AFR problem using Thunder Monster baffles
I did a baseline dyno run on my 95” build after having installed some Thunder Monster baffles in my V&H Bigshot staggered pipes. I must say I’m shocked & amazed at the AFR & the rich condition dip between about 2800-3800 RPMs. Not at all what I expected, reason being is that I don’t feel it in the seat of the pants.
My set-up: 95”, Dewey’s Pro-street heads, 37g gear drive cams, Wiseco flat-top pistons, 44cv carb re-worked by HDWrench, SE 6200 RPM ignition & the BSS pipes.
Posted are three dyno charts:
The 1st chart from Desert Custom Cycles was done in May. It shows 93.21 HP/ 99.62 TQ & a lean AFR with some rich condition dips at lower RPMs. Also written on it is the AFR at a couple different cruising speeds. This run was done w/ stock baffles & carb jetted with a 48 slow/200 main jets.
2nd chart was done at the another shop as we richened up the AFR by going to a 220 main jet & we tried to flatten out the rich cond. dips. Due to time constraints & such we weren’t able to finish addressing the rich cond. dips. We ended up w/ 95.6 HP/ 103.1 TQ.
3rd chart was done at Desert Custom again on Sept 1st. The blue lines are actually copies of the 1st run back in May. Everything is the same as the run at the other shop (2nd chart) except for the Thunder Monster baffles installed. You can see from the red lines (Sept. 1st run) that I lost a bit on TQ & gained a bit on HP (96.08 HP/ 101.71 TQ) with the TM baffles. Not that big of deal but the AFR rich cond. dips are at or below 10.
What I don’t understand is how I can have such severe rich cond. dips at full throttle but at the cruising speeds written on the 3rd chart I’m fine. Notice that at 45 MPH in 4th gear, which is about, 2500rpms my AFR is 14-14.3 & at 75 mph in 5th gear I’m at 13.5 AFR, right where I should be.
I called Big City Thunder & talked to Jim. He said his product is not the problem but that if there were any problems inherent in my build that using his baffles would tend to amplify those problems & make them more apparent. Alright, it does appear that what he’s saying has some truth to it since I already had rich dips & now with the TMs they’re even richer dips. He thought I was over carbed for my build, though Dewey & HDWrecnch both said the 44cv was a good carb for my build. He thought I should go with a 42mm carb or try a dynojet/Thunderslide kit.
What’s wierd is before I put in the TMs I could really feel my rich AFR dips & after putting in the TMs it feels much smoother & the bike still runs like a maniac. I have to admit the TMs definitiley wake these pipes up. They sound awesome.
Now after all that typing (whew!), any suggestions on how to get rid of those AFR rich dips? I could put back the stock baffles, but I’ve still got the AFR dips.
Why doesn’t Desert Customs #’s line up at the proper HP & TQ lines on the graph?
Any help is much appreciated.
Dave
"All that is necessary for evil to triumph is for good men to do nothing" Edmund Burke
"Those who will not be governed by God will be ruled by tyrants" William Penn
'02 WG Lowrider
95" Wiseco Flat-top pistons
Dewey's Pro-Street headwork
37G cams
DTT ignition
44CV Carb & 51mm a/c
Cycle Shack slip-ons
