Gap on NGK Iridium plugs : V-Twin Forum: Harley Davidson Forums
Old 08-07-2006, 06:36 AM   #1 (permalink)
klondike wants to know Dino or Syn?
Bought two of these plugs yesterday for my 01 EG. Just wanted to try something different. Noticed that the gap wasn't at .040". Matter of fact the gap was something like .030" or just slightly more. Whats the deal, is that the correct gap for these plugs or should I regap them to .040". thanks and keepem sharp
klondike is offline   Reply With Quote Quick reply to this message
Old 08-07-2006, 09:01 AM   #2 (permalink)
WildBill2566 wants to know Dino or Syn?
I use these plugs in my 04 train, 1mm gap. dont forget to use copper grease when you torque em down.
WildBill2566 is offline   Reply With Quote Quick reply to this message
Old 08-07-2006, 11:54 AM   #3 (permalink)
What's copper grease? Didn't use it. Didn't mention it on the box at all. These weren't gapped at 1mm but .030" or there abouts. I bent the electrode back to .040". keepem sharp
Old 08-07-2006, 12:04 PM   #4 (permalink)
tallyclassic wants to know Dino or Syn?
Where did you find the NGK Iridium's?? None of the autoparts stores, nor the metric dealers carry these. J&P doesn't either. Is part number DCPR7EIX the correct plug??
ALWAYS use copper antisieze on spark plugs!!
tallyclassic is offline   Reply With Quote Quick reply to this message
Old 08-07-2006, 12:55 PM   #5 (permalink)
Big O Dave wants to know Dino or Syn?
Here's where I get 'em: http://www.sparkplugs.com/
Stage I 95" FLHXI
Black Pearl
Big O Dave is offline   Reply With Quote Quick reply to this message
Old 08-07-2006, 01:38 PM   #6 (permalink)
FOG
trooper113's Avatar
trooper113 wants to know Dino or Syn?
NGK site says .040......
NGK IX iridium 6046 DCPR7EIX .040 TC88
T113
trooper113 is offline   Reply With Quote Quick reply to this message
Old 08-07-2006, 01:51 PM   #7 (permalink)
You don't say?
Duoglide_62 wants to know Dino or Syn?
Be very careful with how you gap them. You can break the tip as it is very fine. Be sure to use a ground strap tool to open the gap and light taps on a hard surface to close it. See the pic.
Deuce
01 Low Rider (now)
62 Duoglide (later)
Duoglide_62 is offline   Reply With Quote Quick reply to this message
Old 08-07-2006, 06:05 PM   #8 (permalink)
I didn't have a problem opening the gap when I took them back to show the vendor. I just used the little round gapper they had by the counter. But I made sure he knew they were't the correct gap even though his computer said they should be .040". I bought them at Parts Plus, I think that is the name of the store. I have also read that you shouldn't use any type of anti sieze on spark plugs as they already have it in the metal threads when the plugs are made. Read that on V twin cafe. Can't say I notice any difference in the bike on how it runs. keepem sharp
PS paid 6 bucks apiece for them.
Old 08-07-2006, 07:40 PM   #9 (permalink)
Sorry, 1mm is about 0.039", and copper grease is an anti seize, I've use it for over 25 years, if you dont use it there is a risk that the plugs will seize into the heads. Google it.
Old 08-07-2006, 07:48 PM   #10 (permalink)
FOG
trooper113's Avatar
Indeed....I broke the tip the first time I tried to open the gap on one.
T113
Old 08-07-2006, 09:43 PM   #11 (permalink)
boblaverty wants to know Dino or Syn?
I had to regap my new NGK's also. I have since gone to the ND Iridium U-groove plugs, they have a finer center electrode, and I noticed my bike starts easier and idles smoother. The NGK's only had a couple thousand miles on them, and they looked very good. I bought both from sparkplugs.com out of San Diego, CA. Yes, use a good anti-sieze on the threads, and replace them on a cold engine too. I also use a little bit of dielectric grease inside the plug wire terminals to eliminate corrosion, also good for the battery terminals and all electrical connectors, and it great on your boat trailer wiring! Also torque to proper specs.
boblaverty is offline   Reply With Quote Quick reply to this message
Old 08-08-2006, 06:01 AM   #12 (permalink)
Nearly forgot, if using anti seize or any lubricant on a thread where not specified use the lowest torque value stated as lubrication of any kind on a thread will have an effect on the co-efficient of friction between the male and female counterpart. What this means is that for any given torque value, you will be tightening the part more than specified.
I only found this out a short while ago and have never had any problems even with total engine rebuilds, but then I always used a middle value where a range of torque values was given. But as stated I now use the lower of the two given in a range.
