Steve,
Bill Bishop, Jerry Branch, Dave Mackie, Hillside Cycle and Small Block Charlie are just a few of the good porters out there with proven and consistent design for Twin Cam heads. These are precision machine shops that put tolerances within thousands of an inch and verify flow on flowbench. SE heads are ok, but they still require a bit of cleaning up of the interior casting marks and can benefit from a porting and polishing. Also, as I said before, I believe that you may benefit from a 1.94 intake as opposed to the SE 1.90. Check out SB Charlie who does the porting, polishing and valve change for around $350-$400. You can save a little ching in your pocket for maybe roller rockers or Feuling Oil pump. If you go the TW6HG cam, get the 2 degree advance cam key to go with it. This will allow you to get to max torque just a little quicker in the power band. This set up will SMOKE your buddies 95 with 203. 95" builds like this will gain about 105 HP and better, but more important, should get you into the teens for Torque. And they will never see you coming. Engine will look bone stock.
43
