Motorcycle.comLeslie Kay'sDiamond Bar ChoppersProCharger.comStainless Ride Specialty AccessoriesOriginal Bike Spirits
SportbikeTrackGear
Old 11-30-2004, 02:45 PM   #1 (permalink)
Stratplexi's Avatar
Stratplexi is on a distinguished road
Another Head Question
What is the compression for a 95" BB with Flat tops if milling the stock heads by .050" ? The SE book says the Flat tops are 9.4:1 with stock heads and I assume that is with standard gasket thickness. It also says the compression with SE heads and the Flat tops are 10:1 and I believe they are milled .060".
Therefore, I would assume that if the heads are only milled .050" it would result in something less than 10:1.
BTW, anyone know the standard gasket thickness and the Cometics?
Also, been talking to a shop that does a 5 angle valve job on stock TC heads and they claim an approximate 10% power increase just from this 'clean-up' work. I think they also stated they change the valve seals and guides while they are doing the job. They do this and mill the heads for $100 each head. Sort of a cheap way to pick up some power. Does this sound correct?
Thanks!
Stratplexi is offline   Reply With Quote
Old 11-30-2004, 03:32 PM   #2 (permalink)
Thanks!
Bullet is the one who can answer your questions on compression ratios with milling the heads.
As far as some one telling you that you will gain 10% more power from a 5 angled valve seat is crazy. What they are saying is if I had 100hp and they put two more angles on a stock valve job you will get 10 more hp.....please give me their number....I will use them in ever build I do......NOT!!!! We can pick up a little hp by cleaning up the last inch of the port and doing a nice blended valve seat but not 10%.....thats a bit far fetched.
Old 11-30-2004, 04:25 PM   #3 (permalink)
Stratplexi's Avatar
Thanks for the quick reply and frank comments. I think my post is a little misleading and I need to clarify what they claim...approximately 10% power increase over stock heads. This was in the context of a Stage 2 BB build with a bolt in cam. In other words, if I let them 'clean up' the heads I could expect an additional 10% gain in power vs. doing nothing to the heads. I thought it sounded a little 'far fetched'.
Thanks again for the help.
