SE 95" piston displacement : V-Twin Forum: Harley Davidson Forums
Old 12-19-2012, 05:15 PM   #1 (permalink)
jrgreene1968 wants to know Dino or Syn?
anybody know what the piston displacement is on se 95" 9:4-1 flat tops(cast)?
Trying to see what my compression would end up being with .030 head gaskets,
jrgreene1968 is offline   Reply With Quote Quick reply to this message
Old 12-19-2012, 05:50 PM   #2 (permalink)
DBChoppers's Avatar
DBChoppers wants to know Dino or Syn?
If you are asking what the dome volume is it's about -1.5cc
Diamond Bar Choppers
(909) 861-8833
DBChoppers is offline   Reply With Quote Quick reply to this message
Old 12-19-2012, 05:56 PM   #3 (permalink)
guydoc77's Avatar
guydoc77 wants to know Dino or Syn?
Displacement?
If, indeed, that is your question, then the displacement would be 95/2=47.5.
I suspect you're asking a different question though.
If you're asking about "dome volume", then the answer depends on which piston you have. Assuming it's a flat top, then what DBChoppers said.
To calculate compression though, you'll also need to know cylinder head combustion chamber volume, compressed head gasket thickness, and deck height of the piston.
You can go to Big Boyz site and use their displacement/compression calculator to get a very close approximation.
http://www.bigboyzcycles.com/TwinCamComp.htm
2008 Road Glide
Phoenix Customs Bagger Brace
Glide Pro
Clearview windshield
107
CP flat tops
R&R Stage 3 heads, .030 gasket, 82cc chambers
Trued, welded, and balanced crank by Hyperformance
TMan 590 cams
SE AC
HPI 54mm TB
Supermeg with open cap and 15 discs
TTS tune by BVBob
2003 Indian Scout Deluxe
Aspen White (got it for my wife)
S&S "SuperStock" 88"
12" apes
Scary fast!
guydoc77 is offline   Reply With Quote Quick reply to this message
Old 12-19-2012, 05:57 PM   #4 (permalink)
Thanks man... That's what I needed
