There are a bunch of bore and stroke combos that will go into the B motor. You can go as high as 4 5/8 stroke and 4 1/8 bore to get to 124". Lots of other designs from S&S, Jims, Zippers, and others that can get you to 103, 106, 107, 110, 113, 116, 117, and 120 along with 124. The only recommendation for the B motor is to keep max revs in a reasonable range.
43
