S&S 510 Gear drive cams : V-Twin Forum: Harley Davidson Forums
Old 01-15-2008, 05:24 PM   #1 (permalink)
ANOTHER DAMN YANKEE
sportyguy69's Avatar
sportyguy69 wants to know Dino or Syn?
Ok I have done a bunch of searches on this, done my homework and read all kinds of threads. But nothing can answer my question. My local dealer has a winter service special going till the end of Feb. They quoted me S&S 510 gear drive cams with adjustable pushrods installed out the door price of $1260.00 with a free dyno tune and printout. I have a 2001 FXSTI with S/E air cleaner, Stage 1 download, Vance and Hines straight shots,and PC 111 USB. I dont do much 2 up riding and dont really go touring for long rides. What I am wondering is this cam setup going to make me say holy *#^! when I twist it. I have a stock twin cam 88. Is this going to be a good performance upgrade?
2002 Fatboy
S/E A/C
Vance Hines Bigshots Staggered
if ur goin to do somethin give it all ya got, might be the last time you do it !!
sportyguy69 is offline   Reply With Quote Quick reply to this message
Old 01-15-2008, 05:41 PM   #2 (permalink)
I paid.........did you??
MaineUltraClassic's Avatar
MaineUltraClassic wants to know Dino or Syn?
At that price..........the dyno run is far from free.
Cams are about $500 for the complete setup
Pushrods are $150 at the dealer
Add in a cam cover gasket for $10...........and your total parts around about $660.......so they are charging you $600 for labor and dyno tune. Labor for the swap is about 3-4 hours.
I did my entire motor work last year for $1500 in parts........that was 95", Big Boyz Heads, HQ-0034G cams, pushrods, gaskets, and SE clutch spring. I did all the work myself, and had it tuned in the end for $300.
In a stock 88", by just changing the cams.........you are not going to get a whole lot of power. It will run better, and you will gain a little bit.......but nothing to shock you.
Steve
95" Powered by Big Boyz Heads, Woods Cams, Doherty PowerPacc w/ Powervents,
10:1 CR, D&D Fatcat 2-1 QB, Hillside 46.5mm TB, & Cometic Gaskets
Built by Me, Tuned by Bean
MaineUltraClassic is offline   Reply With Quote Quick reply to this message
Old 01-15-2008, 05:43 PM   #3 (permalink)
Lefty's Avatar
Lefty is still riding a stock bike Lefty is still riding a stock bike Lefty is still riding a stock bike
I just had the S&S 510s installed in my '05 Fatboy, and no, there is no "wow" factor, but there is a noticeable torque increase at lower rpms in 4th and 5th, probably when hammering it also, but since I don't do that I wouldn't know. I'm happy with the upgrade. BTW, I paid an indy $900 for the same job (have same set-up as you w/big shots rather than straight shots) w/o dyno tune. I thought I'd get a tune if I felt I needed it. But by reducing (yes reducing!) fuel by 2% at all RPM the minor popping on decel (as in full off throttle in 3rd at 60 mph) disappeared and my plugs are tan and oil temp at 205 degrees in 50 degree weather. Your pipes will be louder, be ready for that! I think I need some quiet baffles.
Lefty
Lefty is offline   Reply With Quote Quick reply to this message
Old 01-15-2008, 06:00 PM   #4 (permalink)
route66paul's Avatar
I would bet that they are not doing a complete dyno tune, just downloading a map and checking it on a dyno (to make you feel likeyou have a lot more HP) For a stock 88, put a set of andrews 26 chain cams in and go have it dynoed at a place that does a real dyno, either a SERT or a PCIII. Make sure to check the tensioners and replace if needed.
You will save money if you do it yourself and pull the valve covers so that you can reuse the pushrods.
That cam and a few others will give you the most on a otherwise stock 88"
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 01-15-2008, 06:43 PM   #5 (permalink)
ANOTHER DAMN YANKEE
they also quoted me a price of $980.00 for SE211 cams installed. I`m just looking for a good cam to install with the hopes of someday maybe going to 95".
2002 Fatboy
S/E A/C
Old 01-15-2008, 11:51 PM   #6 (permalink)
BFB
BFB wants to know Dino or Syn?
I'm looking at the same change. The going rate in CO seems to be $1200 with most offering 10% off either labor or parts. I tried two indies and the local dealer. I was disappointed in the price differences, in that there really wasn't any.
The parts run around $800, that's cams ($295), S&S 4 gear set ($435), gaskets, oil, etc add another $50. Add $100 if you want adjustable pushrods. Prices from J&P Cycles catalog 'cause I have it next to my computer. Lots of places to get them cheaper I'm sure.
As to the 510 cam, my research indicates it doesn't kick in until around 3K rpm. The majority of my riding is under that. I've read a number of posts that say the 510 will be rough at rpms under 3K. I'm looking at the Andrews 21G. If you're planning a big bore later then the 26G seems to be the recommended solution.
I've just about got the finance officer convinced. I just need to pick my wrench and pull the trigger.
-Bill
BFB is offline   Reply With Quote Quick reply to this message
Old 01-16-2008, 12:01 AM   #7 (permalink)
Longtime Asphalt Cowboy
Texan's Avatar
Texan wants to know Dino or Syn?
Originally Posted by Lefty View Post
.....there is no "wow" factor, but there is a noticeable torque increase at lower rpms in 4th and 5th, probably when hammering it also, but since I don't do that I wouldn't know.....
Agree on the "no wow" factor on the S&S 510. I did the same cam a year ago and just recently did a 95" big bore. Still not getting the WoW !!! Have really been kicking around stepping up to a S&S 570 cam before steady riding season hits. If you look at the specs on the 510 they are just a tiny step up from stock.
o~\o
"Ya know I haven't been everywhere but it's on my bucket list"
Texan is offline   Reply With Quote Quick reply to this message
Old 01-16-2008, 03:25 PM   #8 (permalink)
ANOTHER DAMN YANKEE
These are the answers that I am looking for. Thanks to all. Pretty much sounds like the 510 might as well be a waste of my hard earned money. I`ll keep looking , I have heard alot of good things about the 26G.
2002 Fatboy
S/E A/C
Old 01-16-2008, 03:36 PM   #9 (permalink)
Y2K
Y2K wants to know Dino or Syn?
o~\o
Yeah,the 510 is a good cam for an otherwise stock 88" but stepping up to a 95" you could use more.
The 570's like a bit of a bump in compression and some flow work on the heads to really perform well.
I have SE 10.25 cast pistons and Baisley SS heads in mine with the 570G cams and there is definately some WOW! factor.!
105hp/110tq
Y2K is offline   Reply With Quote Quick reply to this message
Old 01-16-2008, 03:41 PM   #10 (permalink)
Y2K
IMHO it doesn't get you very far just changing cams unless you get some head work done also.
That's the secret to getting some real wow factor.
Old 01-16-2008, 04:40 PM   #11 (permalink)
Ironbutt
MilesToGo's Avatar
I did the 510 cam plus 95in at the same time and had moderate wow factory. Did heads and carb update the next year and big wow factor. I'd say whatever you are planning on doing save your money and do it all at once.
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
Old 01-16-2008, 07:42 PM   #12 (permalink)
zoomie67 wants to know Dino or Syn?
I bought my 2000 RG last year with the 510 cams already installed. It's got slip ons and a ness big sucker on it. Otherwise the bike is stock. I've got to say I'm not impressed with the cam at all. I'll definately be doing a 95" with higher comp and headwork haven't decided on the cam yet but leaning towards the R&R 525. I'm really only looking for around 100/100.
zoomie67 is offline   Reply With Quote Quick reply to this message
Old 01-16-2008, 08:00 PM   #13 (permalink)
Lefty's Avatar
I'm quite happy with my 510 cams because what I was looking for is enhanced reliability for the long haul, no replacing or breaking of chain tensioners. If you want performance, probably better go elsewhere.
Lefty
Old 01-16-2008, 11:12 PM   #14 (permalink)
Mo-Dog's Avatar
Mo-Dog wants to know Dino or Syn?
I've run both cams in my motor and the 570 had quite a bit more torque and it was down low. I was told that the 585 may have been a better choice when I had the 570s. Seriously consider some head work to get the air flow needed to get the cam to wkr for you...maybe one of the pro builders can speak to this...
"You are only young once but you can stay immature forever"
05' FLHRCI - Black Cherry Pearl - 117" build...125/125 SAE...DTFBY!...
Mo-Dog is offline   Reply With Quote Quick reply to this message
Old 01-17-2008, 04:09 AM   #15 (permalink)
Winter SUCKS
harleymike77's Avatar
harleymike77 wants to know Dino or Syn?
Yup........... I waited, and waited and waited. Finally was able to convince the wifey (this week) I needed the motor done - but headwork was of the utmost priorities. Without doing headwork, it's just not worth doing IMHO. Just my
2014 FLHTK - Ultra Limited 91.51 HP 106.72 TQ
Andrews 57h Cams/Timken bearings/SE Adjustable pushrods/2-1-2 Headpipe/SE Chisel Extreme Billet Air Cleaner/4" Rineharts/SEPST
Chrome front end/inner primary/Mirror Chrome Slicer Wheels with chrome rotors & calipers/LED Lighting/Braided lines/Corbin Dual Tour Saddle, TP and backrest/Premium Ride Hand-Adjustable Touring Shocks/Front Lowering Kit
harleymike77 is offline   Reply With Quote Quick reply to this message
