99 Road King Check Engine Light : V-Twin Forum: Harley Davidson Forums
Old 05-25-2007, 12:59 PM   #1 (permalink)
HKSkully's Avatar
HKSkully wants to know Dino or Syn?
Does anyone have the proceedure to manually pull diagnostic codes on the Marelli type of fuel injected 99 HD's?
It seems as though I read it somewhere but I can't remember now.
HKSkully is offline   Reply With Quote Quick reply to this message
Old 05-25-2007, 02:19 PM   #2 (permalink)
road_king's Avatar
road_king wants to know Dino or Syn?
Try reading this post.
road_king is offline   Reply With Quote Quick reply to this message
Old 05-25-2007, 02:48 PM   #3 (permalink)
HKSkully's Avatar
That's the one I was looking for. Thanks for the help. Coding 16 and 41. Battery + voltage (battery is extremely weak) and CKP sensor/circuit fault.
Will look towards pinpoint diagnostics on CKP and circuit.
Thanks RK Rider
Old 05-25-2007, 04:37 PM   #4 (permalink)
HKSkully's Avatar
MIL update
Code 16 was set due to loose battery terminal connections. Slow cranking fix as well.
Code 41 CKP, Disconnected harness connector below frame (below regulator) for inspection. was full of oil and gunk. Cleaned out terminals with brake cleaner, dried and re-connected.
Cleared out codes (disconnected battery for 2 minutes)
Road tested, no more MIL and no codes.
Old 05-25-2007, 04:51 PM   #5 (permalink)
2kflhr's Avatar
2kflhr wants to know Dino or Syn?
My bike has leaked at the terminal and left a single oil spot when parked when the engine oil is warm since it had about 6700 miles on it (44k now). The oil evidently wicks through the wire insulation from the case to this lowspot at the terminal connection. I figure it's the grommit and I'll replace it when I have to take the primary cover off.
"Good Judgment comes from Experience, some Experience comes from Bad Judgment"
"Significant problems cannot be resolved with the same level of intelligence that created them"
"My Glock is my American Express, I never leave home without it"
2kflhr is offline   Reply With Quote Quick reply to this message
Old 05-25-2007, 05:44 PM   #6 (permalink)
Fourcats's Avatar
Fourcats wants to know Dino or Syn?
Those are the only two codes that I have had. Its nice when the CE light lets you know somethings up...
Fourcats is offline   Reply With Quote Quick reply to this message
