Custom DynamicsDan Vance RacingStainless Ride Specialty AccessoriesBikeBanditMotorcycle.comOriginal Bike Spirits
SportbikeTrackGear
Bike Bandit
Old 03-29-2005, 07:23 PM   #1 (permalink)
nighttrain67's Avatar
nighttrain67 is on a distinguished road
117 Dyno'd.....Finally
Finally got my 117 on the dyno last friday. Overall I am pretty satisfied with the results. Unfortunately, the smallest main jet I had for my SK505 was an .088. The motor was still a little rich so we removed the air cleaner to lean it out a bit. I think an .087, or .086 would have squeezed a little bit more. Maybe not. At the altitude here in Vegas, I am pretty happy with these numbers.
2002 FXSTB 117 ci
SE 103 Flywheels (re-Balanced)
"B" Motor (Balancers Removed)
SE CNC Heads reworked by Dan Baisley (2.100/1.625)
S&S Super "G" (1.800) intake Modified by Wes Brown
Baisley Rocker Arms/Geometry
Wood TW9FG Cams +2 deg. Adv.
Jims Hydrosolid Lifters/Baisley Pushrods
SK505 Carb
Wood 180 Springs/Retainers
Axtell 20 Degree Reverse Dish Pistons
Axtell Cylinders
Baker 6-Speed (R-Ratio, .80 overdrive)
Chain Final Drive (3.95 final ratio)
Rivera Brute III Primary Drive/Pro Clutch
DTT Ignition
Bassani Pro Street Pipes
nighttrain67 is offline   Reply With Quote
Old 03-29-2005, 07:30 PM   #2 (permalink)
I'd be happy with that build too! Nice job, have fun and be SAFE!
'04 Brilliant Silver FLHRSI
hdmarsh77 is online now   Reply With Quote
Old 03-29-2005, 08:16 PM   #3 (permalink)
Hardass
Lardog is on a distinguished road
140 lbs or torque and about the same HP?!? I'd bet you are happy... As long as you don't fall off the back.
Lardog is offline   Reply With Quote
Old 03-29-2005, 08:19 PM   #4 (permalink)
rubberdown is on a distinguished road
What kind of fuel mileage do you get with the build? Nice graph.
"The answer is blowing in the wind" B. Dylan
"Looking for a place to happen,
Making stops along the way". The Tragically Hip
04' Buell XB12S Red
rubberdown is offline   Reply With Quote
Old 03-29-2005, 08:28 PM   #5 (permalink)
I really have not paid attention to fuel mileage. For obvious reasons, it is not quite what it was with my 95" build. LOL
Old 03-30-2005, 12:33 AM   #6 (permalink)
yburgman1 is an unknown quantity at this point
.088 is too rich?
The reason I am asking is because I built my 95" with Dewey's Heads, 37g, 9.8-1 wisecos, D&D 2-1 Fatcat exhaust. I purchased one of the Woods 41.5 Carbs and it came with .089 main jet. I can feel my bike is too fat on the top end. So should I try going down to .088 or .087? Regards.
yburgman1 is offline   Reply With Quote
Old 03-30-2005, 08:08 AM   #7 (permalink)
I guess the best advice I can give you with jetting is to get it up on a dyno and see what the bike likes. My bike runs an extremely low main jet compared to most other 117 setups I have seen. Most are in the .093-.097 range. The only explanation Bob Wood could come up with was the conditions in the dyno room being lousy (humidity 50%, Alt. 27.83 in-hg). He told me to tune for the best numbers, not necessarily the perfect A/F ratio. That is what I did, and that is the main jet that made the best power on the motor.....and it still wanted one or two mains smaller with the aircleaner on.
Old 03-30-2005, 08:17 AM   #8 (permalink)
One other thing I should have mentioned. Bob does tend to set his carbs up a bit on the fat side for a saftey margin. Better a little on the fat side and let the customer tune it, than to send it too lean and have someone hurt a motor. You could try jetting it down a size or two on the main. Make small adjustments and pay attention to how the bike runs. Don't go too far or you could potentially hurt something if your heavy wristed. Certainly one or two jet sizes smaller should be fine for comparison to where you are now. That being said, the dyno is the best place to tune for final jetting, in my opinion.
