11-27-2012, 02:59 PM
#16 (permalink)
Originally Posted by djl
Increasing displacement from 88" to 95" will net about 10HP/12TQ; stock heads and cams; Stage I exhaust and air filter. At a DIY cost of about $350, it's the best bang for the buck in performance upgrades on a $$/HP-TQ basis. YMMV.
thanks , i was figuring 6hp and 8tq
11-27-2012, 03:04 PM
#17 (permalink)
Originally Posted by Half_crazy
Leaving what you have and just punching it and re-tuning, the results won't be huge. Even with good headwork and well matched cams, your stock carb would probably be holding it back.
carb is bored to 42mm with 48 pilot and 200 main , needle shimmed .05 . do i need to put mikuni on ?
11-27-2012, 03:26 PM
#18 (permalink)
Poser
fwiw, I think you should consider getting head work done while you have it apart and are rebuilding. Sending the heads to bean@big boyz is not that expensive.
From the advice and research I have done, I don't think the stock carb will hold you back..esp your 42...
Otherwise I would probably have a new carb on mine.
rkc
Corbin Classic Solo
V&H Big Shot Duals w "Quiet" Baffles
16" Wild 1 chubby's
TWR stabilizer
11-27-2012, 03:39 PM
#19 (permalink)
That's more like it...
Victory Kingpin 110" Stroker/Big Bore,
11-27-2012, 04:12 PM
#20 (permalink)
ok i have been to hospital today for stitches above my eye and concusion so maybe its me but i dont know if you think i need a mikuni or not ?
11-27-2012, 04:18 PM
#21 (permalink)
rkc
ive already talked to bigboyz , he is going to do a street port , shave heads .02 and set my heads up for s&s 585g cams . just cant decide to go big bore or not
11-27-2012, 04:56 PM
#22 (permalink)
throtle
Thats about what you will get, but the low end torque is much better. When I had mine done I thought this was how the bike should have come from the factory. I also went with Andrews 26 cams and it pulls hard, you can avoid down shifting, just twist the throtle.
11-27-2012, 04:58 PM
#23 (permalink)
Axe Man
You won't like those 585's without a big bore, cheapest power you can find. Do the 98 and be done with it.
2007 Ultra
114 CI
SE cases
Woods 8 cams
Reworked 110 heads by nw guy
Thayer 3 stage oil pump
V&H true duals trapp mufflers
103.. on the workbench
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ
11-27-2012, 05:17 PM
#24 (permalink)
Location: The Burning Sands of NV; formerly the Pines of NJ
I have a set of S&S 585G cams that I ran for a whioe in my '02 Road King sitting on a shelf. They are available if you want 'em, nothing at all wrong with them, just not a good bagger cam & I didn't have enough compression for them. If you're interested let me know.
Sent from my VS840 4G using Motorcycle.com Free App
Eric
'02 Road King
95" Science Project
11-27-2012, 05:23 PM
#25 (permalink)
Originally Posted by nutdriverss
throtle
my dyna really does not see low rpm , low rpms for me is 3000rpms
11-27-2012, 05:25 PM
#26 (permalink)
More cubes more power, what else do you wnt to hear?
11-27-2012, 05:31 PM
#27 (permalink)
lol just trying to build this right the first time , i have a 96ci evo i dont ride because it does not make the power at high rpm i want . evo power drops bad above 5000rpm
11-27-2012, 05:57 PM
#28 (permalink)
I ran 585s in a 98" Dyna at 10.5 and loved it. Bike ran hard and still had good street manners. 185ccp and were I doing it again, I'd bump that to 190 - 195.
FXDRYDR
2003 FXD
124"
S&S stuff.
Baisley Pro Street heads
+ Level 2 Mojo.
Badass pipe.
Torq Monster Motorworks
spec'd & built, extra "Special Sauce."
TQ & HP TBD and really don't care.
Stay tuned.
11-27-2012, 06:28 PM
#29 (permalink)
not sober all the time
are you running compression releases ? i had to put an all balls starter and a zen starter drive gear and 450 cca lithium battery on my evo to get it to start but its 11 1/2 to 1
No compression releases but if I did it over, I'd have them. It hasn't been a problem but I'm sure it would make it easier on the starter and such. I have the original starter, just upgraded the cables. Close to 60,000 miles on the bike, 45,000 on the build. Stock replacement type battery does fine.
11-27-2012, 07:29 PM
#30 (permalink)
hpw much tor the cams
| Sponsored Links |
