11-29-2012, 10:31 AM
TQ build
Looking to build a TQer this winter from my 88TCb. Looking for 90-100 range any thought?
Whats your #ers and how did you get it, or whar should you have done in a do over...
11-29-2012, 01:11 PM
not sober all the time
Depends on your budget and what you want. Mine is 2004 95" Road King, Wood TW6G cam, Hillside heads, 9.8 to 1 compression, bored throttle body, S&S pushrods, D&D FatCat exhaust. Right around 100 HP and torque. You could do it cheaper using an Andrews 37 cam, less head work, stock throttle body, stock pushrods and probably still be above 90 HP.
11-29-2012, 01:57 PM
That's a dynamite build! The torque curve is straight up, and straight across! I run mine with a touch more compression
2007 Dyna
117" Hillside
11-29-2012, 05:43 PM
That's impressive for the amount spent. Good torque where you need it.
To the OP, what ever you do make sure you get a good tuner to get the most from your build. I'd shop for someone to tune it before I did the build. Do your homework 'cause the person that tunes it can make or break a good build.
11-29-2012, 06:37 PM
That bike had beehive springs as OEM so it was a simple bolt.. All in all I agree very good power.
11-29-2012, 07:46 PM
Actually boreing to 95 and a a bit of head work to bump the comp to about 10:1 works wonders and is less than $1K, problem is you then need a TTS and a tune for another $900 which takes you to around $2k for the whole build.
I have NO REGRETS! and got respectable numbers...
35k miles on the build and still rolling with NO issues. When I tightened the last screw back then and fired it up, it has never been messed with since...not one hickup
11-29-2012, 09:41 PM
Agreed on no headdwork and 26 cam.
Fishtails? Lol dat aint redneck.
Wuts up yankee hehe
11-29-2012, 11:26 PM
Thanks for all the input, lots of ideas. I like the boring of my own jugs. Any issues on balance of pistons?
11-30-2012, 08:23 AM
Axe Man
No problem with piston balance if using the SE 95 inch stuff.
My favorite budget build
SE A/C or Big sucker
Andrews 37 cams
Street port heads, stock valves 83cc chambers
Cylinders bored to 95
Last but not least a good exhaust and tune.
Easy 105 tq and low 90's hp but most importantly torque where you need it.
2007 Ultra
114 CI
SE cases
Woods 8 cams
Reworked 110 heads by nw guy
Thayer 3 stage oil pump
V&H true duals trapp mufflers
103.. on the workbench
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ
11-30-2012, 08:26 AM
Yea Bob but thats not sexy no black panther cam and cool stuff to tell your buddys about.. I am just messing around.. That same idea for us other than I love the 98 kit as it has always increased the tq curve.. But some times the budget is king..
12-01-2012, 12:04 PM
This is what I run. 95" ported heads,se flat top pistons,mik 42,thunderheader,woods tw6 with 4* gear and 3.37 gearing.92hp/102tq. Added se 1.7 rocker arms, 93hp/112tq. By adding the rocker arm's,I got 10ft of tq.But would like more hp.And believe me today,I am on a budget(wife).
12-01-2012, 07:58 PM
i did my 95" in two parts. first andrews 37g's, se flat tops, pc 3-usb, vh 2 into 2. i tuned out @ 92/102. i came back last winter and pulled it apart again. this time i sent my heads into bean. got the heads cut to 80cc and a street port. that bumped me up to the 9.8 for the cams i run. this is good. dumped the 2 into 2 for d&d fatcats and a set of se adj pushrods. retuned out at 100/104. it is not the 130/130+ i am looking for but maybe next time.  with a few more "!!!
2003 fxstsi
95"
BigBoyz 80cc w/street port & mcr
Andrews 37G
Stage 1 w/Zipper Filter
SE adj quick install p-rods
PC3-USB
D&D FatCat
HD 10 row oil cooler
AllBalls 1.4kw
Built by me
12-02-2012, 03:36 AM
Bore to 98", mild beadwork and Andrews 37 - Wood 6 class cam, suitable exhaust are the best value and bang for the buck when starting with 88" motor.
Big power is nice, but for a good-running, fun-to-ride, reliable daily driver - absolute best bang for the buck. Been there, done that.
FXDRYDR
2003 FXD
124"
S&S stuff.
Baisley Pro Street heads
+ Level 2 Mojo.
Badass pipe.
Torq Monster Motorworks
spec'd & built, extra "Special Sauce."
TQ & HP TBD and really don't care.
Stay tuned.
12-03-2012, 05:55 PM
Sent from my SGH-I727R using Motorcycle.com Free App
2005 Ultra classic
-1550 BB kit/Woods WT6/SE adjustable push rods/PCIII
-Mountain MAchining Heads/1.9 intake/1.6 exhaust
-4.6CC CP Pistons/zero deck hieght f/r
-10.2:1
-94hp/103Ft/lbs torque
-V&H TD head pipes/Rienhart Slips
-Baileys Spring/WB easy clutch
-Mustang seat/WW and Spokes
-34 tooth Andrews pully
-Racetech front springs and emulators
-Dyno'd by Bruce @ Dynotunes
2012 883 Superlow
-Windshield and bags
-Mustang solo seat
12-03-2012, 05:59 PM
how much "seat of pants" difference did you feel after head port and comp increase?
thanks
2005 Ultra classic
-10.2:1
2012 883 Superlow
-Mustang solo seat
| Sponsored Links |
