SE 120 R 30,000 mile top end inspection - Page 3 : V-Twin Forum: Harley Davidson Forums
Old 11-30-2012, 08:32 AM   #31 (permalink)
Axe Man
BVBOB's Avatar
I'm pulling my 114 down to balance the crank, I'm going to balance the crank on the edge of the work bench while I install the new one, lol
2007 Ultra
114 CI
SE cases
Woods 8 cams
Reworked 110 heads by nw guy
Thayer 3 stage oil pump
V&H true duals trapp mufflers
103.. on the workbench
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ
Old 11-30-2012, 10:12 PM   #32 (permalink)
strokerjlk's Avatar
Fire in the hole.
Fang pipe is on with 662-2 cams
07 ULTRA
SE 120Rxtra
Old 11-30-2012, 11:06 PM   #33 (permalink)
INDEPENDENT 1 is on a distinguished road
What did the CCP come out to?
INDEPENDENT 1 is offline   Reply With Quote
Old 11-30-2012, 11:20 PM   #34 (permalink)
strokerjlk's Avatar
220 rear
213 front
After Two short heat cycles.
After the first heat cycle , it stalled the starter @ 150 rear.
Did the second heat cycle and charged the batt. For the above numbers.
07 ULTRA
SE 120Rxtra
Old 11-30-2012, 11:24 PM   #35 (permalink)
214 was gonna be my guess. You should be good to go!
Old 11-30-2012, 11:32 PM   #36 (permalink)
strokerjlk's Avatar
If it stays here , it will be golden.
Seen one that is 240 ccp now, start out @ 218ccp
Sounds quieter than it was before. I found the rear exhaust push rod was rubbing.
07 ULTRA
SE 120Rxtra
Old 12-01-2012, 10:29 AM   #37 (permalink)
todd comer is on a distinguished road
Thought my 120 compression was going to be to high but after seeing your numbers,should be just fine.662-2 cams,86cc heads,.040 head gasket should put me in the correct compression.
2006 FLHXI
120"
Timken(Kirby)
SE 4.625 Crank plugged welded(Kirby)
R&R Cast heads
S&S roller rockers
T-man 662-2g cams
TTS
Jagg 10 row
HP 55mm tb
Fatcat(bigbore baffle)
Baker DD6
todd comer is offline   Reply With Quote
Old 12-02-2012, 08:12 AM   #38 (permalink)
strokerjlk's Avatar
put 35 miles on it seating the rings. all on the dyno. made a few tuning changes as I went along. the bike is nowhere near dialed it.
did a pull and this is where it is at.
clutch isnt liking the xtra power
red is new pistons
blue is the Fang with flat tops.
clutch slip
07 ULTRA
SE 120Rxtra
Old 12-03-2012, 09:30 PM   #39 (permalink)
Eric in Chicago's Avatar
Eric in Chicago is on a distinguished road
I like the last one, looks like what the 120 does to a stock clutch. Looks like your having fun Jim. Get that sucker dialed in and save me a week on your schedule this winter for a "visit" by big blue
08 V Rod DX
09 Ultra-120r Crate "Plus Motor"
S&S roller rockers,
Tman 662-1 cams,
HPI 58mm TB,
D&D Boarzilla,
Rivera Primo/AIM VPC Clutch
Head work by WFO Larry,
Build and Tune by StrokerJlK (Jim Kennedy)
Eric in Chicago is offline   Reply With Quote
Old 12-04-2012, 05:40 AM   #40 (permalink)
strokerjlk's Avatar
Will do Eric
Little video
http://m.youtube.com/#/watch?v=pRH2m...%3DpRH2ml1aypc
07 ULTRA
SE 120Rxtra
Old 12-09-2012, 02:53 PM   #41 (permalink)
aka SonnyForelli on O&A
HDTC882000 is on a distinguished road
OK, so in laymens terms, seeing that there was head work done to the heads on jims motor, will I expect the same results from my 120? I all ready have 8.5K happy miles on my motor and would love to see my pistons look that good when I eventually break my top end down
2005 FLTRI
NOW IT'S A 120R
V&H Pro Pipe HO
Barnett Scorpion Clutch
HPI 58mm TB
5.3 gps FI
SERT, Tuned by Big Boyz
Seacoast HD Dyno #'s
133 hp
127 ft lbs tq
HDTC882000 is offline   Reply With Quote
Old 12-09-2012, 04:38 PM   #42 (permalink)
strokerjlk's Avatar
there was some concern over this pic.
exhaust cleaned up
I think the tune,and venting to a catch can has a lot to do with the condition of the parts.
07 ULTRA
SE 120Rxtra
Old 12-13-2012, 08:53 AM   #43 (permalink)
strokerjlk's Avatar
Update
I have the drago fang exhaust on it.
Tpp installed and its hooking up better
07 ULTRA
SE 120Rxtra
Old 12-13-2012, 05:16 PM   #44 (permalink)
cruzmisl's Avatar
cruzmisl is on a distinguished road
tpp? What's that?
cruzmisl is offline   Reply With Quote
Old 12-13-2012, 07:27 PM   #45 (permalink)
strokerjlk's Avatar
Originally Posted by cruzmisl View Post
tpp? What's that?
Rivera pro clutch's lock up
Similar to a VPC
07 ULTRA
SE 120Rxtra
