What harley says is ok, and what I consider ok is different. I bet what I say is ok, and what many others here say might differ too. Bottom line is these TC pumps can be gouged on the inside diameter of the pump body, and on the outside diameter of the gears, and be gouged on the face of the gears and work almost perfect. I say almost perfect because lets face it. If you have anything less than optimum tolerances some oil will escape the pumping and scanvenging process. But little wear and scratches wont affect your oil pressure at all. The biggest thing you want to watch for is assembly, make sure you realign properly and as Seahag said, put in new Orings.
Nostalgia
If its too loud
Your too old
