avatar
???Oil Pump
I will post the info as soon as I know. This one of those wish I would have went to RC Cycles!
Old 05-30-2008, 12:46 PM   #6 (permalink)
Mtclassic wants to know Dino or Syn?
I have over 4000 miles on my SE camplate/oil pump with no problems. I wonder if they assembled the gerators wrong.
Mtclassic is offline   Reply With Quote Quick reply to this message
Old 05-30-2008, 01:44 PM   #7 (permalink)
aldean's Avatar
Cam plate is the issue
Steve at GMR called the shop to find out what was up. The problem was the oil pressure was low at hot idle. It was determined that the problem was the SE cam plate and not the oil pump. Well I have learned a lesson here. Next time I decide on doing major work, I will load my bike on a trailor and take it to Steve. I wouldn't think twice about driving the 735 mile to have him do the work. He has gone out of his way to help me with this build. Thanks Steve for all your help.
Old 05-30-2008, 04:30 PM   #8 (permalink)
What was the issue with the cam plate?
Old 05-30-2008, 06:59 PM   #9 (permalink)
aldean's Avatar
Cam Plate problem
It turns out that the holes were too big on the cam plate oil passages causing the pressure to be low. Plenty of volume but not the expected oil pressure.
Old 05-30-2008, 11:41 PM   #10 (permalink)
cts1950 wants to know Dino or Syn?
I have a 1999 that is a 103 now. I ran into this issue and have talked with others with 99 engines. THESE ENGINES ARE NOT A (A )OR B MODEL THAT CAME OUT IN 2000. The original twin cam is missing a boss on the engine case that closes a port that was used on the B model for the balance shaft lube. The A model has the same boss but serves as a plug only. The oil passage on the back of the new style cam plate SE Fueling or Delkron must be plugged to keep the oil from short circuiting back into the cam case it can not build oil pressure. This is a issue not talked about with the instruction sheet for the SE HV oil pump and cam-plate combo kit but there is a HD kit to plug this hole. This is a 1999 issue only. This has been discussed at length on this forum on this link there is alot of info there.
http://www.v-twinforum.com/forums/v-...help-help.html
cts1950 is offline   Reply With Quote Quick reply to this message
Old 10-03-2012, 11:27 PM   #11 (permalink)
bikepsych wants to know Dino or Syn?
I just had the SE Cam Plate and oil pump installed. Today as I was heading in to work, I glanced down at the oil pressure and it was sitting around 50psi. Is this a problem? Usually it hung out around 32psi. Not sure what the relief valve is set at. I thought the oil pump was to be high volume vice high pressure. Although depending on the size of the oil galleys and passages its possible that the pressure has increased. I just hope that there is no blockage prior to the relief valve that is causing this increase.
BG
bikepsych is offline   Reply With Quote Quick reply to this message
Old 10-04-2012, 07:12 AM   #12 (permalink)
webco2 wants to know Dino or Syn?
I'll bet they did not plug off the unused oil gallery .
webco2 is offline   Reply With Quote Quick reply to this message
Old 10-04-2012, 07:15 AM   #13 (permalink)
BG
50psi is normal with 20w50 oil. It'll drop to around 35psi when it's heated up to operating temp.
