R&R cast heads : V-Twin Forum: Harley Davidson Forums
Old 03-11-2007, 04:58 PM   #1 (permalink)
roadchaser wants to know Dino or Syn?
Smile R&R cast heads
Which chain drive cams will work best with the R&R cast heads?Going on an 07 fatboy.Have a D&D 2-1 fatcat exhaust(standard baffle) with s/e air filter and a thundermax auto tune. 07 vivid black fatboy.Wanted,arm stretching torque!!!!!
roadchaser is offline   Reply With Quote Quick reply to this message
Old 03-11-2007, 05:00 PM   #2 (permalink)
Average Dude
YankeeBob's Avatar
YankeeBob is reading this now saying WTF is this?
did you call R&R and ask them? That would be your best bet.
Deut. 23:12-13
YankeeBob is offline   Reply With Quote Quick reply to this message
Old 03-11-2007, 07:22 PM   #3 (permalink)
Bryan TTM wants to know Dino or Syn?
i know the 615/585 cams that GMR or RevPerf or even R&R probly'll work the best since Reggie Sr did em himself with those heads in mind...personally, i wouldnt try to reinvent the wheel in this case
Bryan TTM is offline   Reply With Quote Quick reply to this message
Old 03-11-2007, 07:59 PM   #4 (permalink)
Rdubu wants to know Dino or Syn?
You bought the best heads money could buy, why not ask the guys who built them??? and maybe even buy from them so you have access to their 2nd to none advice , Instead of trying to save a buck or two and buying things twice and or part by part from the cheapest guy because you fell for the smoke and mirrors trick that they can and will suck you into, just my 2 cents earned from experience
OttoTuned Jims 113" Smooth + Faster than a turtle on crack! or there about!
Rdubu is offline   Reply With Quote Quick reply to this message
Old 03-11-2007, 10:10 PM   #5 (permalink)
brassman's Avatar
brassman wants to know Dino or Syn?
Is the 615/585 cam GMR's or
R&R design?
brassman is offline   Reply With Quote Quick reply to this message
Old 03-11-2007, 10:30 PM   #6 (permalink)
Booggerbe's Avatar
Booggerbe wants to know Dino or Syn?
The 615/585 cams are reggies and Speeds @ speed performance. I would recommend you to talk with R&R or speeds and they can steer you right. Booggerbe
2006 SG 98" Hyperformanc/R&R/Axtell motor. 11.3 comp, remodified R&R billet heads, R&R cam plate, R&R 615/585 cams and gear drive. 1.675 Roller rockers, modified 07 oil pump, Reworked Hyperformance crankshaft, Axtell cylinders and pistons custom cnc by HyPerformance, Bob Wood Rebel carb, wood a/c, DTTT ign,Baker od 6 speed, Arnott air ride, pro-clutch, 3:37 gearing, 123.46hp / 119.01tq.
Booggerbe is offline   Reply With Quote Quick reply to this message
Old 03-12-2007, 11:55 AM   #7 (permalink)
Speed Addict
darktrainer's Avatar
darktrainer wants to know Dino or Syn?
Really? R&R cast heads are the best heads that money can buy? Dan Baisley might argue that one.
darktrainer is offline   Reply With Quote Quick reply to this message
Old 03-12-2007, 01:59 PM   #8 (permalink)
I'll wait for his arguement and not take your word on this one, as I'm sure you knew what I was getting at with the response I left
Old 03-12-2007, 02:47 PM   #9 (permalink)
Snap-on man
BIG MAN's Avatar
BIG MAN wants to know Dino or Syn?
I love my R&R heads and 615/585 cams, it is a great combo and runs very strong.
98 in GMR, 10.8.1, R&R CAST HEADS, 51MM HP INC THROTTLE BODY, 615/585 GEAR DRIVE CAMS, RINEHARTS, 3.37 GEAR, RIVERA PRO CLUTCH.WOODS AIR CLEANER. 125.4HP 115.8TQ
BIG MAN is offline   Reply With Quote Quick reply to this message
Old 03-12-2007, 03:24 PM   #10 (permalink)
dr dave wants to know Dino or Syn?
depends on the compression you will be running and the size of motor, etc.
i have a set of r&r cast heads on my stroker 106 and reggie actually recommended i use something more aggressive than his 615 585 cams. so you should really ask his advice based upon your engine build and desired riding style.
dr dave is offline   Reply With Quote Quick reply to this message
Old 03-13-2007, 11:25 AM   #11 (permalink)
FatboyNH wants to know Dino or Syn?
I have R&R's cast heads on my FatBoy. However, I have SS 625G gear cams instead of chain driven cams. Either way, R&R builds an awesome engine package. Could not be happier with it.
FatboyNH is offline   Reply With Quote Quick reply to this message
Old 03-13-2007, 01:47 PM   #12 (permalink)
Speed Addict
WTF are you trying to say here? Lassie was more coherent.
Old 03-13-2007, 02:31 PM   #13 (permalink)
KingofCubes's Avatar
KingofCubes wants to know Dino or Syn?
I believe Rdubu meant that you have two cylinder head porters here that are in a league all their own, I know Dan and Reggie personally. Neither of them would take offence or great pride in this exchange.
King Of Cubes
515-266-6381
www.kingofcubes.com
KingofCubes is offline   Reply With Quote Quick reply to this message
Old 03-13-2007, 02:37 PM   #14 (permalink)
AS far as i know Dan does not make a cast head, and I like Dan and his heads are great. But the cast head has a intake port that you would have a very hard time to reproduce on a stock casting. Not to mention the money invested to get there. We are a huge believer in the R&R cast head, we sell and install tons of them, Each and every time they are making numbers that are repeatable time and time again,
We use the cast head on everything from 95 inch to 155. It really is a great product for the money. If you are in the area drop by and check out his shop, you will be AMAZED!!!!!!!
Old 03-13-2007, 03:07 PM   #15 (permalink)
As I mentioned before, those two guys are in a league of their own, they are professionals, and neither would piss on the ground to mark their spot especially in a forum where we should be focusing on product for a specific application. Really if you want to see what they do, stop by their shops and then the real education will begin.
King Of Cubes
515-266-6381
www.kingofcubes.com
