Dan Vance RacingProCharger.comOriginal Bike SpiritsMotorcycle.com Classifieds!Stainless Ride Specialty AccessoriesMotorcycle.comFuel MotoSportbikeTrackGear
Old 11-14-2006, 11:04 PM   #1 (permalink)
Craptacular
MFouts is on a distinguished road
Cam tensioner replacement
Helping a friend replace his cam chain tensioners on an 03 RKC. Any advice help would be greatly appreciated. Tools needed?? Have done a search and read most of the threads I could find but most were switching to gear driven cams.
He wants to replace tensioners only this time and next time go with the big bore and new cams, probably gear driven.
Marc
MFouts is offline   Reply With Quote
Old 11-14-2006, 11:38 PM   #2 (permalink)
Deeply Disturbed
gr8whyt's Avatar
gr8whyt is on a distinguished road
Just replacing the tensioners isn't too big of a job...certainly nothing tricky. Follow the manual.
There are a few specialty tools needed. For sure is a good tensioner unloader tool. George's Garage (look over on the right here) sells one for about $25.00 plus shipping. Most folks also change out the rear cam bearings for the Torrington bearings, but some rather expensive tools are required. Again available from George's garage, if you decide it's worth it. To change the secondary (inner) tensioner, the cams need to be pressed out and then back into the cam plate. Here you need the camshaft remover & installer tools, and access to a press. More $$$. And finally, when re-aligning the oil pump, a person should use some oil pump alignment pins. Plus lots of gaskets, o-rings, snap rings, bearings, etc. to replace. (got snap ring pliers?)
Crud, did I really buy all this stuff? I would have been WAY ahead to take it to a shop. For a few hours labor and materials, I would have saved some serious coin. But I like doing it myself. Knowudimean?
2004 FLSTCI - "White Owl"
gr8whyt is offline   Reply With Quote
Old 11-15-2006, 12:34 AM   #3 (permalink)
PosseRider is on a distinguished road
Shop will charge ya 4-500 ,at least ya got the tools for next time!!!
PosseRider is offline   Reply With Quote
Old 11-15-2006, 12:38 AM   #4 (permalink)
BLKROCKET is on a distinguished road
He wants to replace tensioners only this time and next time go with the big bore and new cams, probably gear driven.Take the cam plate out . Marc
You can take the cam plate out without using one special tool. I have done it many times. The two LITTLE tools I do recommend is the oil pump bolt liners which I bought on ebay for 35.00. then take the cam plate with the cams and have a Harley shop put the tenioners on for about 60.00. then you know its done right. then put it back in. You need a shop manual
BLK FLHX 06 114 REVOLUTION
REV SUPERCASTHEADS 2.1 INT 1.7 EX.,REV ROCKERS
MIST FREE ROCKER BREATHERS,10:8 COMPRESSION
TW8 CHAIN DRIVE, SE TB BORED TO 52.5
DTT II O2 ECM,HIGHT FIVE AC, D&D BORZILLA
ASSEMBLED IN MYGARAGE EXCEPT FOR S.B.
132hp 133 tQ 4th gear AT 5500 ft
BLKROCKET is offline   Reply With Quote
Old 11-15-2006, 01:58 AM   #5 (permalink)
I'm Paid Up...
Try this.. I did it last week. Use 2 Vise grips--one on each end of the spring, and tension it just enought to clear the chain in the rear. No special tools needed for the rear tensioner, and you won't need to remove the cams.. The front one is very easy.
DR_DEUCE is offline   Reply With Quote
Old 11-15-2006, 05:52 AM   #6 (permalink)
pedege is on a distinguished road
you can have a look at :
www.harleyhog.co.uk
www.knightrider.com
on both sites you'll find how to do it, even with pictures !
pedege is offline   Reply With Quote
Old 11-15-2006, 08:38 AM   #7 (permalink)
HDWRENCH's Avatar
We rent the tools to do the job you are getting into. We also support Georges if you are buying the tools. A service manual is a must, as is some blue and red loctite.
GMR PERFORMANCE
928-445-3473
TTS TUNING CENTER AND SALES
WWW.GMRPERFORMANCE.COM
Old 11-15-2006, 08:30 PM   #8 (permalink)
wcgrinder
Al Taylor is on a distinguished road
You can take an old 7/8 sockett and cut/grind 2 slots in it to fit down over the slipper spring.Use a ratchett to twist the slipper away from the chain.You can use a drill bit to slip through the retaining hole.(special tool #ou812) It may be difficult to remove the cam slipper under tension I never tryed.The primary slipper is no problem.I use 1-2-3 blocks all the time to replace cams but you can by the expensive stuff if you want.just be carefull.Shop manual is a real good idea.
Al Taylor is offline   Reply With Quote
Old 11-15-2006, 10:11 PM   #9 (permalink)
Craptacular
Thanks all
Old 11-27-2006, 06:32 PM   #10 (permalink)
poisoniv is on a distinguished road
do you have to cut the pushrods or will the liftres leak down enough to get the cams out and back in? i only want to replce the tensioners.
poisoniv is offline   Reply With Quote
Old 11-27-2006, 06:43 PM   #11 (permalink)
Pebble Cruncher
Rockbiter's Avatar
Rockbiter is on a distinguished road
Unless you cut the push rods and replace them with adjustables, you will need to pull the heads...push rods have to come out to pull the cam plate. I'd say its generaly easier to put in adjustables...but there are ways of removing the heads w/ exhaust and other "tricks" the dealership wrenches use...don't forget a new top end gasket set if you do pull the heads...
'04 TC103 FXD
SE 4.375" Stroker Crank
SE 3.875" Flat top Pistons
SE 211 cams
SE A/C
SE 2 Slip-Ons
SE 6200 RPM Ignition module
SE Clutch spring
White Bros E-Z clutch release
LMR2 oil pressure spring
Rockbiter is offline   Reply With Quote
Old 11-27-2006, 07:50 PM   #12 (permalink)
SYCLONE is on a distinguished road
the heads dont come off, just the rocker box covers, and the fuel tank.
05 Screamin eagle E-glide
114" all bore motor
'08 Night Rod Special,
Tab exhaust,topless,Dobeck Fueler
Coast "wailea" hot tub
2 3hp pumps, 50 sq.ft. filter
42 trillium jets, LED lighting
420 gallons...seats 6
SYCLONE is offline   Reply With Quote
Old 11-27-2006, 07:53 PM   #13 (permalink)
Deeply Disturbed
gr8whyt's Avatar
You don't need to pull the heads to get the pushrods out...only the rocker arm supports. But you're right, Rockbiter, cutting the pushrods and replacing with adjustables is much simpler.
Old 11-27-2006, 08:14 PM   #14 (permalink)
just what i thought... more money. someday that wont matter? THANKS for verifying what i thought was right. AND, is an ajustable push rod a push rod, dont want to buy them twice (recomdations). 23k miles and i am getting worried my time is up!
02 road king
Old 11-27-2006, 08:29 PM   #15 (permalink)
thrasher's Avatar
thrasher is on a distinguished road
02 road king
Yep, its more cash anyway you look at it.
I'd at least take your cam cover off and have a look at them anyway to see what kind of condition they're in. It'll keep you from guessing.
To me it makes more sense to get rid of the problem (cam chain tensioners) and go with a gear drive cams setup.
thrasher is offline   Reply With Quote
