Big bore break in : V-Twin Forum: Harley Davidson Forums
Old 03-19-2013, 01:40 PM   #1 (permalink)
stevedak wants to know Dino or Syn?
Big bore break in
Just completed a big bore upgrade from 88 to 95" on my 2004 Fatboy. I didn't buy a kit with instructions, instead I bought pistons and had the jugs bored to size. Is there a standard break-in process for this kind of mod or a link to a site?
stevedak is offline   Reply With Quote Quick reply to this message
Old 03-19-2013, 02:03 PM   #2 (permalink)
bobbyjoes's Avatar
bobbyjoes wants to know Dino or Syn?
do some heat cycles, you going to have it tuned on a dyno?
bobbyjoes is offline   Reply With Quote Quick reply to this message
Old 03-19-2013, 02:18 PM   #3 (permalink)
Stashu11 wants to know Dino or Syn?
I am no expert by any means, but I read a lot. I saw this post a long time ago and thought it was interesting reading: http://mototuneusa.com/break_in_secrets.htm You might find it helpful.
Stashu11 is offline   Reply With Quote Quick reply to this message
Old 03-19-2013, 02:51 PM   #4 (permalink)
dzlfitr wants to know Dino or Syn?
Ride it like you stole it.
dzlfitr is offline   Reply With Quote Quick reply to this message
Old 03-19-2013, 02:57 PM   #5 (permalink)
brownfoxx1 wants to know Dino or Syn?
i foung this on-line from a racer mechanic. the first 20 miles is critical. you want to
full throttle from 20 mph to 55 or 60 then let off the gas & let the bike slow its-self down to 20 mph. no brakeing. do this at least 20 times then vary your speed to cool the bike off.
what you want is to sling the rings against the cylinder walls several times. in order to
break them in.
brownfoxx1 is offline   Reply With Quote Quick reply to this message
Old 03-19-2013, 04:39 PM   #6 (permalink)
Just pidlin'
CHIPMAKER's Avatar
CHIPMAKER wants to know Dino or Syn?
break them in.
Its more like the first mile.
In any confrontation between knowledge and ignorance, ignorance has the edge,
because knowledge is limited, but ignorance is not......
just pidlin
CHIPMAKER is offline   Reply With Quote Quick reply to this message
Old 03-19-2013, 07:54 PM   #7 (permalink)
CowboyTutt's Avatar
CowboyTutt wants to know Dino or Syn?
NOOOOOO!!! Why does this Motoman Sheet continue to get posted here????? Really??? A HD AIR COOLED Twin Cam motor with iron cylinder liners has its own expansion rates and is NOT the same as the water-cooled engines that Moto Man (Egads!) posted. I wouldn't let that POS break in my air-cooled B&S lawn mower!! Please, please, don't do it his way on your Harley engine!!!
S&S knows knows more THAN ANYBODY on how to break in an air-cooled TC motor. Please consider the previous posts with extreme caution and please read the following link before you make a decision.
http://community.jpcycles.com/articl...-break-in.aspx
Thanks,
Tutt
2009 Dyna Street Bob with Ohlins/Race Tech Suspension
New mystery motor in the works
CowboyTutt is offline   Reply With Quote Quick reply to this message
Old 03-19-2013, 09:59 PM   #8 (permalink)
break them in.
yep, but replace the mph with 3k to 4k and back to 3k rpm. do it in third gear and dont let motor ping or lug. yep, first mile is critical. have done every motor i built that way and no loss of oil conrol and no remarkable leakdown.
Old 03-20-2013, 05:27 AM   #9 (permalink)
Don't know about doing a dyno run til after a break-in. THe S&S instructions seem like a really good guideline. Thanks for all the replies.
Old 03-20-2013, 09:21 AM   #10 (permalink)
compressor#v wants to know Dino or Syn?
Riding the bike too lean, or too rich can do a lot of damage.
If it's fuel injected, do the heat cycles per S&S, then get it to a tuner and let them break it in on the dyno with the correct AFR.
compressor#v is offline   Reply With Quote Quick reply to this message
Old 03-20-2013, 11:38 AM   #11 (permalink)
Nitram_b4's Avatar
Back in the day that Dynos were not av to the average rider / shade tree mech.
When ready to fire up a new build, first made sure of oil flow
2nd after the bike fired you would richen up the mixture until you would see a hint of black smoke if you snapped the throttle off idle then adjust to it just cleared up.
Then adjust the idle and adjust mixture again to confirm
Then run the bike up to temp varying the RPM, shut it down and let it cool to ambient Temp
Run through that cycle about 4 or 5 times, change the oil after about 50 miles than again 250 and 500
2000 FXSTS
97"
KB Pistons
Ported heads
SE 203 Cams
Fueling Camplate and Pump
Fueling lifters
S&S Quickie Push rods
Red Shift Hyd Tensioners
HRS 42 Mikuni Carb
DTT Ignition
Nitram_b4 is offline   Reply With Quote Quick reply to this message
Old 03-20-2013, 02:37 PM   #12 (permalink)
Thanks,
Tutt
I posted it because I thought it was relevant. I think it still is a**hole. If you read it, it says it's for air cooled engines too. It might not be the perfect way to break in a motor, but he shows results for his method. Who else does? I'm not saying this is the right method, but not saying it's wrong either. I used his method on my Lowrider and am not burning any excessive oil at 30,000 miles. To each there own, but I don't see how posting the link is so bad. I am familiar with breaking in aircraft engines (air cooled), and most I've talked to say break them in hard. Anyhow, I thought you might find that article interesting reading even though I offended one a**hole.
Old 03-20-2013, 04:55 PM   #13 (permalink)
Bad Disposition's Avatar
Bad Disposition wants to know Dino or Syn?
Big Bore break in
Is a 95 considered a big bore now days? perhaps I've missed something
BD
08 ULTRA /120R
4.060" big-bore cylinders.
4-5/8" stroke premium forged flywheels worked by R&R
Compression 10:7
T-Man 660SM
R&R Roller Rockers
S&S Lifters (HL2T with limters).
R&R Stage IV CC Heads
HPI 55 mm Throttle Body/1.800 intake
HPI Injectors
Evolution Diamond Terminator Clutch Basket
Bandit Sportsmen Clutch
Bassani Road Rage 2:1 Header
Dyno pending
Bad Disposition is offline   Reply With Quote Quick reply to this message
Old 03-20-2013, 06:23 PM   #14 (permalink)
SirJYK wants to know Dino or Syn?
BD
Yes, I believe it is when you consider starting bore and stroke!
1999 California Motorcycle Company Softail Custom, S&S 88, RB Racing pro stock 2-1 exhaust. Super E. Daytona Twin Tec Ignition 1006. Wood W8 cam. New to me 2005 Electra Glide Classic, stock for now, but not for long...
SirJYK is offline   Reply With Quote Quick reply to this message
Old 03-20-2013, 06:50 PM   #15 (permalink)
Nitram_b4's Avatar
BD
I have a 97" that started life as a 88" you figure it out
2000 FXSTS
97"
KB Pistons
Ported heads
SE 203 Cams
Fueling lifters
HRS 42 Mikuni Carb
DTT Ignition
