Battery ground cable burning up?!? : V-Twin Forum: Harley Davidson Forums
Old 02-19-2007, 06:23 PM   #1 (permalink)
BrianK wants to know Dino or Syn?
Had the bike apart for a project, put the battery back in as last step and started it up. Saw smoke, investigated, and found that the very short ground cable from my battery to the frame was so hot it was melting its insulation. What the heck would cause that?!?
BrianK is offline   Reply With Quote Quick reply to this message
Old 02-19-2007, 06:29 PM   #2 (permalink)
SYCLONE wants to know Dino or Syn?
loose connection................
05 Screamin eagle E-glide
114" all bore motor
'08 Night Rod Special,
Tab exhaust,topless,Dobeck Fueler
Coast "wailea" hot tub
2 3hp pumps, 50 sq.ft. filter
42 trillium jets, LED lighting
420 gallons...seats 6
SYCLONE is offline   Reply With Quote Quick reply to this message
Old 02-19-2007, 06:37 PM   #3 (permalink)
Tightened up the cable connection to the battery, will try again. Thanks! Out of curiosity, why does a loose connection cause the cable to heat?
Old 02-19-2007, 06:44 PM   #4 (permalink)
Acquisitions
dynageno's Avatar
dynageno is reading this now saying WTF is this?
Let us know if that was it...
Back in Black
dynageno is offline   Reply With Quote Quick reply to this message
Old 02-19-2007, 06:49 PM   #5 (permalink)
Will do. I'll start 'er up in the AM and report. - Thanks again - BrianK
Old 02-19-2007, 06:56 PM   #6 (permalink)
Totenkopf is reading this now saying WTF is this?
Sorry if you know all of this but........
increased resistance for the current being passed will cause the overheating. Same reason aluminum to copper wiring don't play nice and cause house fires. High resistance joints due to oxidation.
E-I*R is Ohm's Law: Voltage equals current times resistance
P=I*E is Power equals current times voltage
substitution of E: P=I^2 * R (power equals the current squared times resistance)
As you can see, if resistance goes up, so does power. If it's high enough, it will melt the insulation.
Totenkopf is offline   Reply With Quote Quick reply to this message
Old 02-19-2007, 07:08 PM   #7 (permalink)
I learn so much here I should pay tuition! Thanks! - BrianK
Old 02-19-2007, 10:30 PM   #8 (permalink)
hivolt132's Avatar
hivolt132 wants to know Dino or Syn?
DO YOU KNOW THOSE SYMBOLS BY HEART OR DID YOU LOOK THEM UP?
YOU LAST FORMULA IS FOR CALCULATING POWER THATS LOST DUE TO RESISTANCE. NO REAL RELEVANCE HERE. ITS NOT ABOUT LOSING POWER ITS ABOUT FAULT CURRENT CREATING HEAT.
hivolt132 is offline   Reply With Quote Quick reply to this message
Old 02-20-2007, 06:16 AM   #9 (permalink)
No, this is completely relevant and it's a simple way of explaining about high resistance connections and the added power that is consummed when that happens. If you have a fixed current passing through a connection but resistance goes up, power consummed must go up. What happens when power goes up?? more heat is generated.
Oh and I've had Ohm's Law and related formulas memorized for a very long time. Kinda comes in handy.
Old 02-20-2007, 06:58 AM   #10 (permalink)
DEVILDOG's Avatar
DEVILDOG wants to know Dino or Syn?
Make sure you have no corrosion between the terminal and the frame, also use a star washer so the teeth get a good bite on the frame and terminal.
DEVILDOG
DEVILDOG is offline   Reply With Quote Quick reply to this message
Old 02-20-2007, 07:41 AM   #11 (permalink)
The star washer is the best,.. common issue for a poor ground on the baggers, as many times you would hear about sticky clutch cables. What was going on was the ground was poor and when the bike was started the c-cable was being used for a ground and melting the liner. The customer only knew that his clutch seemed hard to pull. I have seen the t-cables smoke as well. Not a pretty site. Clean the ground at frame, and battery.
Old 02-20-2007, 07:50 AM   #12 (permalink)
hivolt132's Avatar
o.k. sounds good. This stuff is interesting to me and wasnt trying to argue. Thats the way I was taught that formula. I work in the field of high voltage, mostly 13.2kv hot, and as I have always maintained I dont know everything not even close. BTW that formula PIE is for an AC circuit for DC its PEI. Some rocket scientist polly thought of this for easy ID. Now there is something that has no relevance at all. Still loose connection good to know.
Old 02-20-2007, 08:11 AM   #13 (permalink)
hdmarsh77 wants to know Dino or Syn?
I use 'Yooper' cables where he makes them from good welding cable with gold plated connectors. Plus the second ground is that big too instead of the little piece of crap from HD.
I don't know if it helps anything or not but it make me feel better!
'04 Brilliant Silver FLHRSI
hdmarsh77 is offline   Reply With Quote Quick reply to this message
Old 02-20-2007, 08:12 AM   #14 (permalink)
Holy crap! That sounds like trouble.
Old 02-20-2007, 09:31 AM   #15 (permalink)
understood, didn't take it as argumentative. So, just to be clear.....
Actually, P=IE or P=EI is the same mathmatically and is DC circuits. and if you prefer, P=VI or P=IV works too.
For reactive AC circuits, you have to take the relationship of the phase angle between the current and voltage into account. Simplistically, it looks something like P=V I cosΦ for average power in an AC circuit. As you mentioned, meaningless for the problem at hand.
