12-06-2004, 11:31 PM
Crane HI 4TC
Is anyone running cranes hi4tc? if so how much initial timing is safe for stock compression ? what about single spark or mulit-spark mode ? what # advance curve? and what about the rear cylinder offset? I have a 03 wide glide with 203 came SE air filter and slip fit mufflers. somebody out there must have already figured out the best combo.
12-06-2004, 11:47 PM
AIBAMC
Set the Mode to Multi spark, set the initial offset to 0, set the advance curve as high as you can go without ping and then as soon as it gets ping, set the inital to -1, if you still get ping go to -2 on the initial. Dont go above setting 8 though. 45+ degrees of advance is insane.
Do NOTHING with the rear cylinder offset, (set at 0) your build will get nothing out of it on the road even though a Dyno may show a hidden pony.
2002 FXDX / HI Comp TC-95, the WORKS
You can walk away with something gained from interactions with everyone you meet. Listen, be accepting, be open to new ideas and angles. Most of all, SHOW RESPECT!!!!! After this, if someone pi$$es in your cornflakes,,,, MAKE THEM eat every last one!!!
12-07-2004, 12:10 AM
See my thread on page 2. I have a HI 4TC on my 03 FXDWG and cant stop the pinging. I have decided to go with the S&S IST system. Everyone seems to think it will solve my problem. I done some mods as per my question.
Hope this helps
12-07-2004, 08:37 PM
AIBAMC
The IST system works VERY well on those builds that have a ping problem within the low range of RPM"S. Essentially what it does is automatically retard the timing when ping is detected until the ping has ceased. The same effect is achieved by using the initial offset to drop the entire advance curve DOWN however the S&S can and does automatically create a "valley" in the curve to address the ping and then give you back your agressive slope once the problem point has been passed.
The same end result CAN be achieved with the Hi-4TC if you obtain the custom mapping software and associated cables, but all input must be mapped manually. Honestly, the S&S is MUCH more friendly to those who do not enjoy the tinker factor of a more radical build as it is self adjusting However, it sets perameters as it "Learns" and this will cause soft spots in the ignition slope with "Fat" on either side of the retard point. This is NO issue for anyone not concerned with .001's on the quarter mile strip. This also will eliminate the issue I personally experience with temp and altitude changes, but with a unscrew of the knurled seat knob, and a click of the advance slope dial I can choose a softer custom curve that I programmed in for such occasions faster that I can finish my leg stretch and cig break.
<In my best Kung Fu the series impersonation voice>
You must learn the module to achieve Zen with the Build and the elements of nature Grasshopper
12-07-2004, 08:40 PM
AIBAMC
P.S. anyone who wants to play with a trial, demonstaration version of the Hi-4TC custom mapping software, shoot me an e-mail and I will oblige. You cant do anything but see what it WILL do for you.
12-07-2004, 09:00 PM
AIBAMC
Here is a look (attached image
