Originally Posted by RamDude
I have a rocker box noise that I have been trying to get rid of and now it has taken a wierd twist. I had my SE pushrods adjusted to the recommended 2.5 turns and had a lifter noise when hot only in the front cylinder from 2000 to 2700 rpm. I readjusted another 1/4 turn and all was good for a while but then the noise was back. It would even do it at an idle but heres the kicker..... Lean it on the kick stand and all noise stops. Any ideas??? I'm gonna tear into it and would like some opinions before I do. Thanks
The front exhaust almost always make some noise. Mine ticks like crazy, but it's not hurting anything. Just adjust as per the instructions and leave it alone. If it's too loud, get louder pipes or earplugs. It's a Harley, not a Honda.
If it really bothers you that much, try some Lucas oil stabilizer, or their oil. I just started running Lucas synthetic oil in mine this week and the engine is a lot quieter, although not completely quiet. That's just not possible with an Evo.
