07 Inner primary bearing : V-Twin Forum: Harley Davidson Forums
Old 08-15-2007, 09:09 PM   #1 (permalink)
angelflights wants to know Dino or Syn?
I have heard of this bearing going out on the 07s, and that they are the reason for the shrill ,whineing out of the primary.
What causes the inner prim. bearing to go out.
angelflights is offline   Reply With Quote Quick reply to this message
Old 08-17-2007, 04:43 PM   #2 (permalink)
pittguy wants to know Dino or Syn?
Warped inner primary???Engine pulse shocks??Maybe the IDS kit will help this issue also
pittguy is offline   Reply With Quote Quick reply to this message
Old 08-17-2007, 06:35 PM   #3 (permalink)
Axe Man
BVBOB's Avatar
Really, is this even an issue, Havent heard of a single failure around here.
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
Old 08-17-2007, 10:21 PM   #4 (permalink)
TL
tlewis wants to know Dino or Syn?
Here's one. Can't remember the miles but it was early somewhere between 600 and 1400. Replaced IPB and entire gearset. All is well now.
2007 FLSTC
tlewis is offline   Reply With Quote Quick reply to this message
Old 08-18-2007, 12:02 AM   #5 (permalink)
Yes it is realy an issue bvboob, but just maybe not in your world.
How about the clutch hub bearing, ever have issues with that in your world?
Old 08-18-2007, 01:49 AM   #6 (permalink)
Axe Man
BVBOB's Avatar
Sorry if I offended you, didn't mean to, It's just that I hear about bad bearings, bad camplates etc. but I have yet to see someone document them and include a pic, not saying it can't happen but I think it is on a very small scale percentage wise. And btw,, I live in the real world where even the best engineered mechanical devices sometimes fail. Like a buddy of mine said, if it has tires or t i t s, sooner or later you are going to have trouble with it.
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
Old 08-20-2007, 10:36 AM   #7 (permalink)
Tires or ****
Now that is straight up, pen pal. On a side note, Ive been following the 525 cam talk. Still waiting on fulsacs feed back too.
Old 08-24-2007, 11:41 AM   #8 (permalink)
doggiedave's Avatar
doggiedave wants to know Dino or Syn?
I've got 11,000 miles on my 07' ultra with no bearing/ primary issues
doggiedave is offline   Reply With Quote Quick reply to this message
Old 08-28-2007, 10:28 PM   #9 (permalink)
Do the math, first !!
thedriver's Avatar
thedriver wants to know Dino or Syn?
other primary problems ??
are there any other problems in the 07 primary?? i've got 9k miles on my Ultra the last two time i changed primary oil it came out very nasty looking. 1k and 2k miles between last changes. it doesn't matter what kind of oil i use, it comes out nasty, and i'm hearing slight, but strange noises. any input ??/
thedriver is offline   Reply With Quote Quick reply to this message
Old 08-28-2007, 10:39 PM   #10 (permalink)
iclick's Avatar
iclick wants to know Dino or Syn?
The whining you hear is probably the auto chain tensioner, which is noisy at idle on my bike. Can't hear it much once underway. Same on my old '96 RK, on which I retrofitted this tensioner.
iclick is offline   Reply With Quote Quick reply to this message
Old 08-31-2007, 07:30 AM   #11 (permalink)
Bike at the dealer under warrentee, they are checking out the clutch, primary and transmission. They are being good to me.
So far they have told me the clutch is ok, the primary ok and thy think its a trans. bearing.
Keep you posted.
Old 08-31-2007, 08:16 AM   #12 (permalink)
bobsvic wants to know Dino or Syn?
after riding hard two up and loaded down, hauling 500 lb of trailer and cargo and finally getting almost thru sturgis there was a loud whine noise from the primary, sounded like a gear drive, the bike was very hot. after it cooled the whine was gone, i keep listening for it now. no answers here
bobsvic is offline   Reply With Quote Quick reply to this message
Old 09-10-2007, 06:51 AM   #13 (permalink)
It was a broken main gear bearing casing that broke. Dealer replaced under warrentee.
Primary belt whine still there.
IDS installed, less vibrations.
Old 09-10-2007, 08:00 AM   #14 (permalink)
Thread Ender
Pikeslayer's Avatar
My primary bearing went out at 5000 miles. If the noise goes away when you pull the clutch in in neutral, it's your primary bearing. Sometimes you have to blip the throttle to get the clutch plates free.
Dealer said they had a bad batch of bearings with improper heat treat. That could be smoke, though, I don't know.
2007 Street Glide
Old 09-11-2007, 08:14 AM   #15 (permalink)
lap
lap's Avatar
lap wants to know Dino or Syn?
So are you saying that it was part of the bearing that broke? The outer casing that contains the bearings? Not the transmission case? Sorry I'm being thick headed but I'm not clear on that statement.
Lex
lap is offline   Reply With Quote Quick reply to this message
