Old 05-21-2006, 10:21 PM   #1 (permalink)
aceman2101 is on a distinguished road
wild things 107 build
In the process of putting together this build, wild things forged heads 81cc combustion chamber
axtell 107 cylinders with flattop pistons 10.7 /1 static compression
mikuni hsr48 carb
wild things tc46g cam
has anyone seen any info on a wild thing build over 103"? any comments would be appreciated. Thanks ,Ace
aceman2101 is offline   Reply With Quote
Old 05-22-2006, 07:31 AM   #2 (permalink)
Ace, haven't seen any WT builds over 103, but yours should be awesome. I ran those cams in a 95" and really liked them, although they are better suited to your size motor. With the WT heads and WT26G cams in a 95", 120hp was achieved, so with proper tuning you should be in the zone along with great driveability. Let us know how it turns out.
Old 05-23-2006, 06:40 PM   #3 (permalink)
my only doubts about this build is,since I have to open the cases to bore them out would I be better served by stroking it to a 114 or a 117
Old 05-23-2006, 07:20 PM   #4 (permalink)
XLIII
MegaGlide's Avatar
MegaGlide is on a distinguished road
While it's apart, are you going to have the left crank bearing conversion done by someone?
Dave
I mock, therefore I am.
MegaGlide is offline   Reply With Quote
Old 05-23-2006, 09:26 PM   #5 (permalink)
Smile
mega,are you talking about the timken bearing?My bike is a 2001 roadking,should already be done
Old 05-23-2006, 09:51 PM   #6 (permalink)
XLIII
MegaGlide's Avatar
Well, duh.
ONE time I don't check a profile before I post...
Dave
Old 05-23-2006, 10:39 PM   #7 (permalink)
Incredible
Fatb0y's Avatar
Fatb0y is on a distinguished road
I would say yes. I would go ahead and stroke it. That will take it up to a 117CI. I didn't stroke mine last winter, but I also didn't remove the balancers since mine is a TC88B case. This winter I am going to remove the balancers and have a stroker crank shaved and balanced. By doing so I will basically have a balanced engine but without the extra weight, noise, and rev limiting balancers in the engine.
Fatb0y is offline   Reply With Quote
Old 05-24-2006, 09:37 AM   #8 (permalink)
Smile
fatboy at 10.8 / 1 how does your bike startup?What are the specs on that cam you are running,and what kind of tq and hp are you getting.I apologize for all the questions however Im trying to get all the info I can before I pull the trigger on this build
